Question about Brother MFC 7420 All-In-One Laser Printer
My wife has replaced the drum in an MFC 7420 and it keeps telling her to reset the drum. I told her that all of the things I find her say to hit the options key and then press 1 when prompted for reset. She tells me that there is no options key on the printer. She keeps going into the menu and can't find where the options key might be. I am wondering if she is just hitting the wrong key.
All Office
  • 58 Answers
SOURCE: Drum on Brother MFC-7420
Why does the message "CHANGE DRUM SOON" continue to appear on the LCD display of my Brother machine, after I replaced the drum? Description: This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below. Open the front cover. Press the Options key on the control panel. The display will show "REPLACE DRUM - 1.YES 2.NO". Press 1 to reset the drum count. Close the front cover.
Posted on Jul 29, 2007
SOURCE: Brother Printer won't accept mostly full toner cartridge
On the side of the cartridge (TN2000) there is a white reset flag, this need to set to twevle 'o' clock, thats towards the black roller. If that hasn't been reset the cartridge will register as low.
Posted on Jun 12, 2008
  • 133 Answers
SOURCE: Brother MFC 7420 keeps saying - back cover open -
First be sure you close the back cover and remove all the jammed paper. after that, turn off your printer for 1 min to see is it okie.
Posted on Jun 14, 2009
  • 526 Answers
SOURCE: Reset the drum counter on Brother MFC-9840CDW
press the 3 and 9 button at the same time in ready mode.
then the reset menu will appear, press the up or down arrow until you get to drum.
press ok,
and select 1 to reset or 2 to exit.
it will return the ready state and your done.
Posted on Jun 27, 2009
  • 1684 Answers
SOURCE: cannot reset drum counter after fitting new drum
Instructions for resetting the drum count can be found on our web site at:
www.ccl-la.com/brother.htm
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jul 03, 2009
Brother MFC-7420; "Take Drum out; Slide blue tab..."
go online type in Brother MFC-7420 reset and follow details
Jan 30, 2013 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420 change drum soon light, did, still says change drum soon, how do I rest the drum, I cannot find my manual. Tks
Simply open the front cover.
This procedure wil work on the majority of the Brother MFC series of laser based Printer Scanner Fax Facsimile machines.
Good Luck and Thank You for using Fixya
WheatlandServices
Nov 05, 2010 | Brother MFC-7420 Printer
Keep getting Toner Life End Message even after replacing with brand new cartridge. I'm sure it is installed correctly. The Brother 7420 machine won't recognise the new cartridge(TN2025).
Open front cover and hit "Options" button, you should see a prompt to "Change Drum". Don't hit 1 for yes or 2 for no. hit the "Start" button and then put in the number 11. You should see the word "Accepted" in the window. Close front cover and you should be all set.
May 31, 2009 | Brother MFC 7420 All-In-One Laser Printer
Replaced Drum still says "Replace Drum Soon". How do I reset on a Brother 7420?
Reinstall the new drum unit, keeping the front cover open. Press OPTIONS. Press 1 when the display shows REPLACE DRUM? 1.YES 2.NO ACCEPTED. Close the front cover.
May 28, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420 Fax/Copier-Black copies
Check your owner's manual, and there's one in the install disk. It will show you where there are electric contacts inside where the drum is. You may have to take the drum out to see them. You're supposed to clean them with isopropyl alcohol on a q-tip. Don't get alcohol on anything else.
Apr 15, 2009 | Brother MFC 7420 All-In-One Laser Printer
RESET DRUM
Open the front door where you put the toner/drum unit in the machine. Press options then press 1.
Close the door.
Counter reset!
Aug 26, 2008 | Brother MFC 7420 All-In-One Laser Printer
Jun 11, 2008 | Brother MFC 7420 All-In-One Laser Printer
Jul 27, 2007 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420 All-In-One Laser Printer Logo
99 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
