Question about Canon IXY 1000 Digital Camera
My camera is saying that my SD card is locked, not sure how i did that and do not know how to unlock it sunshi7575@aol.com
    Brigadier General:
  • 11,967 Answers
Try moving the slide switch on the side of the card.
Posted on Dec 31, 2010
Trail Card Lock
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 12, 2013 | Moultrie Game Spy D-55IRxt Game Camera
SD card is protected, how to unlock SD card
Take your memory card out of the camera and switch the position of the "lock" tab. One position is for "locked" (i.e., "Write Protected") and the other position will allow the card to be written to (unlocked). Some cameras have image protection built into the on-camera software and you may need to configure this there.
Jan 06, 2012 | Cameras
Camera says card is locked but it's not!!!
You already know about the 'lock' switch on SD cards; did you know it doesnt actually lock the SD card by itself? It merely pushes a switch lever in the reader (in this case, your camera), that in turn tells the electronics to NOT write on the SD card.
So, if your SD cards are indeed working (check on a card reader), it would look like the lever in the camera that senses the position of the lock switch is jammed / bent. If you could pry into the card slot in the camera, and try to shake this lever with a long narrow object (a straightened paper clip, perhaps), that might yield good results.
Alternately, look up 'CHDK' on Google; it is an alternate OS that gives your Canon *lots* of other features. In your case, more importantly, it *requires* the SD card to be locked in use. Dont worry, with CHDK booted in, the camera will store pictures even when it sesnses the card is write-protected. So, it not only solves your problem, it gives you loads of extra features like RAW capability, time laps, remote operation and more, all for free.
Regards,
Anand Dhuru
Apr 21, 2010 | Canon PowerShot A710 IS Digital Camera
My memory card is locked how can i unlock it??
SD and SDHC cards have a slide switch along one edge. The position furthest from the contacts lock the card, the position nearest the contacts unlocks it. Try sliding the switch fully away from the contacts, then fully toward the contacts. If that doesn't solve it, try a different card.
Jan 24, 2010 | Panasonic Lumix DMC-FS4 Digital Camera
Card Locked
First I know you've said you've checked the card's slide switch, but just want to restate this first for others with the same problem who may not know of this switch.
Check to make sure that you didn't accidentally place the tiny locking slide switch on the side of your SD card in the "locked" downward position. The correct "unlocked" position should be slid up toward the direction of the connectors.
If you've tried this, and it's still showing locked, it's likely that the locking switch inside the camera's card slot is stuck. If you look inside the slot on the side of the slot where the SD card slide switch would be, you'll see a glint of gold color on the side. This is the camera's lock/unlock switch. The other glint's of gold that you may see at the far end of the slot are the reader's connectors (ignore those).
Somehow, the locking switch is making contact and has become stuck in the locked position. With a plastic toothpick, or other skinny NON-METALLIC item, tap against this switch to see if you can jar open the contact to its normal unlocked position. Also try blowing compressed air at it, as some gunk may have worked its way in there, jamming it closed. Occasionally, reinsert the SD card to see if the issue has been corrected.
If repeated tries fail, it may be time to consider opening the camera to force open this switch (not recommended unless you have some familiarity with electronics). In this case please see the following (xscrewdriver, hope you don't mind me referencing your blog):
http://www.myfixtips.com/blog/digital-camera/how-to-fix-a-%e2%80%98card-locked%e2%80%99-problem-125.htm
Jun 24, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Camera says SD Card is locked but card is open;
Jun 16, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Sd card not working
Check to make sure you didn't accidentally move the locking switch on the SD card to the locked position. There will be a switch on the side of the card. One side of the switch says locked, (or has picture of a locked lock) and the other side says unlocked, or has a picture of an unlocked lock. Try it out.
Dec 31, 2008 | Nikon Coolpix L11 Digital Camera
Jazz-Hdv178
Did you unlock the SD card or accidentally lock it again?. There is a switch on the SD card to unlock it. Try this and then let me know how you make out.
Aug 29, 2008 | Jazz DV-179 Digital Camera
Canon IXY 1000 Digital Camera Logo
26 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
