Question about Samsung LE26R73BDX 26 in. HD-Ready LCD Television
Samsung 32inch LE32R74BD has lost all digital channels. Its nothing to do with Signal. Aerial is fine and analogue picture is good as ever. Can't access any digital functions on the handset. The reset option can't be selected either.
  • 11 Answers
SOURCE: Digital tuning
You'll need to go into service mode and do a factory reset.
To enter service mode you'll need to press these buttons on your remote in the following order:-
Standby-info-menu-mute-standby.You'll need to do it fairly quickly and be patient it doesn't always go into it first time,don't press and hold the buttons.
The service menu should appear on the screen.Use the up /down cursor to scan down to option number 12 (factory reset)and then press the right cursor wait will appear on the screen and the set will go to standby(don't worry this is normal)
Reboot the set and retune and all should be well
Posted on Nov 04, 2007
moto34
  • 155 Answers
SOURCE: Samsung LCD Tv
Try this:
Access menu service by press on your command, with your TV OFF:
INFO + MENU + MUTE + POWER ON
Then you should get access to Service Menu.
The last item says: RESET
This will do a reset to the TV.
Make no harm.
WARNING: If when on service menu you feel tempted to "screw" on anything FIRST take note on ALL you change! You can compromise the TV ...
Posted on May 03, 2008
SOURCE: 37" Polaroid LCD TV No signal appears when select channel
So, I couldn't get the tuner to work (tried everything). Eventually I realised the cheapest solution would be to buy a digital set top box, and use this as the tuner instead of relying on the one built-in to the TV. Works fine.
But yes, I won't be buying another Panasonic in a hurry.
Posted on May 24, 2008
  • 4 Answers
SOURCE: Cannot change channels in digital mode
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
Posted on Jun 10, 2008
SOURCE: samsung tv LE32R74BD standby light on but wont turn on
samsung tv le32r74bd had tv on standby and wont turn on,it is stuck on standby please can you solve this
Posted on Nov 24, 2008
Freeview problems
To pick up digital signals you need two things a good aerial and a good lead to it. The best type of aerial is like the one shown below. As for the cable to it, get the same stuff used to link up satellite dishes. Also shown below. If you need to split it for more than one TV get a proper splitter.
Never use the old type brown cable, it lets in water and doesn't stop electrical interference. A badly suppressed car on the old analogue TV caused a few dots on the picture. If it gets into a digital signal the picture will freeze and then vanish till it's gone. That's why you need very good cable.
To watch the HD channels you will need a really good signal, so invest in a decent aerial.
Jan 03, 2014 | Televison & Video
My daughter has a Goodmans GTVL19W17HDF in her bedroom for two or three years. She has only now mentioned that she has now lost ITV1 Channel 4 and Channel 5 using DTV, and also has a very inconsistently...
Fisrt check that the aerial connector going into the TV is OK.
The UK is in the process of switching off the analogue channels and reassigning to digital TV. This means that the signal strengths of various transmitters are getting stronger and channels are moving around to different frequencies. Try retuning the digital TV stations. If this does not work then try an external DTV box to see if the TV is at fault or it is a bad signal on the aerial.
May 16, 2011 | Televison & Video
I have a KDL-32v3100 Sony LCD. only analogue channels are found. no digital channels are found. aerial is OK
You don't say how clear the analogue picture is. If it's snowy, or ghosting (double images etc) your signal may be too weak to produce an acceptable result for digital signals to work at all.
If this is not the case you may have a faulty digital tuner. This assuming that the set was working and then stopped.
Jan 19, 2011 | Televison & Video
Hi i have hisence 42 inch tv will not tune in keeps saying no signal yet me old tv is fine
Hi there
I am assuming your new TV is now Digital. If so, it will be looking for a different signal to the old TV which was probably analogue. You may need a aerial upgrade/diagnostic to determine if you are recieving a digital signal. Or you can tune in the analogue channels, by switching the new TV to analogue, through the inputs/menu, and then i suggest autotune.
Hope this helps
TV_Doctor
Jan 03, 2011 | Televison & Video
I have just moved house to Reading and previously was able to view freeview tv using my old indoor aerial in my 2nd floor flat in london. This indoor aerial didn't pick up any signals, not even analogue,...
You will need to have an outdoor aerial installed, the signal area you're now living in will not be a strong enough reception for an indoor aerial no matter how good or expensive. You could try the indoor aerial in different positions around the room especially by a window to try & pick up some other channels but the long term this will cause some of the programmes to break up or freeze. An aerial on the roof or in the attic will be your best solution to pick up all the digital channels on freeview.
Nov 15, 2009 | LG 32LX1D 32 in. LCD Television
Freeview - No transmitter found
The signal from the communal aerial might be weak, since other people are using it, or it is experiencing interference with a power cable or something.
Try a signal booster from **** Smith or Harvey Norman, RadioShack, Tandy, Walmart etc ( I assume you are Australian - Freeview :) )
OR
Get your own aerial, if you don't live in a concrete shoebox....
Oct 12, 2009 | Televison & Video
LG RH277H aerial reception
relocate antenna or buy hdtv antenna. use hdmi cable for the dvd rec to tv. adjust dvd rec input source to hdmi.
Jun 12, 2017 | Televison & Video
Digital channels lost on DVD recorder
I'm delighted to report that all is now working.
I turned the recorder off at the mains electricity supply, left it off for several hours, switched it back on, searched for new digital channels, and it found them all :-)
I had tried this before, but only left it disconnected for a few minutes, and clearly that wasn't enough.
Sep 08, 2009 | Panasonic Televison & Video
No digital picture on digital TV
Are you getting a snowy picture, If so, you`re still on analogue. If you are on a digital channel with say no signal, you should get a blank screen with either a message saying no signal or a dot on the screen. Ian
Jul 24, 2009 | Sony Televison & Video
Intermittent sound/picture freeze when recording
this fault could be due to electrical interference ie freezer cutting in/out .just because your signal is strong dose not mean its interference free .check you analogue picture get it as good as you can with no ghosting. i also live in the southwest cornwall infact .aerials in lofts are not a good idea .i would mount it outside. by the way i am told that when the old analog channels are turned off the digital signal strength will be increased. good luck .farr64 [camborne cornwall]
Apr 29, 2009 | Televison & Video
Samsung LE26R73BDX 26 in. HD-Ready LCD Television Logo
50 people viewed this question
Henry  Thomas
Henry Thomas
