Question about NetGear N150 / RANGEMAX 150 Router
Does not connect to IP address 192.168.1.1 - NetGear N150 / RANGEMAX 150 Router
  • 600 Answers
You have to enter your DEFAULT GATEWAY-and that may not be it--go to START>RUN and type "CMD" in the box-- at the command prompt type "MSCONFIG" and you will see your DEFAULT GATEWAY.
If this was helpful, please indicate so, if not -comment back so we can dig further to resolve this.
Posted on Dec 31, 2010
What is an IP address
IP address is like our normal address. if you have to go somewhere you need to know the address. Same goes for devices. IP address is given to all devices which are connected to a network. So that they can understand from which device you have to connect.
Now to get you laptop's IP address just type "what's my IP address" in Google search bar.
Jun 04, 2017 | Computers & Internet
Tip
How to set up a static IP address in Windows Vista
Static IP addresses are often used for computers that host specific services, or for computers on small, manually managed networks. To set up a static IPv4 address on a Windows Vista computer, first find an IP address that is not currently in use and is outside the DHCP assignable range (if applicable). Then follow either of the procedures below.
From the taskbar:
1. Right click on the network connection icon in the system notification tray.
2. Select Network and Sharing Center.
3. Under Tasks, select Manage network connections.
4. Right click on the network connection that you want to set up the IP address for (Local Area Connection, Wireless Network Connection, etc.)
5. Select Properties.
6. If the User Account Control window pops up, select Continue.
7. Click on Internet Protocol Version 4 (TCP/IPv4).
8. In the Properties window, click the circle next to Use the following IP address.
9. Enter the IP address that you want to assign to the computer.
10. Enter the subnet mask and default gateway. (For small or home networks, these will typically be 255.255.255.0 and 192.168.1.1, respectively.)
11. Enter the IP address of the DNS server next to Preferred DNS server.
12. If you have an alternate DNS server, enter that IP address as well.
13. Click OK to save the changes.
From the Start menu:
1. Click the Vista orb.
2. Right click on Network.
3. Follow the procedure above from step #3.
Reserving an IP address under DHCP is different from setting up a static IP address. To reserve an IP address, log into your router's configuration utility and look for a heading such as DHCP or IP Address Distribution. You will probably need either the computer's Windows name or its MAC address to reserve an IP address for it.
on Jan 30, 2011 | Computers & Internet
What is ip address
Internet Protocol is also known as Ip address.Every users on internet have their own ip address.Users on internet identify by their ip address.Ip address provided by the internet service provider.There are two types of ip address static,dynamic ip address...
Static Ip address will not change forever ..Even if you reset the modem the static ip address won't change.Static Ip address also known as dedicated ip address..You can use for website..This ip is dedicated for your website only..
Dynamic Ip address :
Dynamic ip address will change whenever you reset the modem.A new ip address will assigned for your connection...You can use dynamic ip address for browsing and normal internet usage....you can use the site Ip-details.com check the ip address whether it is static or dynamic ip address
Jul 24, 2013 | Computers & Internet
Setting static ip address
Do you want to connect your Nokia phone with static ip address you have?You can check the details in user manual or you can search instructions in online.It differ from phone to phone.But you need to wifi modem to connect your ip address to Nokia phone.For home connection ISP provides static ip address.You can use only that.But mobile phone network providers won't give static ip for phone connection.To check ip address you can visit the site Ip-details.com
Jul 24, 2013 | Nokia Cell Phones
Why will it not connect to the internets IP address?
If you reset the modem and ip address will not change and remains same hence it is static ip address.If you reset the modem and the ip address change ,it is dynamic ip address.
You can get the Ip address from your internet service provider.you can check the ip address using the site Ip-details.com .
Jan 25, 2013 | RCA DCW615R Wireless/Cable Modem
How come the http://192.168.123.254 address isnt working?
Find your computer's IP address : Windows 7, Vista, and XP, using the command prompt
  1. Click Start, and then select All Programs. Note: If this doesn't match what you see, refer to About navigation settings in Windows.
  2. Click Accessories, and then Command Prompt.
  3. At the command prompt, enter: ipconfig The IP address (or IPv4 address, if you are using Windows 7 or Vista) will be a series of numbers following the pattern xxx.xxx.xxx.xxx (i.e., 156.56.27.32).
Note: If you are using PPP with a modem at home, your IP address will change each time you log in.
Windows 7, without using the command prompt
  1. In the system tray, click the network connection icon and select Open Network and Sharing Center.
  2. To view the IP address of a wired connection, click Local Area Connection. To view the IP address of a wireless adapter, click Wireless Network Connection (Network Name).
  3. Click Details... . Your IP address will appear next to "IPv4 Address".
Windows Vista, without using the command prompt
  1. From the Start menu, right-click Network, and then select Properties. This opens the Network and Sharing Center.
  2. To view the IP address of a wired connection, click View Status to the right of Local Area Connection. To view the IP address of a wireless adapter, click View Status to the right of Wireless Network Connection.
  3. Click Details... . Look for the address next to "IPv4 IP Address".
Windows XP, without using the command prompt
  1. From the Start menu, right-click My Network Places, and then click Properties.
  2. To view the IP address of a wired connection, double-click Local Area Connection. To view the IP address of a wireless adapter, double-click Wireless Network Connection.
  3. Click the Support tab, and then click Details... . The window that appears will display the IP address.
Your IP address has to be in the 192.168.123.xxx range
The router must be configured to match your
Internet service. If you do not know your
Internet connection configuration, please
contact your Internet Service Provider (ISP).
By default, the router is pre-configured with
these settings:
• Automatically set IP addresses for
computers on your LAN (connected to the
router's ports 1-4). The router acts as a
server for dynamic host configuration
protocol (DHCP) and assigns IP addresses
in the range 192.168.123.100 through
192.168.123.199
• The default LAN IP address for the router is
192.168.123.254 with a subnet mask of
255.255.255.0
• The Internet service connected to the
router's WAN port uses a dynamic IP
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 26, 2010 | Asante FriendlyNET FR1104-G Wireless...
How do I find my IP address? trying to connect to xbox live and the xbox does not connect. needs address.
To get your IP address, click start and click control panel. Click network and internet connections and click network connections. Right click your local area connection and click status. Click support to see your IP address.
Nov 08, 2010 | Computers & Internet
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
I can not connect to the local area connection.
1. check your network adapter TCP/IP settings if its set into "Obtain as IP address Automatically".
2. if the settings is set as Automatic and your not getting IP address then select "Use the following IP Address"
3. use IP address followed to your router address like if192.168.0.1 in router type 192.168.0.2 or192.168.0.3 justcheck the next address IP in your network.
4. after typing subnet IP will automatically set
5. type the router IP address as your default gateway
6. click OK to save your new settings
hope this will help you
Nov 26, 2008 | NetGear WGR614 Wireless Router
Wrong ip address
Are you trying to get an IP for your computer, or for your modem? Assuming your using a high-speed connection, possibly a router?
Mar 28, 2008 | Computers & Internet
NetGear N150 / RANGEMAX 150 Router Logo
114 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
