Question about Cameras
When i take a picture it tells me that the memory is full and i have installed a new memory card. The camera is new
  • 747 Answers
I will assume that this camera is using a SD card as there is no make or model shown. All new memory cards need to be formatted to the camera so the camera can read the card. Also SD cards have a lock on the side it's a little sliding switch that can be very easily pushed to the lock side while installing the memory card here is a diagram of the lock and unlock position of this card.
Formatting a card must be done in the camera the memory card is being used in your owners manual may refer to formatting as initializing
Posted on Dec 30, 2010
I have the sony camara DSLT A300 evreytime i take more than 2 pictures it tells me card is full
You didn't tell us how much memory you have installed. At 10 megapixels, even a 2GB card will hold fewer than 20 full-resolution photos. Installing the maximum Compact Flash memory of 8GB would seem mandatory to me unless you want to voluntarily limit the resolution at a point lower than the 10MP native resolution.
May 06, 2011 | Sony Alpha DSLRA300 Body Only Digital...
It keeps saying memory card is full. Bought a new memory card and put in and it still says the card is full.
Are you sure that isn't "internal" memory card is full message?
Sometimes, when "internal memory card is full" there is no more space in the camera's internal memory. Your camera has 16 MB of internal memory. The number of pictures you can store depends on the picture size setting you have selected on your camera. Keep in mind that the camera always uses internal memory, even if a card is installed (auto default).
If really, the problem is in the "SD memory card", I suggest make some backup all files and reformat the SD. Try formatting it in the camera, there should be a process in your owners manual for doing this; donw formatted SD in your computer, isn't good.
Hope helps.
Apr 28, 2011 | Kodak EasyShare One Digital Camera
I have a samsung nv3 camerea , i added a new blank memory card but camera says memory full and cannot take pictures
It may be telling you that the internal memory is full. You must get rid of anything in there. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, insert your new card and do the "format" thing again.
Jan 21, 2011 | Samsung NV3 Digital Camera
When I try to take a picture, it says memory full. But, when I try to look at the memory it says no file. I tried using the disk, installing software, formatting it.. Nothing works. The SD memory card is...
Format the SD card make sure the camera is set to place the new files on the SD card and not go to the internal memory. What I fully expect is the camera has defaulted to using the internal memory which is now full of files/pictures and needs to be set back to SD card. To get the pictures from the internal memory to your computer you need to load the pictures one by one from the internal memory to the SD card. Then take them from the SD card ether to a card reader to the computer or download them from the camera to the computer.
Dec 25, 2010 | Vivitar ViviCam 8025 Digital Camera
Every time i try to take a picture my camera is saying my memory card is full and it's a new 8GB card. it's saying my internal card is full. i have 15 pictures on the 8GB i don't want to delete. i have not...
The camera is actually saying that the internal memory of the camera (which is very small) is full, not your card. Here's what to do....with no card in the camera, go into the menu and find "format"(may be called "initialize") and follow the on-screen instructions to erase the internal memory. Once that's done, your card should work properly.
Nov 19, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
I have a Lumix cameera, Model # DMC-FZ8. I recently installed a new memory card because the one that came with the camera began to malfunction. The new memory card is now having the same problem. The...
Put it in play mode and see if there are pictures on the card (if the card wasnt brand new, of course) If not the card more than likely needs to be formated. In play mode push menu set button go to format when it says delete all data in memory card select yes.
Aug 21, 2010 | Panasonic Lumix DMC-FZ8 Digital Camera
Display reads "images recorded in internal memory" but there are none and I can't take more than 4 pictures until the camera says the memory is full. Also the memory card says it is full after 7 pictures,...
hi, the memory card you are using is to small for the camera it has not got enough memory on it you need to get at least a 1gb memory card or 2gb memory this will then allow you to take between 500 and 1000 pictures the 16mb card you have in is not worth using it will only hold a couple of pictures so go to the well known auction site and buy a 2gb memory card of the same type such as sd card or micro sd or mini sd it should tell you on the 16mb card what type it is then just buy the same type but with either 1gb or 2gb or even 4gb of memory this will then let you take 1000s of pictures
the 16mb card is no good in your camera get a bigger card and your problem will be solved
let me know if you have any problems with the new card ok
Aug 15, 2010 | Fuji FinePix A800 Digital Camera
Have blank 2GB card, camera tells me memory full. How do I get camera to accept the card and send the picture to it no the camera?
this camera takes only cards wich are formatted first on the camera.It will display an error message if you do not use a formated card.See your manual page 59
Apr 14, 2009 | Samsung NV7 OPS Digital Camera
Memory Full Error
You need to format the SD memory card using the camera format function. The manual should tell you how to do this. If you don't have the manual, you can download it from the samsung website.
Jul 05, 2007 | Samsung Digimax S700 Digital Camera
"No image"/"memory full"
Get a memory card ans download them to it --it is telling you the internal memory is full
Sep 17, 2006 | Samsung Digimax 420 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
