Can't get wireless connection to work - Computers & Internet
  • 600 Answers
If your trying to get on the internet with a wireless connection.and running WINDOWS, .and I am assuming you DO have a wireless router all set up and configured to broadcast the signal (not hidden) ....first we have to determine if the problem is at the router or at the laptop AND at what point its getting stuck ... so first try this
try resetting the router (disconnect the power to it for a few minutes) next --be sure the wifi switch is enabled on the netbook---next---go to CONTROL PANEL>NETWORK CONNECTIONS--right click oin your wifi card and choose properties--highlight INTERNET PROTOCOL and choose properties and be sure "OPTAIN IP ADDRESS AUTOMATICALLY" is checked--Does the laptop "SEE" the router?
You will need your SSID to logon to the router(internet)
this is a link to a troubleshooting flow-chart
http://www.daileyint.com/hmdpc/laptop/wireless.gif
If this was helpful, please indicate so, if not -comment back so we can dig further to resolve this.
Posted on Dec 31, 2010
Public wireless conection unable to connect
Hello It`s probably your wireless router that`s not working, or you could be too far away from the antenna.
Is the power supply working, for the router, are the cable set right, is the router on, are your internet connection working.
You can take the router, to a computer repair shop and let them test it.
The router must be connected like this:
But the wireless setup code for it, is different from one router to another.
If the wireless is working elsewhere, the pc is not the issue.
Good luck
Jan 20, 2013 | HEWLETT-PACKARD Hewlett Packard 448337-001...
Compaq presario F500. Wireless internet connection not working. Internet works when plugged into modem. D-Link wireless modem working perfectly. Constant red/orange light on next to wireless switch at...
Hi, Thanks for using fixya.
When you connect it to wireless make sure you go into control panel / network view your connection right click on local area network connection choose disable then connect to your wireless connection. Right click your wireless icon by your clock choose connect to wireless network or view available local wireless connection.
Terry
Feb 15, 2011 | HP Compaq Presario F500 F700 and G6000...
WIFI not working with Linksys wireless-g broadband router/Comcast
Unplugging the wireless router and connecting it again should not have altered the wireless connection/configuration. You have connected the cables correctly because the Internet works when you connect a LAN cable to the router.
The Linksys wireless configuration or the wireless card configuration in the computer was changed it to lose the wireless connection. The wireless card configuration needs to be changed to match the wireless router's settings or change the Linksys with new configuration settings and configure the wireless card accordingly.
To secure your router with a login password and wireless security, please follow my instructions - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Should you need further assistance, please leave me a comment.
Dec 25, 2009 | Linksys Wireless-G Broadband Router
I have a d-link router. i can connect to my
The wireless card is configured for your D-Link at home.
You need to configure your laptop's wireless card for the wireless settings at work too (ie the SSID and encryption etc.). Contact the network manager at your work for the wireless configuration so you can configure the wireless card with these settings.
It maybe possible to setup different profiles on the laptop's wireless card, one for home and one for work so you can just click on the correct profile depending on your home or work location.
Dec 12, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Cant get wireless router to work on laptop
First, try to connect your laptop hardwired to the router, if it works fine, its just the wireless configuration. Make sure you are using the correct wireless network key to connect to your wireless network. Go to the Control Panel > Network Connections > Right-click Wireless Network Connection > Properties > Wireless Networks Tab and delete all the names listed under Preferred Networks box. Click Ok. Right-click on Wireless Network Connection again > View Available Wireless Network > Choose your own network and click Connect. If it asks you to type the network key, type in your WEP or Wireless Network Key and press connect. That should do it.
Oct 06, 2009 | Computers & Internet
Unable to connect to wireless internet. wireless connection shows disabled.
check whether wireless drivers are installed.
check wireless is enabled.
check in network connections whether u can c wirelass lan connection.
Apr 21, 2009 | Computers & Internet
DI-524 not working with Vista32 Dell M1330
make sure your wireless card is set to "obtain automatically an IP address"
Jan 25, 2009 | D-Link AirPlus DI-524 Wireless Router
TOSHIBA EQUIUM WIRELESS PROBLEM
You might deleted your driver to wireless connection or you perhaps upgraded Service Pack to higher version. If your wireless connection will work on lower SP then that device won't work or vice versa.
Another thing, try to check connections. Click menu and look for connections and try to enable wireless connections.
Thanks
Jan 11, 2009 | Computers & Internet
Actiontec GT704-WG wireless connection not working
you say it suddenly stopped working, if you can connect to the router via ethernet cable then try to access the router's web utility page and make sure your router is in mixed or G-only. If you can't still connect to the router through wireless then try restarting the Wireless Zero Configuration from windows. This is how it's made: Go to control panel and double-click "administrative tools", then double-click "services". You will see a list, scroll down to Wireless Zero Configuration and click "stop", you'll see a progress bar. After that click "start", you'll see another progress bar. Now try connecting to your router via wireless connection. If you still can't connect then repair the connection by right-clicking the wireless icon at the bottom right corner. Keep repairing until you connect.
Hope this works!
Feb 16, 2008 | Actiontec GT704WG Wireless Router...
Wireless and internet
1. Make sure that wireless settings are properly synchronized.
>> ssid/security key.
2. Check your computers wireless connection status
> Make sure that it is set to "obtain ip address automatically)
3. If still not working if computer is set to obtain ip automatically, try assigning static ip on wireless pc
> You need to know your router's ip address and dns
4. Disable firewall on wireless pc.
Jan 23, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
