Question about Acer Computers & Internet
I am trying to network my acer with windows vista to the desktop wireless router belkin 54g. My other two laptops worked after making the wireless connection secure but the Acer laptop will not go to any wireless network not even an unsecure one.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
Have you verified the wireless card that is in the machine? (Are you certain there is one there?) Even if there is one inside it, the PC may not see it. Go to device manager (My Computer, Properties, Hardware tab, Device Manager button). Then look through the list to find "Network adapters", click the "+" to the left, and it will display a list of adapters present in the machine. Make sure there are no yellow caution symbols or other error icons in any area.
Then, if you can see a wireless card listed, right-click to view the properties. Please post back with the results, and the exact info regarding your PC and the wireless card if you need more help. Otherwise, thank you for using and rating FixYa!
Posted on Jul 08, 2008
Hi, my son's Laptop says it is conned to the Belkin router but still cannot connect to the net?
Double click on Wireless Network Connection taskbar, then click property, on Wireless network's tab, check on the box ' Use Windows to configure......"
Jun 22, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Change my settings from wep to wpa I have a belkin 54g
when you change the wireless security on the router , it is recommended tht you will change the wireless network name also ( SSID ). Because when you try to connect to the wireless network on the computer, your computer will try to connect to the same old network name with the old wireless security settings. To avoid this you can change the wireless network name. WPA is supported by windows XP SP2 and above operating system.
If the operating system on your computer WINDOWS XP SP1 and if you are trying to connect using the windows utility then you would not be able to connect to the network .
Click Here for more information about the routers and networking
Jan 28, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
I a using cable net and not the dsl line.the net on my pc is working but when i try to connect ps3 wirelessly it show 100% signal from belkin but the internet connection fails.i have tried different...
check the wireless settings of the router .
Make sure that you are typing the correct network key if your network is secured.
May be you will need to open the ports on the router.
Jan 04, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Belkin router not giving signal to linksys adapter HELP!!!!!
I dont think belkin has a stable driver for win.7 at this time. I have a belkin n router with a belkin adapter and had no luck.
Some people have had some success using a Vista driver.
You could go to www.bioticaindia.com and download a win 7 driver there. They show a 48% success rate.
Dec 13, 2009 | Belkin Computers & Internet
How do I put security on my Belkin 54g router
You set your security by enabling WEP.
When you get in the interface to configure WEP, set a pass phrase. Write down the 3 numeric keys it generates. Then connect to the wireless using your laptop, etc. When it asks for your passkey, do not enter the pass-phrase; enter one of the three keys that were generated by the router. That's the biggest mistake people make when trying to get wireless to work.
Oct 06, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Can't connect DSi with same security as comps
hello, yes i had the same problem, but i had it with many other computers, the way i solved it was going into the router settings and click the "restore default settings" then turned the router off for 15 seconds (for a fresh reboot) then when i had to set everything up again i got all my computers on the router and im able to add more without running into that same problem once again, or for a simpler solution try disconnecting the wireless on the computers and replugging them in.... that works sometimes as well
May 01, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Do not have access to the internet
which windows is installed in ur laptop if its windows vista go to network & sharing center click on manage wireless network remove ur wireless network from the list the add the network again and u will be able to connect wirelessly incase if it does work with that go to the device manager & uninstall the wireless network adeptor then click on scan for hardware changes onces the driver is reinstalled u be able to reconfig ur wireless network easily
Aug 28, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Unsecured network shows up as secure
The person who has the router attached to there computer must enter the IP for the router and you will be able to reset the password to enter the router. If you need Help doing this I can solve this issue with you through my computer.
Hope This Helps
All The Best,
RCF
May 28, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
