Question about Asko 1375 Dishwasher
My ASKO 1375 seems to wash fine but will not drain. We checked the pump, filters and drain hose. All seem to be fine. Suggestions?
It is easy to have insoluble items clog underneath the lower spinner. Take it off and clean the holes thoroughly. Check for bits of glass. If this is not the problem, it could be that the pump is broken.
Posted on Dec 30, 2010
Output drainage error
YOU HAVE TO UNCLOG THE FILTER AND THE WATER PUMP ITSELF. CHECK TO MAKE SURE THE WATER PUMP PROPELLER IS NOT OBSTRUCTED? CAN U TURN THE PROPELLER BY HAND
Mar 25, 2014 | Asko W6903W Front Load Stacked Washer /...
Asko 1375
May be the drainpump that has something stuck into it. Check that
Jun 08, 2008 | Asko 1375 Dishwasher
I have a 1776 Asko model & it doesn't finish its cycle-code mesage f-2 keeps appearing. Can you help me out.
Hi
F2 is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Sep 18, 2011 | Asko 1375 Dishwasher
1" of water standing in bottom of dishwasher after cycle? what is the problem
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Oct 20, 2010 | Asko 1375 Dishwasher
I am having an issue with my LG front loader washing machine model number WM1815cs. The water will not drain and the clothes will not spin out. Everything works fine until the rinse/spin cycle and it just...
Hi
Thanks for using FixYa. OE is a Drain Error which indicates that the water was not fully drained within 10 minutes. To start with check the drain pump filter for any clogs/foreign materials and try to clean the filter. Also if you have already checked the drain hose for any blockage then check the pump for any blockages, if still its not resolved then it seems to be the pump that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 28, 2010 | LG WM1815CS Front Load Washer
The drain pump motor on my ASKO model 1375 dishwasher wont stop running
Had a similar scenario on my Asko 1325. I simply removed the unit in preparation to chuck it, but once outside decided to check the inside of the pump/impeller and the electrical connections. Found plastic debris in the pump, and wiggled every electrical connector of its attachment and then re-attached it. Tried the Asko-fiasko outside and it worked.
BTW be prepared for an electrical failure/ meltdown as per the following two photos:e4b01cd.jpg47ce737.jpg
Jun 22, 2009 | Asko 1375 Dishwasher
Dishwasher does not drain after cycle
Check the drain pump and/or drain hose. It may be clogged woth something.
Jan 26, 2008 | Asko 1375 Dishwasher
Leaking washer
Check the pump where the shaft connects. Is it wet or rusty? If so replace the pump...
Dec 16, 2007 | Washing Machines
Asko 1375
May be the drainpump that has something stuck into it. Check that:)
Nov 23, 2007 | Asko 1375 Dishwasher
Asko 1375 Dishwasher Logo
134 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
