Question about Philips 60P8341 60" Rear Projection Television
Philips 60 in. tv
Hey, I have a philips 60 in, when I turn it on the power button blinks but tv will not turn on. It takes a few times of doing this to get it to stay on. After getting the tv on it stays on for anywhere from ten minutes to an hour and then shuts itself off again. Do you have any ideas on what might be wrong with it and or how to fix?
No dont
Posted on Jul 08, 2008
My phillips 60 inch tv 60pl9200d/37 wont turn on the power button flashes blue
Look in the manual. (Page 4)
Turn the TV on From main supply: Ensure that the main supply is turned on. A blue indicator light on the front of the TV lights up. When the TV is turned on by the main supply, the blue indicator light will blink for 45 seconds. This is the lamp's start-up period. When the light goes off, press the POWER button on the remote control or power switch. Press POWER to turn on the TV.
http://www.retrevo.com/support/Philips-60PL9200D-TVs-manual/id/633ag423/t/2/
Telephone number Philips Customer Care Center: 1-888-PHILIPS (744-5477)
Aug 14, 2011 | Philips 60PL9200D Projection Televisions
TV Won't turn on - On/Off button blinks 6 times then repeats
Power supply board has dead capacitors.If you know how to solder?Replace these capacitors that bulge up,puff up or burst open.Should get the power back.
Or replaced a whole power refurbish power supply buy it at Shopjimmy.com,Ebay.com.
If you are not skilled take it in for repair $150.00+ labor rough estimate
Jul 01, 2010 | Philips 60PP9202 60" Rear Projection...
My Philips 60P8341 TV would not turn off. Turned off power strip and tv would not turn on. Waited an hour and tv turned back on, then tv turned off and power button blinks and then theres a click the...
Your convergence board is faulty. Common problem for this model. Pull the back cover off and look to the north and look for a jumper jack [1516 i beleive] and pull this off. [TV unplugged of course] Now plug in the tv and power up...If the picture is distorted you have bad convergence ICs. If picture is good...you may a bad audio IC. You can do this, just be dang careful and good luck to you!
Nov 25, 2009 | Philips 60P8341 60" Rear Projection...
Set will not power on.. Blinks red LED 8 times
It's a power supply related problem.
The flashing 8 times is a trouble code. A Service Manual for your TV model will have the info on the codes. It could be a bad capacitor or a transformer on the power supply board.If you have some electronic experience, you can find a Service Manual for your TV over the internet. Cost about under $20.
Jul 30, 2009 | Philips 32PFL5322D Television
Red power light blinks 9 times
Either a missing cable or you shorted the chips when you soldered them back into the TV.
May 29, 2009 | Philips 60PP9363 60" Rear Projection...
Philips projection tv
replace voltage regulator and serounding capasitors, check the hv swiching transistor and serounding diods.
thanks,
daniel.
Jan 13, 2009 | Philips 60P8341 60" Rear Projection...
Question about Philips 60P8341 projection tv
Vertical protection is what the two error code is. You can get a new Vertical output IC at the following link just leave them a email indicating your model number and what youre needing. They respond quickly.
http://servicemanuals.vstore.ca/
Sep 22, 2008 | Philips 60P8341 60" Rear Projection...
Philips 50p8342 problem
I have tv proyection philips model 50p8342, it is blinking red color on the power switch botton four times and then pause then another four time continuosly.
Aug 15, 2008 | Philips 60P8341 60" Rear Projection...
Philips HDTV does not turn on
I would check the line coil and horizontal and low voltage regulator transistors.
Jan 21, 2008 | Philips 60PP9202 60" Rear Projection...
look for imperfect contacts on the inside main board.
Jan 21, 2008 | JVC AV-27230 27" TV
Philips 60P8341 60" Rear Projection Television Logo
124 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
