Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
It burns up ink cartridges in one day. what it wrong with this thing. we have put numerous cartirdges in this printer and the light flashes the next day and says you ink is low and needs to be replaced. help me, i am going broke. vr Richard Maples
SOURCE: not recognizing new ink cartridge
We had the same problem and tried all steps Customer Service suggested each time; after several calls, it was determined we had a defective printhead... Kodak sent a new printhead, new ink cartridges w/ an envelope to return the ones I was using.
Apparently it's a common problem with this model; especially the earlier ones. Have had NO problems since the printhead was replaced.
I would suggest if you have recurring problems (even after Customer Service directives), call and ask if you might have a defective printhead.
Posted on Jan 16, 2008
SOURCE: Kodak EasyShare 5100 won't print
Hi FixYa team, my Kodak printer's "Check color ink" red light was flashing so I just put in a new color ink cartridge (even though I am only printing black and white). I restarted the machine to try and print some address labels and it acts like it is printing but the paper comes out blank yet I can print pictures. I tried to print and email and it won't do that either.
Thanks.
Posted on Sep 17, 2008
kodakman1986
  • 4 Answers
SOURCE: installed new ink cartridge/ still saying low color
try calling 1 800 421 6699 for US.
solution
try to remove inks, then reseat it..
then remove printhead, by pushing the latch on the upper right, then put it back in. be sure that it will snap. close the door with no inks. try to look at the message, if it has the same error, put the inks on it and close the door again.. then if you still have the error message, call the hotline no. and I'm Afraid that you need a Printhead replacement or defective ink issue...
they will replace it for free..
Posted on Feb 10, 2009
  • 295 Answers
SOURCE: Error message that color cartridge has low ink, so
No way 2 override the message. Printer works on a combination of both black and color ink to print those perfect pictures and documents. If it is showing color ink needs replacement,you ve 2 change it in order to print even in black and white.
Posted on Jan 16, 2010
  • 15 Answers
SOURCE: My Kodak ESP 3 all-in-one printer will not print
you may try to clean the printhead and recalibrate the printer. if this will not correct the problem, you need to replace the printhead. I suggest contacting Kodak technical support to have a replacement printhead.
Posted on Apr 17, 2010
Cartirdge errors
take a cotton swab an distilled water an clean the contacts on the ink cartridges let them dry for about 15 min. an put them back in ..
Jun 01, 2012 | HP Officejet 4315v All-In-One InkJet...
I have put a new black cartridge in printer but nothing is printing out- when I run a test the color cartirdge are working but not black
Hmmm, make sure it is properly fitting in there.... Take it out and put it back in.... Usually the printer performs some kind of "preparing the ink" operation... SO allow it to does this...... Make sure you are using genuine ink, sometimes printers won't accept non-genuine inks.... Hope this helps :)
Jan 08, 2011 | Brother MFC 490cw Color Inkjet...
Two red lights flashing under ink icon and yellow "E" flashing
E it measn the Printhead is not detected or printhead not installed., Its normal if you have E error that you will have 2 flashing red light check color ink or black.
Now try to reseat the printhead of the printer, YOu need to removed first the ink cartirdges before you can remove the printhead.
Now if you already reseat the printhead 2x and the ink cartridges It means the printhead is defective call Tech support for printhead replacement toll free 1 800 235 6325
Nov 12, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
It will not register the ink cartigdes.always showed 'low' from day one. put new cartirdges in black still says low. says color cartridge is missing..used to be able to bypass the ..won't print at all now
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
Aug 26, 2009 | Dell 948 All-In-One InkJet Printer
I have put a new Cyan ink cartirdge in put it will not print
Make sure the cartridge is full y inserted if not will not print and it will aslo not display.
Aug 01, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Do I have to install a color cartirdge (CL-41)?
Some will allow printing with just black & others will not. You may need to put a color cartridge in to print. Check your owners manual or canon website to make sure but if you do need a color cartridge you can buy a generic brand that works with your printer to save some $$. Hope this helps.
Feb 18, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Hp 920c tech support
check your print cartridge has not plastic strip stuck on bottom side of it.
recoonect all connection then try.
Nov 24, 2008 | HP DeskJet 920c InkJet Printer
Wrong Cartridge
replace print head. print head is bad.
Jul 27, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Brand new Printer lights flashing
You should install driver first, then connect printer when prompted, then install inks, as it needs the driver to tell it there are full inks fitted, refer to the manual.
Dec 20, 2006 | Ricoh Aficio G7500 Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
22 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
