Question about Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only
My chuck is stuck - Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only
  • 25 Answers
Your chuck is held onto the motor shaft by a screw located inside the chuck. This screw has loosened and requires tightening. This screw has reverse threads and in order to tighten it, you need to turn the screw in the opposite direction or in oither words, in the reverse direction.
Posted on Jul 26, 2008
Ryobi 18v drill keyless chuck stuck
Try holding the bit in a vice and gently tap the chuck off of the bit and see it it releases the pressure on the jaws.
Jun 20, 2012 | Ryobi 18v Cordless Drill - P206 18 Volt V
Chuck on my drill is stuck open and I cannot close it to put in a new bit
If the chuck is stuck open and you cant "muscle" it closed something is probably jammed up in there and it needs to be replaced. Chucks take a good share of the abuse on power tools and most manufactuers consider them a "common wear item" like brake pads or Tires on your car. A chuck is fairly simple to replace if your drill stuck open and they are commonly replaced on the higher end "Industrial Grade" Power Tools like DeWalt and Milwaukee.
Looking at the Make and Model of your drill it would probably be easiest and most cost effective to just replace the entire drill. If you tried to replace the chuck and found a chuck that will fit your tool it may cost you anywhere from $25 - $40. For Around $40 you can purchase a new drill with a fresh battery.
Oct 09, 2010 | Black & Decker CD9600SBGB 9.6 Volt Drill...
I have a drill bit stuck in my drill and I can not get it out of the chuck How can it be released from the chuck that I can change to an other drill bit.
By stuck do you mean that you can not release the chuck? if so then you can use 2 channel lock pliers to grip the chuck and the base to break it free. i have done the same on a keyed chuck and a keyless chuck .
Oct 03, 2010 | Garden
A bit is stuck in the chuck of my Bosch drill
Hello. Wrap a towel around the chuck and use a pipe wrench or a pair of channel locks to put a little force on the chuck. J.
Jul 19, 2010 | Bosch Drills
Bosch keyless chuck stuck
Make sure you try it in both directions.
Apr 18, 2010 | Black & Decker 3/8" Variable Speed...
Bit tighten stuck open
If you mean the chuck jaws seem stuck open, spray around them with some penetrating oil or spray like WD-40, RP-7 or similar and let sit for a couple hours... Then you can tap around the chuck body with a light hammer or spanner etc... just lightly tap... Then if the chuck has an arbor lock to prevcent it from spinning, be sure that is engaged then try to release the chuck jaws. Sounds like they are stuck open through tight friction or rusting on the inside edges (that you dont see). Be careful not to leave them in the fully open position when stored as this is exactly what can happen!
Mar 31, 2010 | Makita 6304LR 1/2" Chuck Electric Drills
Bit is stuck. chuck wont open. turns but makes a
the chuck is broken inside if clicking. Ace and True Value stores sell chuck replacements
Mar 04, 2010 | Black & Decker BD12PSK 12-Volt Smart...
Cordless Drill, Keyless Chuck stuck in full open position.
if chuck is wide open ,look down inside there should be an allen screw or bolt at the bottom of the chuck it should undo anti clocwise and the chuck comes off
Aug 18, 2009 | Dewalt DW056 18 Volt Cordless Impact...
My rattle gun 18V LXT Impact Driver BTD141 has a double ended Philips stuck in it? how do i get it out?
There are a couple of ways to try to free the bit from the drill chuck. But slow and steady is the key, don't hit anything too hard, so as to not damage the chuck in the process, nor break off the bit in the chuck.
You'll need to put the bit into a bench vise and reverse the drill slowly and carefully. Make sure the bit is tightly secured in the vise and that the drill won't spin your hand around and slam it into the bench when you pull the trigger.
As a last resort, you can try tapping the bit sideways, to get it loose. With chuck opened up all the way possible, gently tap the bit sideways. This should also free the bit, but be very careful not to snap the bit off in the chuck, or you'll have a worse situation trying to get a broken bit out of the chuck.
If none of these work, you can attempt to secure the stuck bit in the bench vise and try to tap the drill chuck using a hammer and a flat brass bar resting against the drill chuck, so you don't damage the chuck. Just tap the brass bar to drive the chuck free of the stuck bit. You have to watch the bit in the vise to make certain it's not slipping and that the chuck is getting free.
Hope you find this Very Helful and best regards!
Jul 12, 2009 | Drills
Stuck chuck
open the chuck all the way, insde there may be a screw in the bottom it's lefthand thread turn it clockwise to remove, the chuck is also threaded, right hand thread. close the jaws on the short end of an allen wrench and strike the long end with a hammer to break it free
Apr 01, 2009 | Makita Usa Inc No.8390DWPE 18V Crdls...
Dewalt DW056 18 Volt Cordless Impact Driver - 1/4" Drive Hex Shank (Battery Charger and Case Not Included) - Tool Only Logo
273 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
