Question about Belkin F5D7234-4 Router
My router will not show on my computer. all the lights stay on when i try to plug it in.
  • 591 Answers
If your router LED's are on and no ethernet wires are connected it is most likely defective
You could try resetting the router by holding down the reset switch in the back for 20 seconds then if it could be just a bug in the firmare
or you could re-flash/update the firmware (with the help of a good friend how can do this)
Good luck
Posted on Dec 30, 2010
Emachines Will not detect ethernet cable
With the machine on and the cable connected on both ends (1 to computer and the other end to the Router or Modem that needs to be powered up) look where the cable plugs into your computer. Is there a green or orange light on. There may be two. Normally one that stays on steady is the CONNECT. This one is normally green color LED. When Data is being transmitted a second LED will be flickering showing data transfer. If you have no LED lights showing directly by the Ethernet cable, try another cable. Reminder: also make sure you have power on the router/ cable/dsl modem.
Hope this helps..
Nov 04, 2012 | eMachines T5062 PC Desktop
My linkys wrt54g wireless router won't work i have tried un plugging it and plugging it back in what else can i try? The light will blink like its searching then it just stays on solid orange.
Hi.
Try to unplug power on both modem and router. Then plug your modem first and wait about 1 minute to make sure it finds a new ip address.
After that, plug your router and wait 2 minutes and try again.
You will probably have to restart your computer if it doesn't work the first time you try.
Feb 11, 2011 | Linksys Wireless-G WRT54G Router
Router/power light constantly flashing cannot make any connection to computer
try to reset the router. On the router you will find the reset button. press it and hold it down for 30 seconds. release the reset after 30 seconds. wait for 1 minute. unplug the power and plug it back in. wait for 1 minute and check if the power light stays solid.
If not then try to reset the router again.
check the IP address on the computer. If you are getting a valid IP address then try to open the set up page of the router.
If you are not getting the valid IP address and power light is not solid then I think you will need a new router.
Click here for more information about the router
Mar 09, 2010 | Belkin (F5D7231-4) Wireless Router
We have just tried to set up a belkin N wireless router and the modem red light stays flashing. Therefore , we have not been able to connect with the wireless
If you follow these steps it should clear up your issue.
  1. Unplug power from your modem, router and computer (turn off computer). Check to make sure your modem does not have a back up battery in it.
  2. Plug the coax (cable) or phone line (dsl) into your modem
  3. Plug an ethernet cable from your modem to the router. Make sure it is plugged into the "internet" port.
  4. Turn the modem on and wait 40 seconds for the lights to come on and the system to boot up fully.
  5. When it is up, plug the power into the router. Wait another 40 seconds to a minute for all the lights to come on and be green.
If this does not help please let me know and we can move further with your support. Routers can sometimes be very sensitive.
Good Luck,
NOLA Tech
Feb 05, 2010 | Belkin (F5D5231-4) Router
I set up my lynksys befsr41 ver4.1 using the set up disk. I hit enter at the password window and it goes to analyzing my computer. Then the password window shows up again etc. etc. etc. At the lower left I...
Are you trying to install the router.
You can do it manually without the CD.
First reset the router for 30 seconds. unplug the power to the router. wait for 5 seconds. Plug it back in.
Make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 14, 2010 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
I'm having problems with my Linksys ezxs55w switcher. The plugs are not lined up with the correct lights. For example, I plug the uplink into the uplink plug, but it shows up as number 5. Same with other...
You have a 5-port router. The 5th port can be used either as an "uplink" port (with a cross-over Ethernet cable) or as a "data" port (with a straight-though Ethernet cable).
You've not provided enough details to trouble-shoot the "staying online" problem, i.e., IP-addresses of each of the connected computers/printers, whether you're using CAT3 or CAT5 or CAT5E cables, whether you've tried different Ethernet cables, and whether the router is connected into a UPS that provides "smooth" power.
Dec 27, 2009 | Linksys EtherFast EZXS55W 5x10/100 Mbps...
SMC2804WBR router: The lights are on but nobody's home.
Sounds like the router is about to die. I had the same issue with a wireless router a few years ago. It would broadcast but I would not be able to get onto the wireless no matter what I did but plugging straight into the modem and it worked just fine. If you've done a hard reset and it is still not connecting or staying connected, it is about time to replace the router.
Nov 17, 2009 | SMC Barricade g SMC2804WBR Wireless Router
Will not reset after pressing button everything stays the same power light will not stay on the 4 port light will flash for a short while then they go out
HI! if reseting the router wont work by reseting it while its on.. do the hard reset, how? press the reset button while power is on and then after 10secs, unplug the power on the back of the router for 2secs and plug in while the reset button is still press, press it for 15secs.. then release.. leave it unplug for 10secs and plug in. if this issue wont fix, try to download the latest firmware for the router and upgrade the firmware.. after download is done, connect the router to ur computer and access the setup page of the router and do the upgrade..
Aug 12, 2009 | NetGear WGR614 Wireless Router
ActionTec gt701-wru
hello!
there's no way to remove the software that you loaded on your router but you can try to revert it to the old software. what you can also do is you can try to reconfigure the settings of your router because chances are, the settings went back to its default after the upgrade
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem
Step 1: Shutdown the computer.
Step 2: Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and test the Internet connection.
May 03, 2008 | Actiontec GT704WG Wireless Router...
Need major help
OK. First of of all, the only light that should stay solid on your router is the power light. All the others are activity lights. They show network traffic through the connections. Second, if you're going to power cycle the router it's a good idea to power cycle the modem as well. Just so you know, I know they sell and promote all kinds of wireless things for xbox 360 but it's best to run it with an ethernet cable. Better results. So, try this: Unplug your modem and router, wait about 60 seconds. When all the lights have come back on the modem (excluding the activity light ) plug in your router. See what happens and let me know.If this fixes your problem, please rate this as fixed. If it did not, then don't rate it yet. Just add a comment and I'll be glad to help you further. Thanks.
Apr 18, 2008 | D-Link AirPlus Xtreme G DWL-2100AP...
Belkin F5D7234-4 Router Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
