Question about Mantis Tiller
Circuit breaker on electric Mantis appears shot. How do I replace it
    Champion:
  • 208 Answers
Mantis electric tiller runs for about 20 seconds then cuts out. Hit circuit breaker, runs then cuts out again and smells like it's burning. Went through all the troubleshooting and no warranty. Help!
It probably smells like it is burning because that is exactly what is happening. Persisting is likely to make things worse, if it is possible for things to be worse.
As the circuit breaker is tripping it is likely the fault is electrical. There probably isn't much electrical to go wrong apart from the motor, a switch and some wiring. A motor fault would seem likely unless the mechanical drive is so very tight it is overloading the motor.
Clearly the machine must be dismantled and checked through by someone competent to do so. The supplied troubleshooting guide is not likely to be much help as they have to be safety-conscious, they tend only to deal with external issues.
Jun 23, 2016 | Mantis Garden
When you said turn off circuit breaker did you mean from electrical panel or is there something on dishwasher
The breaker this should be referring to is inside your home's panel box. Sometimes electronic devices will have an inline fuse to stop power surges from damaging expensive delicate boards with hard to find ICs, but this is a fuse that burns an electrical element and has to be replaced after it's been used, or in other words it's a one shot thing, versus a breaker which is a mechanical device that moves a set of contactors when it senses an over current situation and can be used repeatedly. Unfortunately you didn't ask this question with the string that your first question was linked with so I don't know the original problem, but I have never known of a washing machine that had an on board circuit breaker, and know that many do not include inline fuses either.
If you have additional questions please post (to this string so the can be easily found) and if you found my answer helpful please up vote it, and let us know your results.
Feb 28, 2015 | Washing Machines
Dead short
A electrical dead shot is when an electrical circuit has zero resistance; this happens when an electrical feed comes into contact with metal objects such as a metal outbox, the ground, or a neutral wire. A common sign of a dead shot is a tripped breaker.
Read more from: http://www.diyobd2.fr/
Oct 18, 2013 | Oldsmobile Achieva Cars & Trucks
Hot water heater
1) Check across top two screws on upper element for 240volts.
Circuit breaker can be tripped on one leg so water heater appears to have power, but only has 120Volts to ground, and not full 240Volt potential across both wires.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#electricity
2) Move wires to another same-size circuit breaker
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
3) Add comment and say what you find, and for more assistance Dec 2012
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 12, 2012 | Rheem Water Heaters
Hot water heater not heating
Hello Nick. probably a simple problem:
Circuit braker faulty
The following link is step-by-step troubleshoot for water heater electric circuit:
http://waterheatertimer.org/Test-electricity-to-water-heater.html
Link also tells how to test breaker inside main breaker box, and then ends with step-by-step troubleshoot for internal electric water heater parts.
See basic water heater circuit on following link:
http://waterheatertimer.org/240-v-water-heater-circuit.html
If circuit breaker is bad, following link shows how to replace circuit breaker:
Jan 11, 2011 | RELIANCE ELECTRIC WATER HEATER
Bathtub pump totally dead, pump ran dry for 10 sec, is there circuit breakers on pump motors, switch or is it the motor shot. any way to test motor with removing it?
Normally pump motors are connected on a separate
circuit with its own circuit breaker. At your house there is always a electrical control panel housing several circuit breakers for lights, power outlets, range, aircon, motors, etc...Find a tripped off breaker and reset it. To reset the circuit breaker is to switch it to off position and back to on position. Better still you may reset all the circuit breakers except the main
circuit breaker (biggest amp rating).
After resetting the circuit breakers, try to switch your
bathtub pump on, (to test it, if it is still okey). Other-
wise, your motor is damaged and you got to have the
motor rewinded, to be operational.
Dec 09, 2009 | Plumbing
ELECTRIC blower will not start.
There may be a shorted winding in the motor. Bypassing the breaker may smoke the whole thing. Look in your phone book or online to find a Toro repair facility. They'll have any parts you need
Sep 12, 2017 | Toro Blowers Rake and Vac - Electric...
My electric lawn mower starts briefly and then trips the circuit
check cord from plug to the electric motor.if it has a reset or breaker check for damage. if no obvious damage problem is electric motor.may be cheaper to buy new 1
May 06, 2009 | Electric Lawn Mower
Mantis Tiller Logo
141 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
