Question about Eureka Altima Upright Vacuum Model 2996AVS Vacuum
Can not get the dirt cup off of my eureka altima 2993
I have a similar model but I believe the solution would be the same. My dirt cup wasn't coming out after turning the lever so I wedged a butter knife between the clear dirt cup and the grey plate under it and pried the two apart. With the knife pushed in between the two pieces came apart easily. Now the cup slides out with no problem. can not get the dirt - _395.jpg
Posted on Jan 02, 2011
  • Mattie Anna Dec 07, 2011
    FINALLY a real solution...
    @mgibbons_392: T H A N K Y O U!!!!!!!!
    After much time struggling with it and much time wasted looking up solutions to this problem in other websites, you gave us an actual solution!
    Thank you for taking the time to write this down AND including the picture, which made a world of difference.
    It's people like you that make our word a better place. Not even the those paid to do the job (Eureka Tech Support), posted a real solution like yours.
    If I could hug you, I would, so suffice it to say that we, at our house hold (it was 3 of us working on this problem), are MOST grateful. :-)
I can not get the dirt cup out to empty it.
Just slide the dark gray release tab, located just below the cup, all the way to open position, and then pull the Easy Empty Cup toward you.
Jul 10, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
I have a eureka altima bagless and it wont pick up dirt i clean it and everything it just wont work
The belt is probably worn, stretched or broken that is why it is not picking up. Here is a link to the owners manual which has instructions and a link to the belt you need.
Eureka Altima Owner's Guide
Eureka Altima Replacement Belts
Nov 20, 2009 | Eureka Capture Upright Vacuum Vacuum
I need to know how to remove the dirt container on the eureka bagless vacuum. It says that it is easy to remove, yet we cant figure it out. is there some trick to it that we dont know?
there is a lever at the bottom of the dirt cup,turn it to the left and pull out the dirt cup.note while you have the dirt cup out make sure you clean all the filters there is one right above the dirt cup pull out on the right side and there is a filter on it and at the bottom right below the dirt cup there is a door that says hepa.clean that one to.then your good to go
Apr 23, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
The dirt cup clip broke and can't find the part!! Eureka whirlwind lite model#4388
I am assuming that you're looking for the handle at the front of the dirt cup... Part # 28131-288N, it has been replaced by part # 74985 Dirt cup grip assembly. If you call Eureka Customer Support at 1-800-282-2886 they will be able to find you a local dealer.
Apr 02, 2009 | Eureka Whirlwind 4388 Bagless Upright...
Eureka altima 2993av bagless
Hi
Sounds like its blocked. Check under the glide plate and the hose. Look in the book for model specific details
Feb 22, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka Altima Spitting dirt back out
your intake is clogged at the bottom and your filters are dirty not letting it create suction.is the dirt cup full
Oct 24, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka Altima
The dust cup has a small gray tray that appears to be part of the cup, but is not. I made the same mistake also and almost broke the stupid thing trying to get it out. Simply push the lock to the left to unlock. Gently lift the dust cup and not the gray tray and the cup will slide out easily.
[IMG]http://i294.photobucket.com/albums/mm88/SteelNET13/vacuum2.jpg[/IMG]
[IMG]http://i294.photobucket.com/albums/mm88/SteelNET13/vacuum1.jpg[/IMG]
Oct 01, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Dirt does not go in the dustdup
Take off the front top filter (the clear plastic peice where it says eureka) there should be two filters inside, the bit of foam and the peice it's attached to.
I clean both parts in warm soapy water and let dry, that always fixes the problem for me.
Sep 07, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka altima bagless
I experienced the same problem of being unable to remove the dust cup. Inspection of the dust cup appeared to indicated two tabs on the bottom of the dust cup preventing it from sliding straight out as illustrated in the instructions. However, after much fiddling, I assumed that the dust cup with the tabs was probably a slightly different part than actually intended for that particular model (2996avr) and so decided to force the cup out, reasoning that if the tabs broke in the process, that was necessary for removal of the cup anyway, and therefore not detrimental.
HOWEVER, upon forcing the cup out, the cup broke away from a plate upon which it is designed to sit. The cup had apparently become stuck to the plate after much use without sufficient care and cleaning. The plate is what the tabs are attached to, and so by breaking the cup free of the plate, the tabs were not an issue, and the cup easily slid in and out of the housing, as intended. It was also observed, upon removal of the cup, that there is a very slight lip on the front of the plate to secure the cup in the proper position; this would likely act as an additional hinderance if the cup was also stuck to the plate by old cemented grime.
May 16, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Lost Manual
You didn't mention brand or model #, but try going to the manufactures web site and see if they offer manual downloads.
Oct 31, 2007 | Euro-Pro Shark SC-505 Handheld Steam...
Eureka Altima Upright Vacuum Model 2996AVS Vacuum Logo
272 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
