Question about Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum
Model 25a3 Bissell won't spray. Where is the heater or solenoid switch on this model. Tnx
Make sure the belt is tight around the pulley. I had the same problem with no water/solution spraying. After researching the internet, the only answers I found were "clean the tubing" "clean the heater," etc. It turns out that the belt was not secure around the pulley. That belt also runs the pump. After taking care of that, problem solved. I probably got off easy, but you might want to check that before you tear apart the cleaner. Good Luck
Posted on Jul 04, 2012
My machine was not spraying water and the solution was to clean out the nozzles. I was able to access one through the side where you gain access to the belts. The one on the other side was accessible when I removed the clear shield in the front and removed two screws so that I could lift up the top. The nozzles are white and you need to squeeze the clamps and slide them back in order to remove the hoses that lead to the nozzles. I used a straightened out paper clip to shove into the back of the nozzle in order to clear it. The holes are very small so it's easy for them to get clogged. Apparently they are easily clogged by cleaning residue, so in order to prevent its happening again, I fill the tank with clear water after I'm finished using the machine and then run it just for a while, spraying clear water that will hopefully clean out any residue. Hope this helps.
Posted on Jul 24, 2011
I need a diagram of the hose connection in a Bissell Proheat model 1699-r
Bissell Proheat Carpet Cleaner Parts & Repair Diagrams
www.vacpartswarehouse.com > BISSELL
The Bissell Proheat Series Vacuum Parts, Repair Schematics, & Accessories. ...Bissell Proheat Proheat Cleaner 25A3 ... Bissell Proheat Deep Cleaner 1699 ..
Aug 30, 2015 | Bissell Vacuums
Bissell pro heat wont spray water
Hi, it's Allie from Crucial Vacuum!
Your Bissell ProHeat 25A3 may have stopped spraying water for several reasons. Make sure the bladder or water tank of your unit is filled with water properly and that the 2-in-1 tank has been placed properly.
If the water tank/bladder is filled and the 2-in-1 tank is placed properly, your unit's pump may have lost prime, to check this turn your unit's power off and hold spray trigger for 30 seconds. Turn the machine back on and check the spray flow.
Another thing that may not be allowing your unit to spray properly or spray at all is having a clogged solution filter and may need to be cleaned.
Last, your unit's pump belt may be broken. To replace, turn off your unit and unplug from any electrical outlet. Use a flat head screwdriver into the slot of the belt access door to release where you should have access to your unit's pump belt.
You can purchase direct your replacement belts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/bissell-proheat-2x-belts-2pk.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Oct 05, 2014 | Bissell Pro Heat Deep Cleaner Model 25A3,...
I have a bissell pro heat carpet cleaner. It is model 25a3 and about 1 year old. no water comes out when I press the trigger to clean the floor. The tools attachment works fine, any ideas?
If you are getting water from the tool. But not at the floor the most likely problem is the heater is clogged with coagulated soap or minerals. You will need to separate the upper handle to get to the heater. Insure the machine is unplugged. Remove the cover from the heater making sure you don't lose the little gaskets on each screw. Clean the channels inside the heater and put the cover back on. Be aware of how you are Taking it apart so you will know how to reassemble it.
Oct 31, 2013 | Bissell 25A3 Proheat Upright Deep Heated...
The same as a number of others,,no solution will spray out, suction works fine
Sorry to hear about the spray issue you're experiencing.
Here's a quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1099&cid=ccsocial
Feb 22, 2013 | Bissell 1698 PowerSteamer ProHeat Upright...
Repair manual for bissell proheat model 25A3
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Bissell model by clicking the link below.
Bissell PROheat 25A3 Series User Manual
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Sep 26, 2010 | Vacuums
Does the bissell pro heat have one or two belts?
The Bissell Model 25A3 has two belts, a pump belt and a brush roll belt. The pump belt (Bissell Part # B2150628) is flat and runs from the motor to the pump. The brush roll belt (Bissell part # B0560621) is cogged and runs from the pump to the brush roll. See key numbers 34 and 36 below.
May 17, 2010 | Bissell 25A3 Upright Vacuum
When I am cleaning carpet, the water spray works
I have a Proheat 2X and had the same problem. I don't know if this will work with your unit... but I tried the Water Rinse setting and found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing.
SO, an alternative to throwing out my unit and buying something else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW. Don't know if this will help, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
Apr 19, 2010 | Bissell 25A3 Upright Vacuum
Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum Logo
1,076 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
