Question about Mitsubishi WT-42413 42" Rear Projection HDTV-Ready Television
Have a mitsubishi wt-42413 that won't turn on it is not the outlet. won't go on with remote or switch on tv
5 Suggested Answers
  • 1694 Answers
SOURCE: MItsubishi WT 46809- not staying on when turned on
One or more fuse devices open==caused by convergence IC
shorted. Solution==replace fuse(s) and STK I.C.(s).
Posted on Oct 11, 2007
  • 159 Answers
SOURCE: Mitsubishi WT-42413 Blue Green and Red Line
there is a section in the tv working just to keep the screen fitting top to down (vertical section) some capacitors are dry now in that area. this one has not to be a expensive job in the workshop. Try estimates
Posted on Apr 14, 2009
style_points
  • 34 Answers
SOURCE: Mitsubishi WT-42311 DLP Bulb Replacement
Your access should be a a panel near the back or side. You will see that it is somewhat easily removed and should have maybe one or two screws. You will see the casing to the lamp. Go ahead and remove it. Now unscrew the old bulb and replace it with a new one. There is not a lot of screws holding it together. It's a fairly easy process once you find the lamp. You should see the lamp once the panel is removed.
Posted on Apr 27, 2009
SD Tech
  • 14553 Answers
SOURCE: Mitsubishi tv model wt-42311, error code 2-2. what can i do?
2,2 IS short protection and 95% chance it means one of the two pico fuses that protect the convergence IC chips are bad.
This model uses two of the chips: STK-392-110 and you would have to pull the light box out to replace them safely (total parts cost will be under 30 dollars).
It involves getting at the chips and the fuses and replacing them: how much skill do you have?
SD TECH
Posted on Mar 25, 2010
When turned on mitsubishi WT-42413, it turns off itself within a second. any help?
Check you -24and + 24 on power supply and you green fuses if open fuse replace fuse and the stk394-250 good luck
Jan 16, 2011 | Mitsubishi WT-42413 42" Rear Projection...
Picture shadow
Tv have a problems known as a convergence problems,it dead.Tv colors lines R,G,B mis alignment,have colors pictures shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 12, 2010 | Mitsubishi WT-42413 42" Rear Projection...
Tv won't stay
It sounds like the convergence went out. STK 394-250 and some pico fuses. Check that the error code is 2.2 before you replace any parts.
To check the error code simply hold down the menu and device buttons for 5 sec and count the flashes inbetween pauses. Goodluck.
Jul 05, 2010 | Mitsubishi WT-42413 42" Rear Projection...
Mitsubishi WT-42413 Red Convergence will not move left right
U check all the resistors with the Ohm Meter?All the resistors u check it in tolerance?Resolders all the resistors,so it make good resistance for the ICS?U do all these steps,u still have problems,Ur ICS some how it shorted it dead,again.
Apr 02, 2010 | Mitsubishi WT-42413 42" Rear Projection...
Apr 14, 2009 | Mitsubishi WT-42413 42" Rear Projection...
Wt-42313
there probably is a fuse blown. but something made the fuse blow. If you can take the back off and find out if one did blow and the location for it i can probably help you further.
Sep 22, 2008 | Mitsubishi WT-42413 42" Rear Projection...
Mitsubishi television light turned on then two seconds later turns off
Looks like the infamous protection circuit error. Can you give me more details please? Does the LED stay on after the set turns itself off?
Aug 31, 2008 | Mitsubishi WT-42413 42" Rear Projection...
Mitsubishi WT42413 Convergence Problem
I have a Mitsubishi rear project. TV. Model #42413. I have a problem with the convergence problem where I am seeing double???
May 25, 2008 | Mitsubishi WT-42413 42" Rear Projection...
Mitsubishi wt-42413 Power problem
Okay try to distinguish if the three blinks is 1 pause then 2 blinks or 2blinks pause 1 blink. As the set will only blink a two digit code 12 meaning no error detected and 21 meaning the set is hutdown due to xray protection.
May 13, 2008 | Mitsubishi WT-42413 42" Rear Projection...
Mitsubishi WT-42413 42" Rear Projection HDTV-Ready Television Logo
69 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
