Question about Kenmore 44109 / 44102 Side by Side Refrigerator
Kenmore SR1087 Freezer Door will not close without lifting
I can't find the replacement part for this model. I'm thinking the bottom hinge is broken and i should purchase another one and repair myself.
Please help. SearsPartsDirect.com don't have the part.
Http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
check this site out. I have the same problem but I don't have to lift the door to close yet....
Posted on Aug 10, 2008
How to change door opening to other side
Hi Eleanor,
Without a specific model number I can only give general information, but, Kenmore fridges are all about the same, so here we go. Take a close look at your unit. You should observe several small plugs inserted on the side of the doors that don't have the hinges currently mounted. These inserts cover threaded holes that are used to mount the hardware for the hinges. If your fridge has two doors one above the other. remove the top hinge hardware, lift the door up off of the bottom hinge pin. then remove the bottom hardware on the top door. Typically the mounting screws are either phillips head or 1/4" hex head machine screws. You should now see that there is now a threaded hole in the same position on that side as the plug in caps on the other side. remove the caps from the one side and insert them in their respective holes on the other side. the door hinges will attach to the now exposed holes on the side that the plugs were removed from. But not yet. First remove the top hinge hardware on the bottom door, lift the bottom door off of the bottom hinge, and then remove the bottom door hardware relocating the bottom hardware to the other side. Install the bottom door onto the hinge pin of the bottom door hinge. Close the door then install the top hinge on the bottom door. Next install the bottom hinge and hardware for the top door, set the top door on the installed hinge, close the door add install the top door top hinge and hardware next. Same with the door handles. All of this info applies to the doors and the fridge itself.
Jun 26, 2015 | Kenmore Refrigerators
Bottom freezer door will not stay closed.
Check the hinges and the door seal. If you need parts Sears service center online has a great parts locator for kenmore
Feb 18, 2014 | Hardware & Accessories
I have a kenmore upright freezer model 970-254326 bought in 2011 from sears. The door opens left to right but in my tiny apartment I NEED it to open from right to left just to put things in and get th
You should see some plastic plugs or holes for mounting bolts on the opposite side of the freezer case. The latch mechanism should adapt from one side to another.
You would remove the top hinge and then lift the door off of the bottom hinge. Then you would remove the bottom hinge and switch it to the other side. Place the door onto the bottom hinge and then install the top hinge on the other corner of the case to match.
You should be able to move the handle from one side to the other. The magnets in the doorseal should work as before to keep the door closed. The interior light is usually centered on the bottom to aid in reversing the door opening.
Dec 30, 2011 | Kenmore Freezers
I have a sears kenmore elite refrigerator. It is a side by side. The doors don't line up when closed. The freezer side is about 1/4" higher. It looks funny when closed.
there are plastic spacers located at the hinge on the bottom of these units, and they break after wear and tear , they are also beveled so they help the door close,, check to see if yours are in good order, if not you'll have to replace them,, to do this you remove the top hinge,, its just a couple of screws that hold the hinge on under the plastic deco cap ,, once you've done that Lift the door off the lower hinge,, install the spacers, and place the top hinge back once the door is reset
Aug 25, 2011 | Kenmore Side by Side Refrigerator
How do i take freezer door off a side by side frig that has water/ice options
usally a quick disconnect block for wireing harness on top freezer hing. There will be a water supply tube going up through bottom freezer hinge with a disconnect union fitting close by usally under refrig behind toe grill. once these are disconnected you can then take top hinge off of main part of refrig. by taking screws off on top of upper freezer hinge. you then should be able to lift door off by lifting up on door and water line should slide up and through the bottom hinge.
Feb 27, 2010 | Kenmore Refrigerators
Freezer door not sealing
replace the seals and / or have the hinge adjusted
May 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My freezer door will not stay shut. Dometic Model RM2453. This is the model with the freezer compartment inside the unit. Springs in freezer door seem weak or broken.Can I safely remove the plastic spring...
yes you can.remove two screws from under one side pull it away slightly and it will come away.you will then have one housing on both sides left in the fridge wall,they will have a little pressure on them from the springs. just prise them away. you will need help to replace them, as you need pressure against the spring to keep the door closed. you can buy springs and housings seperately from camec there is left and right housings.give me a call if you need to ..
Apr 22, 2009 | Dometic RM2452 Refrigerator
Freezer door rubbing
take the freezer door off and put a washer or two on the bottom hinge. sometimes there are extra plastic washers on the top hinge that you can move to the bottom to lift it up.
also check if the hinge is bent or loose, as this may cause the problem.
Jun 28, 2008 | KitchenAid Architect KTLA19KRSS Stainless...
Bottom hinge on fridge door broken
Yes, there is supposed to be a plastic bushing/washer under there. Usually 1/8 inch thick. If a dealer is not handy you may cut some out of plastic to put there. Then undo the top hinge, and carefully lift the door off (you might want to empty the shelfs). Put your spacer on the hinge pin, and replace the door and the top hinge.
Jan 28, 2008 | Liebherr Premium CTP 3153 Top Freezer...
Kenmore 44109 / 44102 Side by Side Refrigerator Logo
627 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
