Question about Maytag Dishwashers
My washer leaks. I get a puddle on the right side of the washer after running it? Its old Model MDB7130AWB
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
You have a defective water pump, that is leaking, or their are some rubber hoses, that may have cracked. They are easy repairs, and should not cost you much.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Dec 30, 2010
  • 132 Answers
Check the seal on the inlet valve.
My Kenmore 700 series washer has been leaking water. When the tub is filling with water, water seems to leak along the front bottom edge of the machine in several areas. I'm left with a huge puddle of...
First ck to see if your water pump is leaking. It normally leaks when the machine is running not just filling. Also look at all the attaching rubber hoses under the machine and see if water is leaking down the back right side of the machine and then running around the frame to the front long shot but possible.
Aug 11, 2010 | Kenmore 15864/15862 Top Load Washer
Got a Dewalt 3800 PSI Pressure Washer with 4.0 GPM with a Honda GX 390 gas engine. Tipped it up to roll it out to my truck and got a big puddle of water with what looked like Pump oil in the puddle. Can...
Could very well be. Did you check the oil level and condition of oil? If its too full or if its light brown milky, then water has entered crankcase. Pressure washer pumps cannot stand to ever let run dry. Even a little. Also excessive idling will overheat pump if it doesn't have a thermostatic relief valve that allows some more cool water to enter pump.If it doesn't have one add one. Find your PUMP mfg and model number. IF it's pumping good now and no leaks, quick replacing the seals will save big future repairs. www.pressure-washer-parts.com has lots of info on many pump manufactures. Or get some seals from dewalt.
Aug 11, 2010 | Dewalt 3800 PSI Pressure Washer
Leaking water on spincycle
I have the same problem with my washer. The problem just began a few weeks ago. It is splashing out the front left corner of the tub and running down the inside of washer and then leaking out the bottom of the frame. It is just enough water to be annoying. The washer is about 6 years old.
Model: FAV6800AWW
Serial: 11277017EG
Any ideas??? Help!
Jul 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Hello, I have an ASKO Washer model W6461 and I notcied a puddle (1/2 cup) under the front right part of the machine after running it once. How do i get the service manual for this machine so i can...
you may find the leak coming from the door seal or the soap drawer while it is filling,if you leen the machine back you will find two T20 screws under the front.you can get the book from asko.com.au
Jun 15, 2010 | Asko W6461 Front Load Washer
Puddling on floor during high speed spin cycle
you have a leak in your outlet hose normally caused by rubbing on the drum barrel / repair with tape or replace whole hose but this brand of wASHER ITS VERY HARD TO REPLACE IF DONT KNOW HOW TO
Apr 27, 2010 | Fisher and Paykel GWL11 Top Load Washer
Leaking at front base of washer. Not a stream but a growing puddle as it goes through its cycles. Not sure where to look to find the cause. All water and drain connections are good.
Remove the cabinet to access the water pump. It is attached to the motor front/center.
It will be leaking.
No repair, only replacement will stop the leak.
Remove 2 screws on the right and left sides of the control console. The console is hinged. Fold it to the rear of the machine. Unplug the lid switch connector.
Remove 2 clips holding the back panel to the cabinet base.
Remove the cabinet. Motor and pump are at the bottom center.
May 24, 2009 | Washing Machines
Puddle under 1 yr old washing machine hours after it is finished
Sounds like either the gasket on the inlet is leaking or not tight or the solenoid housing is cracked causing the leak. When its in use the pressure from the line is realased when the solenoid is opened letting water in. When not in use the solenoid stays closed allowing pressure from the line to build causing the gasket to leak. Check your gaskets, and solenoid housing for leaks and then check to make sure your water pressure is not set too high.
Joe
May 19, 2009 | Kenmore 22422 Top Load Washer
Maytag MDB7130AWB dishwasher blows circit breaker.
These have been known to leak water into the door panel. If so the water can cause a short. Your breaker is keeping the machine from lighting up. Check any seals that may have been braeched in the door. Start at the dispencer latch
rubber.
Mar 07, 2009 | Maytag MDB7100AWB Dishwasher
Whirlpool Ultimate Care 2 leak after wash cycle
Hello, you may have a small drip from the pump or a small drip from the hose that goes from the pump to the rear of the cabinet. To make sure you will have to run the unit with the cabinet removed. A local service tech can remove the cabinet quicklyand isolate the leak.
Dec 23, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Dishwashers Logo
59 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
