Question about Maytag Dryers
It stopped working smell hot breaker ok ck plug and cord ok 220 volt ok
  • Maytag Master
  • 1,902 Answers
Hello & Welcome to FixYa
If the smell comes from the rear panel then it can be due to a bad thermal fuse/thermostat which is located on the blower wheen housing to the exhaust duct, this fuse cannot be reset if it tests open then it needs replacement. Another thing that can cause burning smell is the motor going bad, it is located at the bottom of the unit, after reading your question most likely it is the motor that is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Dec 30, 2010
Dryer gets warm but not hot. Takes much longer than used to.
A lot of times when this happens, the are vent is plugged up, had one that did this and come to find out it was plugged up so bad it stopped getting hot. hope this helps.
Dec 01, 2015 | Dryers
HELP???
What was the voltage that you measured? Are the units 220 volt or 120 volt. Units that size are usually fed by 220 volts. What is the current rateing of the circuit breakers? Are they a double breaker with a handeling capacity of 20 amps or are they 15 amps.
You didn't mention if they ever worked? Are you feeding 120 volts or 220 volts to the two units?
Good luck,
Marty
May 11, 2014 | Dometic Rooftop RV Air Conditioner
I have a electric dryer Model WED5810SW0 THAT I WAS TOLD I COULD CONVERT TO 120V from 240v is this true and if so how do i do this?
If you consider doing this the first thing is SHUT THE MAIN BREAKER OFF. Use an auxiliary light source to see when working in a dead panel. Always keep in mind an ARC FLASH ACROSS HOT MAINS HAS ENOUGH HEAT TO PEAL THE SKIN OFF OF YOU. Before an explanation of how to do it you should keep in mind that this is for a single receptacle only. If any other receptacles are on the same circuit they will also be changed to 240 volt receptacles and if you plug any 120 volt device into them, the 120 volt device will be destroyed. That said OK, any 120 volt outlet can be changed to 240 volt by removing the 120 volt circuits neutral, re identifying the white wire with red or black phase tape and connecting it to a new 2 pole 15 amp breaker. The maximum that this circuit will now load up to is, on #14 wire at 80% = 12 amps at 240 volts. The 120V receptacle must be changed to a 15A - 240V receptacle so that 120 volt devices can not be plugged into it. Never use 2 single pole breakers together because code requires that on a fault trip both legs of the 240V circuit must be disconnected simultaneously. OR USED A Quick 220 Voltage Converting Power Supply
Voltage converter buying guide. Voltage Transformer Buying guide.Voltage converters also known as voltage transformers are devices that convert foreign electricity to power devices from different parts of the world. A step down voltage converter is a 220 to 110 volts converter. A step up converter is a 110 volts to 220 volts converter. Our 2-way converters are voltage transformers that convert power from both 220 to 110 volts and 110 to 220 volts. They also work with 100 volts, 110 volts, 120 volts, 220 volts and 240 volts. This model is a 2 way voltage converter / voltage transformer available in many different sizes including 100 watts, 200 watts, 300 watts, 500 watts, 750 watts, 1000 watts, 1500 watts, 2000 watts, 3000 watts and 5000 watts.
Sep 07, 2011 | Whirlpool Dryers
How to install???????
ok. if it is a electric dryer u need a 220 volt plug in to make it heat and work. u need a dryer vent metal tube so the hot air and lent can go out. u hook up the vent tube plug in the 220 cord and it should be find. ok
Feb 13, 2011 | Dryers
My GE DPSB620ECWW does not light up the pannel or
Check circuit breaker at the house electric panel, if good, check for voltage (220/240)volts at the receptacle that the dryer power cord plugs into, if good, check for voltage(220/240)volts at the dryer terminal block where the dryer power cord connects to the dryer, if good, check voltages at the dryer power transformer, should be 220/240 volts for motor,and 110/115 volts control power for dryer controls, you should find the failure within these inspections/testing.
Good Luck !
Mar 15, 2010 | GE Profile DPSB620ECWW Electric Dryer
How can i convert our 220 volts wall outlet to 110 volts for a microwave oven.
Find the breaker for it (a double for 220) and substitue a single breaker (for 110). This will leave one wire unused from the breaker box to the outlet. You'll have to change the outlet of course to accommodate a normal 110 plug. You can also skip the breaker part and just change the outlet and cap off 1 of the hot wires. Just make sure to kill the power and be safe!
Mar 11, 2010 | GE JVM1650 1000 Watts Microwave Oven
Replacing a power cord
Hi. Replacing a power cord usually isn't a big deal. Locate the breaker at your main panel for the dryer (usually located at the box with the meter, outside) and trip it to the "off" position. Test the circuit by trying to make the dryer come on at the dryer control panel (it should not). Unplug the dryer and gain access to the power leads (where the cord connects to the dryer). It is probably a 3 lead cord. If so, the outside leads will be the hot leads as dryers are 220 volts with 110 volts per hot lead. The middle lead will be the ground, which is the return path from the dryer. Carefully note the position of the wires as you disconnect the cord. A diagram that you make for yourself is always helpful. Note on your drawing which wire connects to which lug and the color of the wire leaving the lug to the dryer from the terminal strip where all of the connections are. An example of this would be that the left cord wire connects to the black wire, etc. The outside "hot" wires of the cord generally will be connected to either a red or black wire in the dryer. Neutral and ground wires are generally connected neutral to white and ground to green (or directly to the frame).Buy a replacement cord (take the old one with you). Replacements are generic and you can get one from any hardware store, not just at Sears. Reconnect the cord in the same manner in which it came off. Replace the electrical cover plate previously removed. Plug in the dryer. Turn the breaker back on. Try the dryer. If anything seems/sounds/smells wrong, trip the breaker back off and re-investigate. Don't try to shut it off at the dryer. Hope that this is helpful albeit generic as it is, and thanx for using FixYa.
Regards, WoobieDog
Jul 06, 2009 | Kenmore Dryers
I have a ge spacesaver laundry in order for the washing machine to work the dryer has to be running. what is the problem
ck wiring to unit should be 220 volts between 2 outside screws and 110 between each outside screw and middle screw ..ck breaker box to be sure breaker is not partially kicked
Sep 28, 2008 | GE Washing Machines
I have a Hotpoint Electric Dryer Model Number NBXR453EVOWW, It quit all of a sudden and will not turn on.
raise top ck thermal fuse on element housing on rear wall top right side..also possible door switch ..if you have already verified breakers ok and unit has 220 volts
Jul 15, 2008 | Dryers
GE Spectra range
All of the items you mention that do work, are 120 volt items.
All the items that do NOT work are 220 volt items.
Sounds like you have a voltage problem, you will need to use a meter to check if you have 220 volts a/c to the outlet the stove plugs into. Take care when doing the following, you will be around live voltage and could get hurt. If you are uncomfortable working with a live circuit best to call someone in to do it for you. Check for 220v at the outlet for the stove (where the stove plugs into), if you have it there, go to where the cord attaches to the stove and check at that point. You should have either a 3 or 4 wire cord on the stove, On the rear of the stove there is a terminal block that the cord is fastened to. Between RED and BLACK you should have 220v, between RED and WHITE and BLACK and WHITE you should see 120v. Another thing to check is that the nuts holding the wires from the cord to the terminal block on the stove are turned down tight. A loose connection there will give you the same problem you have as well.
Jan 07, 2008 | GE Spectra JBP78 Electric Kitchen Range
Dryers Logo
41 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
