Question about Hotpoint 23 in. BFI68 Built-in Dishwasher
The error message codes for flash rapid wash and auto duo wash both flash on my BFI 680 dishwasher. What should I do?
2 Suggested Answers
Daniel S
  • 4323 Answers
SOURCE: My BFi 680 dishwasher swithches
Hi
The timer is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 21, 2011
Ariston l63 is not rinsing proper cycle but instead flashing 12hr light
Error messages,
Your dishwasher is equipped with a safety system which is able to detect any operating anomalies. These anomalies are reported by one or two wash cycle indicator lights "G" flashing rapidly.
24463930-0h3kxpflbez5mdeb5anq3st4-3-0.jpg Flashing LED diode above the mark 12h (drying) indicates faulty NTC thermistor. So, could be faulty: thermistor NTC, wiring between NTC and control board, control board.
Dado
May 20, 2014 | Ariston Technologies L63 Free-Standing...
How to repair - no water is entering the dish waterr
Your dishwasher is equipped with a safety system which is able to detect any operating problems. These anomalies are reported by
one or two wash cycle indicator lights "E" will flash rapidly.
Any flashing combination of LED diodes (Intensive wash, Regular wash, Eco wash, Rapid wash, Soak and Crystal care) means different error code. Take a note of which lights are flashing?
If you have problem with fill water than following two LED should be flashing.24428775-0h3kxpflbez5mdeb5anq3st4-3-0.jpg
In this case could be:
  • Water valve disabled
  • Turbine disabled
  • Control board faulty
Dado
May 15, 2014 | Ariston Technologies LL65 Built-in...
HOTPOINT DISHWASHER BFI 620 ERROR CODE LED FLASHING 1 & 3
Check the end of your drain hose for the clog.
Feb 17, 2013 | Dishwashers
Hi, our ariston dishwasher has stopped before the cycle finished and the water has not drained out. There are 2 flashing lights - the brush emblem and the spray ' on a tilt' emblem (the 2 on the...
Error messages.
The dishwasher is equipped with a
These anomalies are signalled by
the rapid flashing of one of the
wash cycle indicator lights M.
If the indicator light for the soak
cycle flashes (see wash cycle table),
cancel the wash cycle by following
the instructions indicated in the
"Modifying a wash cycle in
progress" paragraph on page 4.
Now check whether there is any
water in the mains supply and that
the tap is turned on; if the error
message persists, then call for
technical assistance, indicating
which message appeared.
If the indicator light for any wash
cycle apart from the soak cycle
flashes rapidly, turn the appliance
off and call for technical
assistance, indicating which
message appeared.
Troubleshooting
You have checked
everything, but the
dishwasher still doesn't
work and the problem
persists?
Call an authorised service centre
near you and remember to mention:
? the type of malfunction
? the model mark (Mod?.) and the
serial number (S/N?.) indicated on
the rating plate located on the inner
door, to one side.
If you need further help, reach me via phone at https://www.6ya.com/expert/kelley_9a924afdf232bd4d
Jan 14, 2018 | Hotpoint-Ariston LI 640 24 in Builtin...
My dishwasher model No. is Hotpoint BFI680, There was water lying in the bottom after a wash and it couldn't be restarted, I cleaned it out and took out the drain pump and connected it up to 240volt and...
Hello!
As the manual says:
If water remains inside the
dishwasher, check:
the drain hose is not kinked.
the drain syphon is not
obstructed.
the dishwasher filters are not
clogged.
i also add a link to this manual, hope it will help
Hotpoint BFI 680 User Manual Page 13 of 20
May 23, 2017 | Dishwashers
Hi My BFI 680 trips the electricity at the mains just as you put it on. Have cleaned the filters. Any ideas ?
could a internal fault in m/c[shorted wires] water,faulty on /of switch,recheck wiring to m/c
Dec 31, 2009 | Hotpoint 23 in. BFI68 Built-in Dishwasher
Function buttons do not work on off button does
I have expreienced the same problem and carried out a hard re-set by holding down the on/off switch whilst pressing the program button. It's now working - but not sure for how long!
Jan 06, 2009 | Hotpoint 23 in. BFI68 Built-in Dishwasher
Dishwasher does not heat up
the heater t.o.c will be blown it may be resetable access by removing the side panel if the stat is resetable it will have a red button on the top simply press till you hear a click good luck
Jul 21, 2007 | Hotpoint 23 in. BFI68 Built-in Dishwasher
Open Questions:
See all Hotpoint 23 in. BFI68 Built-in Dishwasher Questions
Hotpoint 23 in. BFI68 Built-in Dishwasher Logo
56 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
