Question about Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher
Jenn air diswasher mod # JDB1100AWS
DISHWASHER WILL NOT WORK .NO LIGHTS ON CONTROL PANEL ATTEMPTED A RESET VIA THE CIRCUT BREAKER,I CYCLED THE POWER GOT LIGHTS TO COME FOR NORMAL WASH AND HEAT DRY BUT THE UNIT WILL STILL NOT WORK .AFTER A FEW MINUTES THE LIGHTS SHUT OFF. DO YOU THINK I SHOULD REPLACE THE CONTROL BOARD?
  • sueellenb Jul 30, 2008
    I'm having a similar problem on a Jenn Air JDB9910AWB. Control panel is dead. No lights. I've checked circuit breaker, door latch mechinism, and checked door latch switches for continuity. All seem properly working. Admitting defeat, I started unloading the dishwasher to the sink. Closed the door and tried the normal clycle button for grins--and the dishwasher started! Opened the door, shut it again, and once again, no lights, no action. Any ideas?
  • dickersons Aug 22, 2008
    we have same problem too, maytag has replaced the control panel 3 maybe 4 times under warranty. It acts like there's moisture getting to the electronic board because the panel fails after maybe a month of washing. Any solutions? no recalls that we've heard about.
Has anyone got asolution to this? I have the jdb1270 and am experiencing the same thing. 2 years later. Looks like Jenn-air has not fixed this problem
Posted on Nov 17, 2010
Disassemble front door to get to the latch. Check if the latch is properly in place, sometimes the metal cylinder that hold it in place, slips out of position.
Posted on May 19, 2009
Control panel won work power
yes the have power cord. see this steps and fix it.
God bless you
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer or Control Electronic
Replace if defective (note: uncommon problem).
4. Selector switch
Read more: http://www.appliancepartspros.com/repair-help/dishwasher-repair-help.html#ixzz2aaj83j00
Jul 30, 2013 | Jenn-Air 24 in. JDB1100AWS Built-in...
Control panel will not light up, the dishwasher was running and now it has stopped mid cycle and will not do anything. I just replaced the control panel (black plastic with buttons, not control...
I have a kitchenaid dishwasher model # KUDC10FXBL1 I went to start it and none of the buttons were working. I have checked the breaker and the wiring and everything seems to be in order.
Jan 13, 2011 | KitchenAid 34 in. KUDP01FLSS Stainless...
Suddenly it seems there is no power, nothing on the control panel will lights up. I have reset the breaker with no success. Please advise on the problem and solution.
Possible failur of the control panel. It can be a power supply failure in this unit, can be the SMPS, if so please refer to my repair guide to service SMPS, Check my link:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
if not the controller unit must be changed.
Sep 21, 2010 | Jenn-Air 24 in. JDB1100AW Built-in...
No power or lights in the front panel
Check the fuse / circuit breaker inside washing machine. There may be a extra control circuit fuse normally on the control PCB.
May 28, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Still soap left in the machine after a wash, soap residue left on dishes
What type soap. Some soaps have been found to be so concentrated that it causes an oversudsing. Electro lux did have a problemwith the little white ball in the center causing this. To desud the dishwasher pour 1/2 cup of liquid fabric softener in the diswasher and run thru entire cycle with the heater in the off position. This will rid the dishwasher of any build up.
Feb 01, 2010 | Jenn-Air 24 in. JDB1100AWS Built-in...
Difficult to pull door open and loud click coming from left hinge
I would check for obstruction in the path of the door spring areas. If appropriate, remove the bottom access panel (typically 2 screws); open/close the door in attempt to observe the inside bottom left and right for the clicking sound.
If not already done so, also ensure your dish-washer is raised of the floor a little bit; leveled and properly secured to counter top with 2 screws.
-C
Fremont, CA
Jan 30, 2009 | Jenn-Air 24 in. JDB1100AWS Built-in...
Flashing Power Failure Light on Frigidaire Diswasher Model # FD989GFC2
I have a Frigidaire that does the same thing. I was able to push the start cancel button then select a cycle and press the start button, shut the door and presto it worked.
Oct 17, 2008 | Frigidaire 24 in. GLD2162RDC Stainless...
Jenn Air Dishwasher Model JDB1100AWS Light Normal/Extra Rinse are the only two buttons that work.
have you solved youre problem ? i have a dead 11000 series unit no one has any input so much for trying to save a buck.time to switch to paper plates i had a bosh before this i went through 3 contol boards then threw it out i miss the old manual controls
May 31, 2008 | Jenn-Air 24 in. JDB1100AWS Built-in...
Jenn-Air dishwasher jdb1100aws problem
I hate to sound like a broken record. But look for my vinegar and CLR fix. In my experience in most cases that works.
Thanks
Kashif. A
Mar 07, 2008 | Jenn-Air 24 in. JDB1100AWS Built-in...
Open Questions:
See all Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher Questions
Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher Logo
1,300 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
