Question about RIM Blackberry 7100i
Blackberry has device error code 395 and won't come on, what to do? Anyone know how to reset it without having the phone on?
SOURCE: blackberry 7290 reset 373
i read this somewhere and they say "Bang your device ******* the floor a few times"
Posted on Apr 22, 2008
SOURCE: blackberry 7100t
i just got a 7100t and the battery won't charge. i bought it used, so i don't have a manual. my computer says it does not recognize the device. Is there some type of hardward i need to download before it will work? thanks
Posted on Oct 04, 2008
SOURCE: blackberry 7290 device error:373 reset
Hi Anand
Practically speaking i spent 3 hours looking for your solution but nothing much even the BB intelectuals failed .Try these steps out it may resolve the issue and lets hope for the best .
This error : 373 : Device Error means that the Timers are corroupted
1. Remove the battery for at least 5 minute.
2. Make sure u have working SIM card, other wise remove the old SIM.
3.You should receive an Hour glass spinning. Give a few minutes, after that u will see a 507 message on the bb screen, (which means there is no app loaded on the bb)
4.If this dosent work
Use application loader to wipe handheld clean and reinstall base software but do backup your data
And please let me know .
Posted on Apr 04, 2009
label_chick
  • 407 Answers
SOURCE: Blackberry Rim Error: 373.......HELP!!!!
A reset should allow you to turn the device back on.
Hold down ALT+RIGHT SHIFT(CAP)+DELETE simultaneaously for a few seconds.
Posted on Jun 01, 2009
Bajanguru
  • 7752 Answers
SOURCE: JVM Error 545 - Blackberry Pearl 8110
to correct this issue try this method
You need to reflash the OS on the phone you should take the battery out first then connect it via the usb cable to the laptop/pc you are using then open the blackberry desktop manager,click on the apploader, then install the OS.
pls not that when u click on the apploader the pin should be PIN:UNKNOWN you make need to do this like 4x before the pc sees the pin:unknown but it will work once it see the pin:unknown you can re-insert the battery and continue with reflashing the phone
Posted on Jan 30, 2010
My cousin put in a password for my blackberry 8220 he forgot the code and now i have one chance left before the phone is wiped what should i doo??? i need help plzz and thank you
Forgot BlackBerry Device Password
  • If you have forgotten your BlackBerry device password, and your BlackBerry device is on a BlackBerry Enterprise Server, contact your BlackBerry Enterprise Server administrator and request to have your password reset.
  • If your BlackBerry device is not connected to a BlackBerry Enterprise Server and you have forgotten your password, there is no way to have the password reset without erasing all the data.
If you know the password you're typing is correct, try the following:
  1. Deliberately type in an incorrect password five times on your BlackBerry smartphone.
  2. Before the BlackBerry smartphone allows a further attempt, you will be prompted to type the word blackberry in plain text.
  3. Instead of asterisks, the text you have been entering for the password will now show in plain text. Check to verify that it is correct.
  4. If the password is still being rejected by your BlackBerry smartphone as incorrect, connect the BlackBerry smartphone to a computer that has BlackBerry Desktop Manager installed.
  5. A prompt will appear in BlackBerry Desktop Manager to type the password for the BlackBerry smartphone. Type your password to rule out missed key strokes, incorrect symbols, or a problem with the BlackBerry smartphone
Aug 29, 2011 | RIM BlackBerry Pearl Flip 8220 Cellular...
Hi there i have downloaded qeep on my blackberry curve 8520 and had an error message come up on opening the file the error code is error starting f4d896b1dec1 module f4d896b1dec1 has verivacation error...
Hi,you could try this, it worked for me, might not work on all black berry,But you could try itout and get back to me it if helped.
RESET BLACK BERRY
How to Reset a Blackberry
There are three main types of Reset that apply to the Blackberry. These are listed in order below. Instructions for Blackberry Pearl are slightly different - see bottom section of the Tip.
1) Soft Reset - simply press the ALT+RIGHT SHIFT(CAP)+DELETE keys.
This reset stops all applications that are running on the Blackberry and will help if you are having problems connecting the device to computer. This reset will not erase any information from your device.
2) Double Soft Reset - this reset is almost equivalent to a full hard reset. First perform a Soft Reset as outlined in Step 1.
As soon as the screen is no longer black - repeat the steps once again exactly as before.
This takes you to another screen showing an hour glass. Allow the device to reset. This helps if the device has suffered a more serious error. Be aware you may loose some information from your device. A backup is advised prior to proceeding if at all possible.
3) Hard Reset - this is the full blown reset and will fully reset the device to help resolve critical errors with software or hardware. Again back up important information before proceeding if possible.
Note: For RIM models 850, 857, 950, or 957, you must insert the end of a paperclip or similar blunt object into a small recessed hole on the back of the unit and depress the switch inside. The device will reboot and be hard reset.
Other Models: With the device turned on - remove the battery for 30 seconds or more. Now replace the battery. The device will reboot and be hard reset.
Blackberry Pearl: To reset to factory defaults enter 'Options' from the main menu. Scroll to Security Options and press the trackball. Choose 'General Settings'.
Press the left soft key, then scroll to "Wipe Handheld" with the trackball and press the trackball. To initiate the factory reset, your phones security code may be required in order for the process to complete. Your phone will now be restored to its original settings on leaving the factory.
A hard reset can be achieved with the Pearl in the same way as outlined at Step 3 by removing the battery.
Be aware that resets such as these may erase data, such as contacts, ring tones, pictures, text messages and stored Internet files and emails. Make sure to back up important information beforehand if at all possible. You can obtain software to back up the device to your computer directly from Blackberry Below.
software112.com/products/blackberry-desktop-software.html
Hope this Tip helps. If so please do leave a vote for the solution.
Good luck
Thanks.
Feb 09, 2011 | Cell Phones
Application error 205 Reset-blackberry curve 8520
i tried to upgrade my blackberry, and it told me that if i disrupt or unplug the devise wile the upgrade was taking place, that it would make my device 'un-usable' unfortunately my laptop froze and now my blackberry wont switch on it just loads, then goes on to a white screen that says error 205 does anyone know how i can sort this out?
Feb 01, 2011 | Cell Phones
Unlocking my blackberry curve after 0 attempts
You can get your mobile unlocked here
http://www.prounlocking.com/blackberry-8520-curve/rs8wp9/ at very low cost which gives you best solution...
Aug 16, 2010 | RIM BlackBerry Curve 8520 Smartphone
App Error 523 Blackberry Pearl 8100
you need to wipe the device with JL commander and reload the software using desktop manager
Jul 19, 2010 | RIM BlackBerry Curve 8300 Smartphone
How do i solve the APP Error 523 on blackberry tour. I have no password set, i have the OS version 4.7 on the blackberry device. The device loads and shows the error APP Error 523 and reset. Upon reset it...
I had this same problem it was from a third party application that I had downloaded. Go to blackberry.com, and select support and search your APP error it will walk you through a guide on getting it fixed--although your phone will reset back to default.
Sep 27, 2009 | RIM BlackBerry? Tour 9630 Smartphone
Blackberry pearl 8130 locked by personal code
You can reset the phone by going to Options > General Settings > Security > Blackberry button and wiping the entire handheld.
That usually does a pretty good job of clearing the handset. If that doesn't do it, then you might have to reflash it by going to the carriers website and redownloading the software.
One final thing - it might be the PUK code. If thats the case, then try putting your SIM card into the phone (if its a GSM Blackberry)
Aug 25, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
Placed password shut phone down
Which model are you wanting help with - You mention both the 8300 and 8900?
In any case - The 8300 doesn't have a reset button? On the 8900 it may be behind the battery cover if so you will need a paper clip.
The following advice is general to Blackberry's and will help clear the memory and reset issues - These are both the soft and hard reset.
You can do a soft reset using Left Alt, Right Shift and Delete - Hold down keys simultaneously for a couple of seconds.
If that doesn't work - Try power down, remove the battery for a minute or so, re-insert battery and then power back on.
Let me know how you get on with the above - If they don't work - Can you also clarify which model no as I have given you generic advice for both models...
Jun 03, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Blackberry 7290 Device error: 400
Could someone help me with Device Error 400 for Blackberry 7290 please? I have this error since yesterday and can't resove it. If anyone can help me with would me great.
Thanks.
Jun 15, 2008 | RIM BlackBerry 7290
Computers & Internet Logo
118 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
Trisha
Trisha
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
