Question about Motorola Talkabout 2-Way Radios
Motorola Talkabout I'm trying to figure out how to set the channel and frequency for a much older Talkabout from 1999. It resembles the Talkabout 200 from 2000 but it doesn't have a screen at all and it is blue. Just says Talkabout on it. It has an on button, push to talk button, monitor button and the volume control. It's like brand new but just can't find my directions for it.
  • 1 more comment
  • trailrunner Jul 10, 2008
    FCC ID AZ489FT4818
    I also would like to know how to change channels?
  • louisfulton Aug 10, 2008
    Have the same radios. I figured out how to change channels for the main channels #'s 1-15, but not the sub-channels, and I have 1 on 10-32 and another on 10-33, they will not communicate to each other but give an occasional burst of noise when keying the mike.
    To change the channel, hold the red on-off button depressed when starting for a few seconds and then press the "Talk" button, it will cycle from channels 1-15, but when you press the monitor button it will also announce the sub-channel but I havent figured out how to adjust
  • Anonymous Apr 09, 2009
    cant get them on the same frequency
    Sergeant:
  • 250 Answers
Hello trailrunner,
Back when Family Radios first came out a number of manufacturers came out with both standard 14 channel radios and scaled-down single channel radios designed as entry level offerings. My guess is the radio you have is probably a single channel unit based on what you describe. It probably operates on FRS channel 1 (462.5625 MHz).
If you post the model number and FCC ID number (which should be located on a sticker on the back of the radio) I might be able to give you some more information.
Best Regards,
Ken
"Go Ahead. Use Us."
Posted on Jul 09, 2008
What frequency does my motorola talkabout have
If they're all set to the same "Channel" and "Code" you will be able to talk between them.
Apr 15, 2014 | Motorola Talkabout T5300 (14 Channels)...
How do I use my T4500 Motorola Talkabout?
Here is a link to the user guide for the T4500 radio: http://www.giantintl.com/radiopdfs/manuals/US/T4500.pdf
A few tips: Set your frequencies to be the same on both radios. Put your code and any special features on Zero or Off, until you feel comfortable with the use of the radio and are ready to turn them on.
Best regards.
Oct 28, 2012 | Motorola Talkabout T4500 (7 Channels)...
Is motorola talkabout work on free frequency?
In the USA the TalkAbout radios operate on FRS (family radio service) frequencies which do not require a license. Not certain of the laws in other countries.
Best regards.
Nov 02, 2011 | Motorola Talkabout T5720 (7 Channels)...
I have a set of T4525s and another set of T4508 Can they communicate with each other?
Hi
Absolutely no because
MOTOROLA T4508  frequency range: 409.7500-409.9875MHz
MOTOROLA T4525s frequency range: 462.5625-462.7250MHz
Aug 30, 2010 | Motorola Talkabout T4500 (7 Channels)...
Are motorola talkabout t6210 and talkabout 200 compatable. I have the eavesdrop reducer turned off on the t6210 but the transmissions are garbled when recieved by the talkabout 200.
Yes, they should be compatible. You are correct in shutting off your eaves drop reducer. You might also check to see you have your interference eliminator code set to zero (off). We have been unable to find a good online source for a user guide for the T200, but if memory serves, they do not have "code". Here is a link to the very similar T280 guide: http://www.giantintl.com/ContentManage/manuals/Moto/T280_User_Manual.pdf
And here is a link to the T6210 user guide http://www.giantintl.com/ContentManage/manuals/Moto/T6200_User_Manual_E.pdf
Between the two radios there should be 14 frequencies in common. If you continue to have difficulties you might check to see if your batteries are good and/or fully charged. This also can interfere with good communications.
Best regards.
Aug 22, 2010 | Motorola Talkabout T6210 (14 Channels)...
Require Frequencies for CTCSS codes for Motorola GP 2000
check this link at page 21 or see below
CTCSS PRIVACY CODES FREQUENCY CHART (Hz) Code Freq. Code Freq. Code Freq. Code Freq. Code Freq. 1 67.0 9 91.5 17 118.8 25 156.7 33 210.7 2 71.9 10 94.8 18 123.0 26 162.2 34 218.1 3 74.4 11 97.4 19 127.3 27 167.9 35 225.7 4 77.0 12 100.0 20 131.8 28 173.8 36 233.6 5 79.7 13 103.5 21 136.5 29 179.9 37 241.8 6 82.5 14 107.2 22 141.3 30 186.2 38 250.3 7 85.4 15 110.9 23 146.2 31 192.8 8 88.5 16 114.8 24 151.4 32 203.5 * Channel 8,9 and 10 are designated Canadian Marine Frequencies * Channels 8~14 are low-power FRS license free channels Note: Privacy codes can be programmed for use on Channels 1~22 only
Feb 01, 2010 | Motorola GP300 Compatible 2 Way Radio...
Can Motorola TA200/T5622 work with newer T5000?
A 22 channel transceiver is an American system call FRS/GMRS radios which are actually illegal in the UK and rest of europe. They use different frequencies completely and will not work together on you other PMR radios.
Mar 15, 2009 | Motorola Talkabout T5720 (7 Channels)...
Motorola Talkabout Basic
I believe you do not need to hold the monitor button when changing channels
Push the talk button till you have the channel you want then push monitor button to accept
Hope this works
Dec 16, 2008 | Motorola Walkie Talkie 2-Way Radio
What will i do to connect Motorola T5720 and T5728
Set both the frequency and the interference eliminator code to match one another. (The big number and the small number) Here is a link to the owners manual: http://www.motorola.com/mdirect/manuals/T56XX_57XX_User%20_Manual_E.pdf
Basic instructions:
Press the Menu Button
The freq number will flash
Use the + or - button to select the frequency.
Press the PTT button to save the channel setting.
To set the code:
Press the menu button until the code starts to flash (the small number)
Press the + or - to select the code.
Press the PTT to save the code setting.
Once you have both radios matching on frequency and code, they should communicate together.
Aug 21, 2008 | Motorola Talkabout T5720 (7 Channels)...
Radio Communications Logo
193 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
