Question about LG WM-2277HW Front Load Washer
In the digital panel "de"
  • 1,772 Answers
In the digital panel moz-screenshot-1.pngmoz-screenshot-2.pngIn the digital panel barrettdenco.jpg
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Dec 30, 2010
Kenmore elite quiet pak2 washer-in the time remaining/de l at display a y, digital numbers are flashing and sometimes read08,8:88,0:88 and when I choose a setting and press start the machine locks the
Sounds like the control panel is defective or you have a stuck key on the unit. Check the control panel for any obvious cracks, damaged, etc. if all else fails, you'll have to replace the control panel.
Jan 09, 2015 | Kenmore Washing Machines
Need instruction book for Cuisinart Single Serve Brewing System Model # CUISS-700
Here are the instructions to de-scale your Cuisinart SS-700, taken directly from the unit's manual, available here (www.cuisinart.com/share/pdf/manuals/ss-700.pdf):
1. Empty the reservoir.
2. Disable the AUTO OFF and OFF TIME features.
3. Making sure there is no K-Cup in the brewing chamber, fill the reservoir with 60 oz. of undiluted white vinegar.
4. Place a large mug on the drip tray and run a Hot Water cycle. Select the 12 oz. brew size. Discard contents of mug.
5. Repeat the hot water process until ADD WATER is displayed on the control panel and the reservoir lights will flash.
6. Let the Brewer stand for at least four hours while still on.
7. Rinse the water reservoir thoroughly and fill with fresh water.
8. Run another Hot Water cycle. Discard contents of large mug.
9. Repeat hot water process until ADD WATER is displayed on the control panel and the reservoir lights will flash.
10. You may need to perform additional Hot Water cycles if you detect any residual vinegar taste.
Note: If DE-SCALE is still displayed on the control panel after completing the procedure, repeat the de-scaling procedure above.
If you found this solution helpful, please leave a positive rating!
Sep 17, 2012 | Cuisinart SS700 SINGLE SERVE BREWING...
Khhc2090s trouble
The sensor errors are probably just from opening the door and interrupting the sensor cook cycle.
By the way, you should always press "Stop" before opening the door of a running microwave. Otherwise, the door switches will prematurely fail.
I would first check the door switches and their mounts. See this help file.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can also download manuals, installations info, and parts lists here.
dee77f7.jpgWe're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Nov 25, 2011 | KitchenAid Microwave Ovens
I have an Electrolux Washer machine model EWT959 and it currently problem is:- 1. "Choose Program & Start" 2. Once "Start/Pause" button pressed to start the wash 3. The message on...
It doesn't think the lid is actually closed indicating that there is a problem either with the lid lock or the lid locked sensor requiring a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Oct 06, 2011 | Electrolux Washing Machines
LG WM1814CW Front load Washer dE error? I get the dE error everytime I push the start button. The door wont open or close. I can hear the latch moving inside but nothing will happen. The "Door...
A dE error code indicates that the washer door was unable to lock. This can normally be resolved by performing a simple reset on the washing machine.
How to reset the washing machine:
1.
Press POWER to turn the washer off.
2.
Unplug the washer from the power outlet or turn the circuit breaker to the unit off.
3.
With the power disabled, press and hold the START/PAUSE button for 5 seconds.
4.
Plug the washer back in, or turn the circuit breaker back on.
5.
For more information about how to reset your specific model, please refer to the owner's manual.
Press in on the door firmly and select any cycle. The washer door should lock, and the cycle should begin without an error code appearing on the display. If the cycle does not begin and the dE code appears again, repair service is required.
Feb 03, 2018 | LG WM1814CW
Aquarius wf620 super silent washer has "test" in
  • to de- activate press and hold the start/cancel button untill all the lights come on.
  • then press and hold the on/off and start/cancel buttons together until d-off appears
that should do it and if not get back to me, there is another way you can do it.
Jul 11, 2011 | Hotpoint Aquarius WF220 Front Load Washer
The digital display shows a sign c-on and 00:02. It doesn't start any of the programmes. Don't know what to do. Please help.
the fault is 4rm the panel or u switch the washer of 4 abt 24hours 4 the washer 2 reset itself again or call ur sevice provider 4 troublrshooting
Jun 29, 2011 | Washing Machines
Our machine's digital display reads 'dE' seconds after pressing start and nothing isour machine's digital display reads 'dE' seconds after pressing start and nothing is happening except for an awful b
The dE error means that the door switch has failed to "make" Either the door is not closed all the way, or the door switch needs to be replaced or adjusted.
Apr 18, 2009 | LG WM2487H Front Load Washer
LG WM-2277HW Front Load Washer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
