Question about Dishwashers
Dishwasher dose not drain water - Dishwashers
  • 2 more comments
  • CARKINGINC Aug 19, 2008
    THE DISHWASHER HAS A FEW INCHES OF WATER IN THE BOTTOM
  • debby32652 Dec 16, 2008
    1 year old. I only use it once every two weeks. Hasn't drained completely last two times; leaves food residue. What to do??
    what does this mean?? What do I do? Only a year old, seldom used.
    BAD CHECK VALVE ALLOWS WATER TO BACKFLOW FROM HIGH-POINT SIPHON BREAKER
  • quadwilly Mar 16, 2009
    I have a GE dishwasher and it will go through the cycle and it tries to drain but it won't. I stuch my hand down in the garbage disp. to feel if the water was going in and there was a trickle. This is a new garbage disp. not used yet and I bought the dishwasher used and has new hoses. What can be wrong with it? =<
Posted on Jul 08, 2008
Should a sump pump pit have holes in the walls and where dose the water drain to
Water in electric dishwashers drains into the sewer line. The holes in the walls are to keep small diameter drain line from clogging. Keep the holes clear.
May 13, 2015 | Dishwashers
Dishwasher hose - I am changing my kitchen and want the dishwasher further away from the drain and water pipe. Is it ok to extend the hoses (by adding another hose onto the current hoses) or do they need...
It should be OK
Just make sure that the hose going in to Garbage dipsal loops obove so water dose no siphin in to the dishwasher when u#ing thr GD
Nov 16, 2014 | Dishwashers
Miele dishwasher doesn't work.error F70
When this problem happened to our machine, it was simply the pipes under the sink where the dishwasher drain pipe fits were blocked with muck. This was preventing the one way valve connecting the drain hose to the household waste from fully opening thus preventing the machine complete its drain cycle.
Solution was to thoroughly clean the sink drain pipes - plunger, power plunger and then a dose of chemical cleaner. Dishwasher is as right as rain now:)
Mar 29, 2010 | Dishwashers
My SHY56A05UC Basch dishwasher runs and dose not shut off
The dishwasher is stuck in drain mode because there is water in a catch leak area underneath, it may have been caused by soap suds over flow or disposal backup. Remove bottom kick plate and vacuum out any water, then run dishwasher again and look for water leaks.
May 21, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
The dishwaher dose not empty even with the pump running
Here is a tip that I wrote that will help you with your problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Mar 01, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Frigidaire Dish washer MODEL
hi there aaliyazaidi2.is the water clear or dirty that you find in the dishwasher?there are two ways this could be happening.1,if the water is dirty[although it dose not have to be ,but its a sure clue]its you drain line of your dishwasher.what happens is because the drain line is lower than the sink drain, when you use your sink water runs by way of gravity in to the drain hose and then fills up your dishwasher,till you drain it or wash a load...to solve this problem you need too make a loop as we repairman call it.get some zip ties ,or what ever[string] and tie your drain hose off at the top off the sink under the sink cabinet[imagin your drain hose as a roller coaster, the hose coming from the dishwasher is the start of the coaster before it goes to the top of the big hill.what you want to do is ,at the top of the roller coaster hill,tie your drain hose to what ever you can under you sink causing a hill so when your hose goes back down ,it ends up into your disposer or what ever plumbing it ends up into.[hay i hope i helped you understand what i mean their];#2,the other way is your dishwasher water valve may not be sealing well. the water would only be clear if this was the issue and could be warm water because its only hot water to the dishwasher.what happens here is because the water valve is not sealing water slowly adds to your dishwasher may be drops at a time,and over the hours gone by it accumulates and the you notice water in the tub.to solve this you replace the water valve.its[most of the time blue,but could be tan or white]under the dishwasher.the water line from your house goes to it.i hope this helps you you can email if you need more help. God bless ,tom
Feb 25, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
Dish washer IDL 550
Hi meeey,
I'm Harvey the Master Plumber.
Your problem is: Your dishwasher dose not drain water, and now dose not turn on the machin
Any body can help you?
If the motor runs but it won't empty then the pump needs replacement. If the unit washes but the motor won't come on to empty then you have a control problem. Either way I don't recomend this repair to the average homeowner. You might consider utilizing our Repair Directory to find a repair man. If the d/w dosen't come on at all then it may be time to consider replacement.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 10, 2008 | Indesit 24 in. IDL500 Built-In Dishwasher
Dishwasher dose not drane
YOU CAN TRY REMOVING THE LOWER RACK AND LIFT OFF THE SPRAYER. THE DRAINAGE WHOLE IS USUALLY VISABLE. YOU CAN FLUSH OUT THE DRAIN TO SEE IF THAT DOES IT. THERE SHOULD BE NO STANDING WATER IN THE BOTTOM OF YOUR DISH WASHER AFTER WASH CYCLE AND DRY CYCLE. HOPE I COULD HELP.
May 02, 2007 | Hotpoint 24 in. DF55 Free-standing...
Dishwasher won't drain all the way
After cleaning the air gap thingy my machine works fine again. This thing sits on the left lower back side of the machine (left when you are standing in front of the machine). It is a transparent plastic box with 3 hoses attached (drain hose from pump, drain hose to the outside and water). Inside the box is a black plastic float. If debris gets caught in there the float gets stuck.
Solution is to remove the part by pulling the 2 drain hoses out (there is a small black clip holding them in) and unclamp and remove the water hose. Rinse and shake the housing until the float moves freely again and reassemble.
Jul 31, 2006 | Siemens 24 in. SL84A305UC Built-in...
Dishwashers Logo
362 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
