Question about Whirlpool Heating & Cooling
I have a Whirlpool quiet miser AC. Do I have to open the vent when it is on heat mode?
2 Suggested Answers
  • 587 Answers
SOURCE: freezes over
If the coil is freezing up it's either a dirty filter, coil or low on refrigerant. Unless somebody went in and changed the fan speed to a lower speed.
Posted on Apr 20, 2009
Hi there, I have a Whirlpool quiet miser heat and air unit (220) just quit working
Check the drain line and look for a safety switch. Need to shop vac the drain line and possibly the float switch cup. Hope this helps!!
Sep 17, 2017 | Whirlpool Heating & Cooling
Ac exhaust fan
Yes for dehumidifier, no for heat mode. In dehumidifier mode all the unit does is takes air in, runs it through the evaporator (cold) coil and the back through the condenser (warm) coil discharging dry, slightly warmer air back into the room. In heating mode however if you don't vent the exhaust there will be no heat produced. Warm air will come out the top but cold air will also come out the exhaust (essentially, in heating mode all it does is operates as an air conditioner in reverse. Hope this helps.
Jan 11, 2014 | Whirlpool ACP102PS Portable Air...
Quiet partner whirlpool III gold reset
TRY A RESET CODE
Press the "Sani Rinse," "Heated Dry," "Sani Rinse" and "Heated Dry" buttons on the dishwasher's electronic control panel in quick succession to put the appliance in diagnostic mode.
Close the dishwasher door and engage the door latch.
Wait 10 seconds before pressing the "Cancel" button to reset the dishwasher.
Dec 18, 2013 | Whirlpool Gold Dishwasher with Quiet...
Automatic Temp/ Heat works no A/C
make sure the a/c clutch working and the line is cold , let me know .
Nov 28, 2011 | 2001 Mercury Grand Marquis
Dryer not heating.
First clean out the exhaust vent tubing entirely and then try it. It may heat up very hot if thoroughly cleaned out. A moister sensor detects any lint build up and put the burner into a check mode that prevents home fires in the exhaust vents
Jul 08, 2010 | Whirlpool Dryers
Freezes over
Apr 20, 2009 | Heating & Cooling
Whirlpool Gas Dryer, LGR5636EQ2, timer not moving on Auto (DryMis
If that is a 3 wire gas assembly then the timer is screwed.The orange wire when removed from the mix will make the thing advance. The trouble is in the timer. If that is a 2 wire gas operator you need to change the high limit and open up the outside vent. My opinion.
Nov 14, 2008 | Whirlpool GGQ8831L Gas Dryer
Whirlpool Quiet Partner 980
clean light blinkin???? ry pushing the sanirinse-heated dry--sanirinse--heated dry. tha tshould put in diagnostic mode, there also should be a trouble shooter underthe lower acess panel
Apr 09, 2008 | Dishwashers
Dryer not heating
Either the vent is plugged and the moisture is not escaping, or the element is no good. the failure mode for a dryer heating element is to open circuit.
Dec 14, 2007 | Whirlpool LER4634PQ Electric Dryer
Heating & Cooling Logo
114 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
