Question about Saeco V'spresso
Reduced amt of brewed coffee dispensed into cup; water appearing to flow from underneath coffeemaker at the same time.
  • 1,089 Answers
Hi
I am sorry to say but that is probably your boiler leaking. Usual cause is water hardness set too low (anything lower than 4), which leds to not descaling enough to remove deposits that cause the boiler to leak. Your only remedy is to replace the boiler.
Posted on Dec 31, 2010
Owned this coffee maker for 14 mos. At first you'd turn the brew switch and the brew cycle would start. Over time you'd turn the brew switch and it would take awhile. Now who knows when it will start.
Over time, Calcium will deposit on the tubes and containers which get in touch with water. Try Decalcifying with Designated Products.
Usually, you do this by diluting the product, fill up the water reservoir, and cycle on the machine, without cofee of course,
Pour out the water. It will probably look troubled.
If the water does not start percolating, just let the water reservoir stand with the decalcification product for about 30 mins. don't leave it in overnight, because these products are slightly caustic to remove the Calcium, but it could damage parts if left in the machine overnight.
Repeat the process until the water starts running faster.
don't forget to rinse with regular water. 2 Cycles rinsing should suffice.
See manual for suggested products or just use 1/4 cup of Vinegar diluted with Water. .
Jun 19, 2015 | Cuisinart DCC-2000 Coffee-on-Demand 12-cup...
My keurig will not dispense right amt of water
Try brewing a cup without a K-cup in it on the largest cup button (will brew just hot water). This will help clean it out in the event it is clogged. If that doesn't work, completely remove the K-cup holder where the needles are (careful not to get **** ) by pushing up from the bottom and rinse using hot water, preferably with a sink sprayer if you have one. Sometimes the needle can get clogged, especially if you ever use the hot cocoa K-cups, so the manufacturer recommends brewing a "blank" cup of just hot water after each hot cocoa K-cup brewed. Hope that helps...Best of luck!
Jan 02, 2010 | Keurig Special Edition B60 Coffee Maker
It is stuck on large and does not brew
My keurig did the exact same thing. Stuck on large and wasn't pulling water into coffee maker so it would only dispense a small amt of coffee. I turned it off for about 10 mins. Emptied the reservoir and filled it half way with white vinegar. Ran several cups through and after 2nd brew it ran faster and after the 3rd run with vinegar all the size cup lights came back on. It is working great now. Just empty reservoir with remaining vinegar and rinse. Run a couple cycles of plain water through the coffee maker to rinse out vinegar. I hope this works for you.
Dec 27, 2009 | Keurig B60 Coffee Maker
No coffe in the cup
Hi
I would say you have a stripped thumb screw. It is in the top left side of the brew unit and holds the filter screen in. If it is stripped there will be water or coffee in the pocket on top left of the brew unit.
Dec 26, 2009 | Gaggia Syncrony Compact Coffee...
Our Keurig only dispenses a partial cup of coffee. We descaled as recommended and did the paperclip cleaning of the need,es and no improvement. When we press brew, it draws an appropriate amount of water...
Keurig coffee maker dispenses only part of a cup (about 5 ounces) after brewng one cup. Running a second clear cup (w/o K-cup) shows coffee grounds in cup of clear water. the maker will then brew a full cup of coffee. It appears that the top pin is too long and goes into the coffee after it punches through the top of the K-cup. Some of the gorunds appear to get stuck in the top pin.
Nov 10, 2009 | Keurig Platinum B70 Coffee Maker
Not brewing. Add water and coffee, switch to the brew selection and the water/coffee does not flow. The machine heat ups and starts processing noise.
Make sure the lid is on the carafe.
Make sure you are not using a paper filter and a gold tone filter at the same time.
Make sure the carafe lid is down all the way and that the center knob of the carafe lid is making contact with the spring at the bottom of the filter basket.
If the above conditions have been met, then decalcify your coffeemaker by running 1/3 carafe worth of vinegar and 2/3 carafe worth of water through your coffeemaker - use the self-clean button to do this - will take about 35 minutes.
Aug 30, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
I dont know how to make coffee
Water Level ////Amount of Ground Coffee
42 Cups --2 ½ Cups
36 Cups-- 2 Cups
30 Cups- -1 ¾ Cups
28 Cups --1 2/3 Cups
24 Cups --1 ½ Cups
22 Cups --1 ½ Cups
18 Cups-- 1 ¼ Cups
12 Cups --1 Cup
1. With basket and stem removed, fill coffeemaker with COLD water to desired level using the cup markings on inside of coffeemaker as a guide. Do not make less than 12 or more than maximum capacity of the coffeemaker at one time.
2. Place stem into heating unit in bottom of coffeemaker, then put basket on stem. Spread the recommended amount of ground coffee evenly into the basket. See chart. Use regular electric perk grind coffee or coffee ground for all coffeemakers. Do not use drip or finely ground coffee as flooding of the basket can occur.
3. Turn cover in place on coffeemaker. To reduce coffee spills, especially if coffeemaker is tipped over, make sure cover has been turned clockwise until it is completely secured in the handle slots. (Note the arrows on the cover for correct turning.) The cover temporarily reduces coffee spilage if coffeemaker is tipped over, so care should be used when moving coffeemaker.
4. Place coffeemaker on a dry, level surface. Attach cord to coffeemaker and plug into a 120 volt AC electrical outlet ONLY.
5. Coffeemaker stops perking automatically. (Each cup of coffee requires about 1 minute brewing time) Serving light will glow when coffee is ready. Before serving, use a hot pad to remove cover, then carefully remove stem and basket from coffeemaker as coffee and grounds are HOT. If not removed, bitter oils from the coffee grounds will drip into coffee. Replace the cover making sure it is completely secured into the handle slots.
6. Coffee will remain at serving temperature as long as coffeemaker is connected to outlet. (if you have an insulated coffeemaker, the sealed-air insulation will keep coffee hot for up to two hours without electricity.) To serve, place cup and saucer under faucet and press down on handle. If a continuous flow is desired to fill a carafe, lift handle straight up until it locks into open position. When approximately one cup of coffee remains in coffeemaker, disconnect from outlet.
TO MAKE MORE COFFEE: If another pot of coffee is desired right away, partially fill coffeemaker with cold water to reset the thermostat. Pour out water, refill with cold water and repeat steps 1-6.
TO HEAT WATER FOR INSTANT BEVERAGES: Plain water may be heated in your coffeemaker for use with instant beverages. Simply fill the clean coffeemaker with cold water to the desired cup level, and then place the stem and empty coffee basket in place. Using the stem and empty basket will heat the water more uniformly. Secure cover in place and plug coffeemaker in. Heat water until perking stops and serving light comes on. Unplug coffeemaker when less than 1 cup remains. Other than making coffee or heating water, no other liquid should be heated in coffeemaker as damage to heating unit can occur.
When coffeemaker is used to heat water only, the metal inside will discolor which is normal and does not affect performance or the water heated in the coffeemaker. Refer to Special Cleaning Instructions in this manual for removing discoloration as well as mineral deposits, which form inside the coffeemaker when heating water. If these deposits are not removed, pitting of the metal inside may occur and result in damage to coffeemaker. Refer to the cleaning your coffeemaker section
Apr 14, 2009 | West Bend 58030 Coffee Maker
Condensation- Cuisinart coffeemaker DGB-300
The condensation is normal, not just with this Cuisinart Grind n Brew, but with ALL Cuisinart Grind n Brews - because of this, you will really need to clean it after every use if you want the grinder portion to last long. As far as the bean amt - Cuisinart bases it's reccomendations on a smaller-than-normal coffee cup size of 5 ozs or so. Plus, the condensation, as you mentioned, will prevent a certain portion of the grinds from flowing to the brew/filter basket. Add more beans or less water to make a stronger cup.
-Tha Mp3 Doctor (also loves Cuisinart)
Mar 16, 2009 | Cuisinart DGB-300 Coffee Maker
Coffee Makers & Espresso Machines Logo
80 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
