Question about Sony Cyber-Shot DSC-F717 Digital Camera
My name is Jeremy. I have a two-fold problem. First of all I got an Memory Stick Pro Duo. Will that work the same as the MS Pro? Secondly, My pictures are looking yellowish through the lcd display, but they turn out ok. The problem is I take 5 pictures of everything because they all look like the lighting settings on the side of the F-717, WHT BAL, and still no change. Any suggestions on either would be great, the first is essential. Thank you.
  • 455 Answers
Hi Jeremy,
The DSC-F717 is compatible with the Memory Stick Duo, Memory Stick PRO Duo and Mark 2 Memory Stick PRO Duo. A dedicated Memory Stick Adaptor (MSAC-M2) must be attached to use the Memory Stick Duo media with the Camera. The Memory Stick PRO Duo and Memory Stick Duo are same except the size limitation in MS Duo. Duo's size limits up to 128 MB. This Camera is compatible up to 2GB of Memory.
The Yellowish tint on the LCD screen may be the issue with the Image Sensor in the Camera. The Camera was having issue with it's CCD Image Sensor Device. This can be identified by capturing new images in the Camera. If you're able to view the previous images and Menu icons normally in the Camera, then the issue may be with it's CCD. You may try resetting the Camera to check if the issue can be resolved. (The RESET button is located inside the Battery / Memory Stick cover. To reset the camera just press the RESET button using a sharp-pointed object.)
If the issue persists, service may be required. You may also check for the free service offered for the U.S model Camera if it is having the Focus issue. Click here for more details to see if the issue is affected with this model.
Thanks for using FixYa.
Have a great New Year!!
Posted on Dec 31, 2010
My computer (HP DV 5200TX) is not reading the memory stick duo. What steps can I try?
I didn't know that HP built computers with card slots that support MS pro duo. Try getting a mini-usb cable, leaving the card in your psp, and plug the PSP into your computer. Make sure you set the PSP to connect using the USB first, though.
Feb 11, 2011 | Sony 1GB Memory Stick PRO Duo Memory Card
PSP3004 screen flickers after using a fake duo pro memory stick
its the memory stick.
go to staples and get a 4gb ms duo, they are $19.99 there, put CFW on memory stick and it should stop flickering
May 07, 2010 | Sony PlayStation Portable (PSP) Console
Corrupted
Could this be,redone and have the Stick and the psp on at the same time?
Feb 15, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Have Sony CyberShot DSC-F707 Sony Memory Stick Duo Adaptor and Sony Memory Stick Pro Duo 4gb When installed get C:1301 error
In DSCT1 Camera, the C:13:01 error message indicates a Self diagnostic message. Each of these codes indicates the symptoms and resolutions of the Camera. In C:13:01, the issue is with the Memory Stick being used in the Camera.
The Symptoms are:
Memory Stick Pro Duo 4GB is not compatible with the DSCF707 Camera. Maximum capacity supported by the Camera is up to 128MB. Please try using a MS with 128 MB and check if it works. A dedicated adapter (MSAC-M2) must be attached to use Memory Stick Duo or MagicGate Memory Stick Duo media.
Thanks.
KenSolutions
FixYa
Dec 24, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Sony memory stick PRO Duo is not working
try formatting it on a pc in FAT file system or run a deep scandisk
May 03, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
MY PROBLEM IS THAT MY LAPTOP HAS WINDOW VISTA SYSTEM AND I CANNOT LOAD MY PHOTOS FROM MY SONY CYBERSHOT DSC P73. I NEED THE PROGRAM OR WHAT I NEED TO DO?
To make things easier, you should buy a card reader. There are different types.
MS Pro Card Reader - Is ONLY for the sony memory cards
Multi Card Reader - Will read sD, xD, Ms Pro Duo, Ms Pro, Compact Flash, Smart Media, etc.
Sony has a new memory stick out called the memory stick pro duo. Your P73 does not take this. The P73 takes the Memory Stick Pro. Which is a longer stick. You can go out to best buy or ritz camera and buy a card reader (Memory Stick Pro) and stick your memory card into the card reader and stick that into your USB port on your computer. Since it is USB, this will require NO SOFTWARE.
Your camera came out in 2004. Vista did not come out until early 2007. A lot of software does not work with vista.
Mar 29, 2009 | Sony Cyber-Shot DSC-P73 Digital Camera
Unable to upload pictures from memory card to computer
Most laptops that have a memory card reader will only read these types of cards, without needing an adaptor: -SD card -MMC card -Sony Memory Stick or Memory Stick Pro cards -XD cards
However, you have a MS Pro Duo card, although it fits into the card reader slot, the card is a lot thinner than what's expected, so the laptop won't be able to read it.
You need to put the Pro Duo card into the stanard size MS Pro caard adaptor. See attached image.
Hope this helps.
Jan 10, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Memoy stick pro dou and my p900
SE P900 does not support memory stick pro duo. it' s only support MEMORY STICK DUO (w/o PRO). i have the same problem too. my p900 only live with 32MB MS DUO and there are no more MS DUO in my city (even SE's service center)
if you wanna use your MS DUO PRO, then you'll need to upgade to P990i or P1i. that's much better then P900i (newer OS, more ROM, new keypad, plus WiFi) :D
Dec 24, 2008 | Sony Ericsson P900
Format error
If Duo Pro got hardware problem, then it can not be fixed and you can't retieve data on it. Regarding new memory stick, camera will check it and let you know about format it or not.
Jul 31, 2008 | Cameras
Sony Cyber-Shot DSC-F717 Digital Camera Logo
41 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
