Question about Oliso TG-1000 Iron
The auto lift will not work on my pro series oliso. It's stuck in the out position.
I have the Oliso Pro and it will not stay on. I know it is out of warranty can it be repaired?
Look for a local repair shop. We have not been told what is wrong and someone who can see it might be able to find out.
Jun 04, 2018 | Oliso Irons
My oliso tg1250 has stopped lifting,what can I do??
Call 1-800-899-5157 - or - email customerservice@oliso.com
They made this and they are the experts.
  • THeT
    Apr 06, 2017 | Oliso Irons
    How can I clean the plate of my Oliso pro. It has wonder under on it
    get the iron hot. Take a piece of fabric and a dryer sheet. Put the dryer sheet between two layers of fabric. Place this at the edge of your ironing board. With the iron hot, run the sole place over the "fabric/dryer sheet set" several times. This will remove wonder under and many other adhesives from your iron.
    May 31, 2016 | Oliso Tg1600 1800 Watts Smart Iron Pro
    I got this iron for christmas, it shot steam 2 times and thats all. I had it set on cotton, linen. I used reg bottled water, should i use tap and why no shots of steam.
    take it back for a warranty exchange after you check that the thermostat setting is on steam
    distilled water is recommended for irons
    bottled water ( filtered water) and tap water is the same product and will have minerals and contaminates that affect irons
    Jan 02, 2016 | Oliso TG-1100 Continuous & Burst of Steam...
    I plugged my max 110 V Oliso iron into our house's only 220 V outlet. Smoke is being emitted and it is unusable (The iron, not iron). Can someone please tell me how to fix it?
    are you saying that the iron works with 110 volts and you plugged it in a 220 volts outlet??? if so then the voltage is to high for the iron (luckily it didn't get burnt) but all you need to do is plug it into a 110 volt outlet
    Jun 23, 2015 | Oliso TG-1000 Iron
    Oliso auto lift not retracting
    Its can be your switch inside it so you have to strip it and cut it out its a small its like a resistor you can brigde the wires its also fine or you can go and buy a new one and put it again but you will need to solder it back
    Sep 12, 2014 | Irons
    Iron leaks , lift stuck in up position
    Here is a tip that will help you with that problem...
    My Steam Iron is Leaking Water
    http://www.fixya.com/support/r5301301-steam_iron_leaking_water
    heatman101
    Jun 12, 2010 | Oliso TG1100 Iron with Auto Shutoff
    My oliso iron is not heating up yet all the lights go on when I plug it in and turn it on.
    Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
    Electric Iron not Heating Up or not Working Right
    http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
    heatman101
    Nov 30, 2009 | Oliso TG-1000 Iron
    Oliso TG-1000 Iron Logo
    122 people viewed this question
    Top Oliso Irons Experts
    Andrew Taylor
    Andrew Taylor
    ray gallant
    Bill Boyd
    Are you an Oliso Iron Expert? Answer questions, earn points and help others
