Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Will fill with water but wont continue with cycle, makes a buzzing noise in the console but nothing else. not the lid switch or the motor coupling
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
Check the capacitor on the back wall on the inside of the machine. Here is a link to the part.
Posted on Dec 30, 2010
Replaced the lid switch on my top loading washer and it fills with water and it still wont start.
There are a couple things that could cause that
1) The water level switch,but if it filled to normal level and the water stopped that is pretty unlikely.
2) the motor,if it just sits there silent and no humming/buzzing noise the motor is most likely not the problem,if a heavy buzzing is heard the motor needs to be replaced.
3) again if it just sits there and wont make any sounds no matter where its set at,the timer is the very probable trouble.
I hope this helps you diagnose your washer trouble,
Gene
Aug 05, 2011 | Washing Machines
Machine filled with water then just began beeping. Never started to wash the clothes. When turned off and then on again, it makes a buzzing noise and nothing happens.
If your buzzing noise stops after a few seconds, it could be the motor failing to start. If it sounds like a signal buzzer, it could be indicating the lid open, or a failed lid switch.
May 18, 2011 | Maytag Bravos MTW6600T Top Load Washer
My washer fills and agitates, but when it gets to the rinse/spin cycle it stops and makes a loud grinding noise. Thanks for your time
If it doesn't drain the water after the wash cycle and the sound is more like a buzz then the first thing that I suggest you check is the lid switch. If the lid switch is damaged then the machine will not pump the wash cycle water out and it will not go into the subsequent cycles. The "grinding" or buzzing sound can be caused by an intermittent signal reaching relay switches or solenoids.
Feb 03, 2011 | Kenmore Washing Machines
Washer fills with water but wont continue washing cycle
Your lid switch is bad or loose.. open and close your lid and see if you can hear clicking noises.. if not.. then your lid switch is broken.. good luck
Jan 21, 2009 | Washing Machines
Washes but dosen't drain
you having an issue withthe lid switch not activating, either a bad lid switch, or the "arm that hits it simply not making connection and needs adjusting.. chances are you cant hear a "clicking" noise when the lid is lifted and lowered... if this is the case its a lid switch issue... for safety reasons, the machine is not recognising the door closed so wont enter a spin cycle. will hawever wash and fill
Jan 03, 2009 | Estate TAWS800JQ Top Load Washer
Kenmore washer Model# 11024642300
Dear Customer
Please perform the following checks
Does it drain and spin if not lift the lid and close it slowly did you here a click? no click check lid switch. if it drains but wont spin and the motor is running most likely a bad motor coupling. fills and nothing but it dose drain and spin look a the water level switch. need more info model # Please rate this,Thank u
Dec 16, 2008 | Kenmore 24032\24036 Top Load Washer
Fill with water, stop then no agitation. Please help
ck left hinge screws lid switch is under left rear and is tough to acess if switch seems suspect 2 screws in rear of console are removed and console rolled back to acess switch also ckd wires to motor have seem problem with poor contact in motor connector
Apr 27, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer continues to work even if water is not filled to top and even if i try to stop continues to spin
A defective pressure switch can interfere with the cycles that depend upon the switch to indicate when water has filled or emptied from the tub. It can also result in underfilling or overfilling of the tub. The switch routes current from the timer control to the temperature switch and the water inlet valve when the tub needs to be filled. Once full, the pressure switch cuts the current and reroutes it to the motor on the timer control to continue the cycle.
Dec 07, 2007 | GE WBSR3140DW Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
