Question about Verbatim Acclaim 750GB Portable USB 2.0 Hard Drive
Hooked up my portable hard drive (750GB Acclaim) no problems except my computer would not let me register it (I tried to change my norton settings but nothing I did worked). I installed all the nero and usb turbo stuff and backed up all my filles using nero and also dragged my folders to the hard drive too. My computer kept giving me warnings about low disc space so I removed the nero/turbo stuff thinking I could just re-install after I did a whole system reboot of my computer and get rid of a lot of stuff I don't need - (I don't know what files I need and which I don't so I was thinking doing a whole system restart would be the way to go). Only problem is my computer won't read the portable drive when I plug it in. I went through some steps that my computer took me through and used device manager to locate the drive and it prompted me to remove it - I did but it didn't help.) Sent Verbatim an email but wonder if there is a speedier way of getting help.
3 Suggested Answers
SOURCE: I bought a Verbatim Clon USB Portable HardDrive to
You have to partition your Verbatim Drive to work on a Mac. Go to Macintosh HD / Applications / Utilities / Disk Utility. When in Disk Utility select the 232.9 GB SAMSUNG HM250HI Media to the left.
Posted on Jan 16, 2010
  • 1623 Answers
SOURCE: USB portable Verbatim Acclaim 320gb
the power requirements of the hard drive are too much to run it from the laptop, remove any other usb devices and you will find that it works
Posted on Mar 16, 2011
My Samsung M2 PORTABLE 750GB USB20 HARD DRIVE giveing me message says thei is a write delayed
This happens when there is a disconnect of the usb interface or if the drive stops spinning. You either have a failing hard drive a failing usb enclosure or a usb issue with your computer. First thing is to plug the drive in to another computer to determine if this is a usb issue. If the problem persists then it is the circuitry in the enclosure or the hard drive. You may be able to install the drive into a new enclosure and if it works that was the problem, if not than you have a failing hard drive.
Jun 22, 2013 | Samsung M2 PORTABLE 320GB USB20 HARD DRIVE...
Reset external hd wd750
A bit vague.Can you be more specific.To give
an informed solution I need more information. Factory settings? Formatting the drive will remove all the data from the drive, Is that what you mean by"FACTORY SETTINGS"?
Nov 04, 2012 | Western Digital My Passport Essential...
I have a 320 gb acclaim portable hard drive. My mac doesn't read it, the first time I plugged it the lap asked me if I wished to format it and I said yes. Now it doesn't read it, what can I
You formatted the hard drive on your laptop in NTFS and the MAC cannot read and write to this formatted NTFS hard drive.
THE FIX
Format the hard drive using your laptop BUT this time format it in FAT32.
The MAC can read and write to a FAT32 formatted hard disk, so now you can exchange data between the MAC and the Windows laptop.
Jun 10, 2012 | Verbatim 320GB Acclaim USB Portable Har
My mac recognizes the verbatim hard drive, then says it was unplugged incorrectly, then recognizes it, then says it was unplugged incorrectly, etc. in a continuous loop. I have purchased two of these hard...
Make sure that you are connected to a usb port on your computer and not thru a usb hub. Also try a different port on your computer. It is unlikely that two hard drives would be bad, but I would try them on another computer. Thanks for using fixya
May 26, 2011 | Verbatim Acclaim 750GB Portable USB 2.0...
I registered my seagate GOFLEX 750G portable drive on my MAC, but it does not work on my school MAC and pc, even after I registered, please help me
You dont need to register the product to use it. Please make sure you have admin privileges at both computer in order to install new hardware.
Mar 22, 2011 | Seagate 750GB FREEAGENT SATA/USB 2.0 750...
Im looking for the driver of Verbatim turbo USB 2.0
The drivers for your hard drive can b downloaded from the below link provided.
http://www.verbatim.com.sg/en_SG/products/hard-drives/2-5-hard-drives/page/1
Jan 08, 2011 | Verbatim 97164 Drive, USB, 320GB, 2.5 in.,...
I canĀ“t see the portable hard drive unit in my pc
First, try to connect it to a different computer, to see if it can be read on _any_ computer at all.
Second, check the warranty-status of the unit; if the warranty still is valid, Verbatim will replace the hardware (but will NOT make any attempts to 'recover' your files).
Third, an external drive has two major components -- the disk-drive and the USB-to-disk-drive adapter. Open the enclosure, and remove the disk-drive, and connect it as a 'slave' disk-drive in a desktop computer, to see if that interface hardware is the problem.
Feb 18, 2009 | Verbatim External, USB 2.0, 750GB...
Verbatim Acclaim 750GB Portable USB 2.0 Hard Drive Logo
Top Verbatim Computers & Internet Experts
Martin Murray
Arora Singh
Arora Singh
Computer Links
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
