Question about Schlage Camelot Deadbolt Keypad, Satin Nickel #FE595VCAMXACC619
Can I lock my house from the outside using my key pad?
    Problem Solver:
  • 12 Answers
You may indeed use your key. The key will push inward about 1/2in when it is in the correct position to turn the locking/unlocking mechanism, the keypad will be still active
Posted on Dec 30, 2010
Our schlage lock with thumbturn on inside and keyed on outside. inside lock position AND outside keyhole are sideways. is this normal??
I've never seen a lock like that was intended to be that way, but have made that mistake when the shaft that goes through the bolt portion of the deadbolt is square and is 90 degrees off in the square hole it goes through. If so remove two screws on the inside and take out assembly with the key hole, position key hole bottom, then put key side assembly with shaft through bolt portion of lock. Test the key to see if it locks and unlocks, maybe you need to position shaft 90 degrees to left or right to work, then put cover on inside house and the two screws.
May 19, 2016 | Schlage Locks & Locksmithing
Lost 6 digit programming code and sticker is not inside key pad. How do i reprogram key pad
Programming Your FE595 Keypad Entry Lock - YouTube
? 7:02
www.youtube.com/watch?v=z8BgHP712eg
Jul 14, 2010 - Uploaded by SchlageLocks See how to program your keypad entry flex-lock (FE595). Video length is 7:02. ... Can you lock the door from the outside using only the keypad?
Sep 28, 2015 | Locks & Locksmithing
How do I change the battery on a winchester gun safe door?
Winchester uses several different brands of locks. You need to be more specific as to the lock that is on your safe. However, most batteries are contained in a housing on the under side of the code entry pad.
S&G batteries are usually removed by simply pulling slightly forward on the tab on the housing on the base of the lock. The housing will then drop down and you can change the battery.
Some locks will actually have the battery contained inside the code entry pad housing which can be removed by grasping the entire key pad housing and rotating the housing a few degrees counter clockwise, and then pulling the unit straight toward you.
Some locks may require you to remove a screw, but most do not.
A more specific description of which lock is installed in your safe will allow for a more specific answer. A picture also helps.
Mar 01, 2015 | Optics
I lost the keys to my back door yale lock, how do I get another one?
Somehow your answer ended up in the Office Shredders problem area. I suggest you resubmit your answer to the correct problem area. When you do, clarify if the lock is installed in the door, in that case, either 1) remove the lock and take it to a locksmith to make a new key (It is expensive if they come to you) 2) Buy a new lock and hide a spare somewhere safe outside your house 3) If it is a pad lock, cut the lock and get a new one.
Dec 09, 2013 | Office Equipment & Supplies
Driver door lock will not lock with key entry or key pad
press the last two keys on your outside door keypad simultaneously, all doors should lock. if this doesnt work suspect the doorlock actuator inside the door panel
Apr 08, 2013 | 2007 Lincoln MKZ
How do I lock the door with the key pad? I can unlock it fine but I can't get the door to lock. Don't have the manual. what buttons to I press?
Push the Lock button on outside touch pad to extend latch bolt 1" which locks the door when you leave.
Enter your desired personal code to retract the latch bolt completely which unlocks the door when you return home.
The T-turn on the inside of the door is used to extend (lock) or retract (unlock) the latch bolt when you are inside.
Using the key from the outside will also extend (lock) or retract (unlock) the latch bolt.
This Touchpad Electronic Deadbolt should be accompanied by a Kwikset Knobset, Leverset, or Handleset.
I cut & pasted the above from the installation instruction sheet.
Here is the link to the entire installation instructions sheet (manual):
http://s7d5.scene7.com/is/content/BDHHI/40486-02
It is a .PDF file, so if you aren't able to view it, download and install Adobe Reader from this site first:
http://get.adobe.com/reader/
If you are not able to lock the door using the outside touch pad's lock button, you may need to reprogram the door's "handedness", which gives the lockset the ability to be used on doors that have their hinges on either the right or left side of the door (right-hand or left-hand door).
The instructions for that are found on Step 4.9. This is also an excellent time to change the batteries, which is recommended yearly.
Aug 01, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
My key pad for my car is not working, my car is locked. Can you use the key to open it from the outside
Yes. even though most newer cars are equipped with "keyless entry", the good old standby of unlocking the door with a key still works.
Mar 23, 2011 | 2004 Pontiac Grand Prix
Servicing front hubs
Automatic Locking Hub
  1. Shift transfer lever to the ``2H'' position, then move vehicle forward and rearward approximately three feet.
  2. Raise and support vehicle, then remove wheel and tire assemblies.
  3. Disconnect brake hose from caliper.
  4. Remove caliper locking bolt.
  5. Rotate pad assembly upward then remove pad retaining clip and caliper assembly
  6. Remove brake pad support bracket.
  7. Remove hub cap retaining bolts, then the hub cap, Fig. 15.
  8. Remove housing assembly, snap ring and shims.
  9. Remove drive clutch assembly, inner cam and lock washer.
  10. Using tool J-36827 or equivalent, remove hub nut.
  11. Remove hub and disc assembly.Manual Locking Hub
    1. Shift transfer lever to the ``2H'' position and set free wheeling hub into Free position.
    7. Remove housing assembly retaining bolts then the housing assembly Fig. 16.
    8. Remove snap ring and shims.
    9. Remove body assembly and lock washer.
Jul 02, 2010 | 1991 Isuzu Trooper
Schlage Camelot Deadbolt Keypad, Satin Nickel #FE595VCAMXACC619 Logo
107 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
ken skalski
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
