Question about OKI B4400 Laser Printer
"TRIANGLE ! " WARNING LIGHT
I do not know what a warning light on my printer means.
hi . try to use the printer status monitor in your pc. it show you exactly what is wrong with your printer.
Apr 17, 2016 | Canon PIXMA MP160 All-In-One InkJet...
What does a flashing Red triangle mean?
TCO means that the tachograph does not work properly. Because the european legislation is very strict regarding the malfunction of the tachograph system, the truck manufacturers alert the driver about his critical situation with a warning sign, the red triangle that flashes.
Apr 16, 2014 | Bruder MAN TGA Container Service Truck
Porsche Indicators Lights Flashing
switch off the flashing warning light to the right6. It has a red triangle on it.
Apr 21, 2013 | 2001 Porsche 911 Carrera
The red triangle light with the "!" in it keeps flashing. I've just printed some things off but now it's not printing. Need it to print obviously..
ATTENTION light(triangle): Indicates that the print-cartridge door is open, print cartridge is missing, and other errors.
If ATTENTION and READY light is blinking:
Printer initialization
The printer is initializing.
No action is necessary.
Cleaning mode
A cleaning page is printing.
Wait until the cleaning page has finished and the printer is in the Ready state.
This could take up to two minutes.
If ATTENTION and READY light is on:
Fatal error
Turn off the printer, and then unplug the printer power cord for 30 minutes.
Plug the printer power cord into the power outlet, and then turn the printer on.
If the error persists, replace the printer.
If ATTENTION light is blinking and READY light is off:
  1. Attention: door open, no print cartridge, or media jam
The printer is in an error state that requires operator intervention.
Check the following:
? The print cartridge door must be completely closed.
? The print cartridge is correctly installed.
? There is no media jam.
2. Out of memoryThe printer is out of memory.
The page you are printing might be too complex for the printer's memory capacity.
Try lowering the resolution.
Aug 01, 2011 | HP LaserJet 1020 Printer
Volvo c30 How do I reset the maintenance remider message.
1. turn ignition to I
2. depress and hold trip button
3. turn ignition to II(while still holding trip button)
4. in about 5-7 seconds warning light(yellow triangle) begins to flash
5. release trip button WHEN yellow triangle is flashing(it flashes 5 times, if you wait for it to stop flashing, it will NOT reset), turn ignition off
Mar 02, 2011 | 2008 Volvo C30
Light with the triangle flashing - printer stopped
That means ATTENTION, you are either out of toner or have a paper jam.
Feb 18, 2010 | HP LaserJet P2015 Printer
I mailed yesterday about the problem with ouy hibrid prius. The problem is there is a warning light and a triangle sign appear. The problem is that we dont understand what is this sign for, and also the...
The triangle with an exclaimation mark in the middle is the Master Warning Light . I havn't had time to check out exactly what it is but is is covered in the service reminders part of the owners manual. Google " 2005 prius warning lights . In the first result , you will find a link to toyotapartsandservice.com where you will find owners manual's etc. ( in english )
Jan 06, 2009 | 2001 Toyota Prius
Flashing light
Here is what HP has on the subject of the triangle light flashing:
c00028322.gif 1 - Attention Light 2 - Ready Light 3 - Go Light Figure 2: Printer light key c00028323.gif 1 - Symbol for light off 2 - Symbol for light on 3 - Symbol for light blinking
c00028328.gif Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Figure 8: Paper jam c00028328.gif 13.JJ.NT JAM IN TRAY 1
13.JJ.NT JAM IN TRAY X
The Attention LED is blinking. Check paper loading then open and close top cover.
When there is a jam in tray 1, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored.
When there is a jam in tray X, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored. These are the error explanations for just the flashing triangle light, there are many more, but none for just the flashing triangle.
If the light pattern is different let me know (other lights on as well)
-Hope this helps.
May 28, 2008 | HP LaserJet 1012 Printer
OKI B4400 Laser Printer Logo
123 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
