Question about Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl
Sanipro xr pumps for 15 mins then wont start up again have to turn the power off and back on for it to pump how do i fix it
    Scholar:
  • Saniflo Expert
  • 115 Answers
Definitely there is a problem with the pressure chamber, it may need to be replaced. The pressure chamber is were all the electrical components are sitted and is what turns the unit on and off. You can always order parts throught Saniflo's technical dept. 800-571-8191
Posted on Jan 11, 2011
I have a Sanipro,it sounds like it pumps real weak and goes off quickly instead of emptying out everything. then it will come on again after aseveral seconds . Could it be the Condenser on the motor?
  1. Saniflo & Saniplus&... Repair Questions - Fixya
    www.fixya.com/.../p1064016-saniflo_saniplus_macerator_pump_002 Saniflo & Saniplus& Macerator Pump - Recent Questions, Troubleshooting & Support ... My saniflo does not flush properly always leaves the toilet paper behind.
Jul 20, 2015 | Saniflo SANIPRO Macerating Pump
Have a vw golf 1998 .car wont start turns over . put key in leave 15 minets and will start
Disconnect one of the cables from the battery. Leave off for 5 min. Reconnect the cable, tighten properly, snug. Computer is now reset. Perhaps that will work....
Jan 20, 2015 | 1998 Volkswagen Golf
I have a sanipro xr its not making the sound it use to when i use to flush and the waste doesnt go down.
The pump in the lift chamber has quit working. Check the power to it and if that's not the problem then you will have to get into where the pump is to see if the float is hung up. I know it's a nasty job but someone has to do it.
Jan 28, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
Sanipro xr is less than 6 months old been working fine but has recently become rather noisy. Sometimes goes off in the middle of the night for no reason.
Water pressure makes the unit kick on and off. Somehow water is draining back into the pump casing, check the flapper on the check valve inside the discharge elbow, it may not be closing properly or may be obstructed allowing waste water to drain back into the pump. Also check the flapper on the flush valve inside the toilet tank (water closet) the flapper may be leaking water into the bowl and from the bowl into the pump casing sitting behind. As far as making a loud noise, there could be a blockage on the drain pipe, blade or impeller. The discharge pipe may be loose, not clamped against the wall and is rattling against the wall when in use.
Jan 08, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
Sanipro xr massirato the problem is the pump is not pumping on makes a stuck sound, how do we clear out the massrator?.
You must remove the lid to gain access to the blades. Make sure you unplug the unit first. When reinstalling the lid place a little soap water around the gasket to help with the seal. thanks for using FIXYA. Jeff
Mar 11, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Sharp XR-1S Projector, no picture, lamp light flashing..... help!
if it's under 1 year old, it's still under warranty, so send it in and get it fixed for free.
Jul 06, 2009 | Sharp XR-1S Multimedia Projector
97 f-150 wont start sometimes when hot
Check for spark. Also listen for the fuel pump to kick on or spray starting fluid in the throttle body to see if it starts. If the fuel pump isn't kicking on then its your fuel pump and its located in the tank
Apr 21, 2009 | 1997 Ford F150 Regular Cab
Jeep Cherokee Sport 1993 stalls after start up fuel pump issues
good morning to you and welcome to fixya.com. hope we can get you fixed here. just a couple of questions first? have you changed the fuel pump yet? if so where did you buy the pump from? your pump is actually building up to much resistence and is unable to overcome it in turn no power is getting to pump as needed. i have a grand cherokee with 230k so i love hearing that you have that many miles. lets keep you rolling. let me know and ill help you out.
Feb 28, 2009 | 1996 Jeep Grand Cherokee
1984 bronco 2-runs 15 min shuts down wont start again for 20 runs
If the fuel filter is dirty it will settle when you turn the truck off. When it runs for a few minutes the debris in the filter will get sucked into the screen and stop the fuel from getting through. If it was a starter or coil, it would not start at all.
Dec 05, 2008 | 1984 Ford Bronco II
Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl Logo
701 people viewed this question
Top Saniflo Home Experts
Paul Carew
Donni Steen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
