Question about Dell Inspiron 1150 Notebook
The bottom corner of my monitor (where it covers the hinges) is broken.
What is this part called if I wanted to order it? I think it would be the outer frame of the monitor.
  • 45 Answers
That would be called the front bezel
Posted on Jul 08, 2008
Streak in LCD Screen
Judith,
I'm going to state in my own words, as to what I think you have stated, originally; (Please bear with me as this may be clumsy)
" I have a Dell Inspiron 1525 Notebook PC.
This laptop has problems with the Hinges, and Base Cover.
The Base Cover area where the Hinges, and their respective screws go, is beyond repair. To properly repair it, I would need to purchase a Base Cover, Hinges, Hinge Brackets, and a 'Bezel'."
At this stage I am a little unclear,
" I think I would have to buy the entire bottom of the case,
{ Base Cover. Got it }, and replace the bezel that had pieces break off at the hinges too,....."
Hmmm.....Bezel....
Bezel that is close to the Hinges,..........
1) The Display Bezel that is in Front of the LCD screen? Thin plastic frame that resembles a picture frame? Bottom part has Hinge Covers formed in it?
2) Palm Rest Cover?
The cover that covers the top of the Body, of the laptop?
The major portion is below the Keyboard towards you. The rest of the Palm Rest Cover, is two rectangular pieces on each side of the Keyboard.
One of these two pieces broke? (Connector piece?)
3) Center Control Cover?
Is above the Keyboard, and below the Display Assembly.
Has the Power on button in it, for one.
To go on;
You purchased the same model on Ebay?
Same exact model number? Look on the bottom of the laptop.
Reasoning?
Primer:
An LCD screen cannot produce light by itself. It needs an additional light source.
A Backlight is the additional light source.
A Backlight (Present technology), can be a CCFL, or a series of LED lights.
The Dell Inspiron 1525 series used a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
(Approximately 2mm Thick, by almost the height of the LCD screen, Long.
2mm is a little larger than 1/16th of an Inch. { .0787 )
A screen Inverter is used to convert the power (Electricity) from the laptop, for the LCD screen, and the Backlight.
Point?
The screen Inverter, and the LCD screen, are a MATCHED unit.
Looking at the back of both LCD screens, what is the Dell part number/s, or LCD manufacturer model number/s?
[ One LG example from an article on InsideMyLaptop,
http://www.insidemylaptop.com/replace-lcd-screen-inverter-dell-inspiron-1525-laptop/
Scroll all the way down to Step 14. Read under the first photo, and view the second photo ]
Want to see if the LCD screen you are using, matches the Inverter in the laptop.
Dell, just like all laptop manufacturers, use different manufacturers of LCD screens. (LG, Sharp, Hitachi, etc)
May go with one for a few years, then off to a different one. (Or one's)
May change when a particular laptop model comes out.
The LCD screens may be slightly different models. In turn they would use different screen Inverters.
This = No.
4) Translucent 'streak' going from bottom left corner, to upper right corner.
That translates to;
A) Video Cable damage (Dell = Display Cable)
B) LCD screen damage
C) Bad graphics chipset
Have you used an external monitor to diagnose? A VGA monitor?
If so disregard the following;
A) Laptop OFF, monitor OFF. Connect a VGA monitor to the laptop.
You can use a CRT monitor (Looks like a small TV), or a flat LCD screen monitor that has a VGA cable attached.
Example of a VGA Cable, and VGA port, (Connector),
http://en.wikipedia.org/wiki/VGA_connector
Connect to the left side of the laptop.
B) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By default the display should show on the external VGA monitor.
If not:
Hold the Fn key down, simultaneously tap once on the F8 key.
Still nothing showing on external monitor?
You have at least three display options;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY.
Try again.
If the display is the same on the external VGA monitor, you have a bad graphics chipset. (G.P.U.)
If Not, the problem lies in the Display Cable, or screen Inverter, or LCD screen.
As you have seen the Display Cable connects to the motherboard, then routes up under the Left Hinge, and up into the Display Assembly.
The Display Cable can be damaged from normal use, over time.
Now add to it that you have had extensive Hinge problems.
If the sheath of the cable shows any visible damage, the tiny wires inside stand a chance of being damaged, also. (Stretched/Broken)
I would suggest testing the Display Cable. Perform a continuity test with a multimeter, for each wire in the Display Cable.
[ An economical multimeter can be purchased for around $8 to $12.
Available in a multitude of stores. An auto parts store is but one example.
Or perhaps you know someone who has a multimeter. Analog or digital is fine]
C) Did you reconnect the Wireless Antenna Cables correctly?
Reaching here but inquiring minds want to know.
http://support.dell.com/support/edocs/systems/ins1525/en/SM/display.htm#wp1179838
http://support.dell.com/support/edocs/systems/ins1525/en/SM/minicard.htm#wp1181360
[ The above is from - Dell Support > Inspiron 1525/1526 Service Manual,
http://support.dell.com/support/edocs/systems/ins1525/en/SM/index.htm
D) Would like to know what you did to follow Anti-Static Precautions?
I'm not following on the points of;
1) You installed what you considered to be a working LCD screen, into a laptop you bought off of Ebay; and the display stopped working on the Ebay laptop?
Or;
2) Or is your statement, that after receiving the Ebay laptop, your original laptop would no longer show graphics on it's display?
IMHO I would use the case parts of the Ebay laptop, and rebuild your original laptop.
Awaiting corrections, and possible questions.
Regards,
joecoolvette
Mar 20, 2012 | Dell Inspiron 1525 Notebook
Hinge is broken on my lexmark X6500 so cover won't close
I have a Lexmark X6570 All In One Wi-Fi model. Just had the problem where I went to print and received an error message saying that the cover was open (when it wasn't). I noticed that the back right hand corner had slightly popped out of place for no apparent reason. Tried to pus it back into place with no luck.
Here's what happened and how to fix it:
There are two plastic hinges at the back of the 6500 series printers that allow the top cover to open for access to the ink cartridge carriage. The lower ends of the hinges are cylindrical shaped and each contains a very stiff steel spring inside. They are designed to prop the cover of the printer up and hold it open when opened. As the plastic material ages, it may weaken and the tension of the internal spring may break the round end of the hinge off. This causes the printer cover to not fully close (even though it may appear so). There is a switch in the main printer body that detects when the top cover it open (even partially), and the printer won't work in this condition.
To fix this, open the top cover and carefully disconnect the 3 wire harnesses and the ribbon cable that run from the top cover to the base of the printer. Then remove the 'paper jam' hatch cover from the back of the printer. There are two phillips screws on the back panel of the pinter (one is located behind the paper jam hatch cover). Remove these screws (they secure the plastic hinges in place). You should now be able to lift the complete top cover/ scanner table assembly off the rest of the printer. Look for a steel spring about 3 inches long...remove this along with the round base of the hinge which may have broken off and remained down inside the printer. Glue this piece back onto the end of the hinge, but leave the spring out. Now reassemble the printer in the reverse order of disassembly and you should be good to go. Note that the top cover or the printer will not stay propped open on it's own with the spring removed, but this is not really an issue.
I am not sure if new replacement hinges are readily available from Lexmark or other sources.
Jul 23, 2011 | Lexmark X6570 InkJet Printer
I want to remove hard drive on a k40ij-d2 notebook
unscrew 4 screws on the back.<br /> remove battery cover, remove one screw there too.<br /> slide the bottom panal forward.<!-- from fixya rte -->
Aug 16, 2010 | ASUS K40 Notebook
Dometic rm2804 door hinges are worn and plastic strip retainer is broken off. On the lower door the hinge pins fit into round metal guides. In turn, the metal guides are held in place on the door corners...
I had this problem. I reversed the decorative plastic strips, both ends of the strip have hinge pin holes, so the doors can open left or right. I put the TOP decorative plastic strip on the bottom and BOTTOM on top.
Jun 25, 2009 | Dometic Refrigerators
How can i take the bottom stand of my monitor before i mount it t
Generally speaking, LCD monitors have a plastic cover that snaps onto the back side which covers the hinge and screws holding the base plate 'post' to the monitor. Remove the cover, and remove the screws. The post that engages the base plate will come off with the hinge intact.
tom
Dec 21, 2008 | Hyundai Computers & Internet
Bottom hinge on fridge door broken
Yes, there is supposed to be a plastic bushing/washer under there. Usually 1/8 inch thick. If a dealer is not handy you may cut some out of plastic to put there. Then undo the top hinge, and carefully lift the door off (you might want to empty the shelfs). Put your spacer on the hinge pin, and replace the door and the top hinge.
Jan 28, 2008 | Liebherr Premium CTP 3153 Top Freezer...
Replacing the whole monitor screen and bezel
Usually there is a plastic cover that snaps off right about the keyboard that covers the hinges. It is sometimes screwed from the bottom of the notebook thought. Once that is removed you should have a clearer view of what needs to be done. Sometimes there is a few screws from the bottom or back of the system that hold the hinges and sometimes the screws are on top of the hinges. You should also see all the cables that go from the screen to the system, unplug those. Hopefully that is all you need to do, but sometimes you have to remove the keyboard and palmrest to get the screen off. Good Luck!
Jan 10, 2008 | Gateway MX6448 Notebook
How do I replace the LCD screen hinge on my IBM T41?
I'm sure you could get these hinges from IBM, but no idea as to their cost. They are available on e-bay for $8-$35 (depending on whether you want 1 or a set) plus $8-$10 shipping.
As far as replacement. You will have to remove the Top cover assembly from the base of the PC. If you need help with that, just let me know and I'll talk you through that.
To replace the hinge, you will have to disassemble the Top cover assembly.The screws that you will need to remove are covered by small black adhesive covers. There are 3 round ones along the bottom of the bezel, 2 square ones up at the top of the bezel (to the left of the white LED keyboard light, and 6 (trapezoidal shaped) on the outside of the cover (3 on each side). Carefully remove those covers and the screws that are under the covers. Keep track of where the screws should go back in.
The actual bezel is held into the top cover with some internal snaps. Start at one of the corners, run a knife blade along the seam (between the cover and bezel) and you will hear each fastener "snap" as you slide the blade past it. Once the bezel is loose, lift it off of the LDC screen. There is one additional screw that is located up in the upper right hand corner. That one will need to be removed, also.
Gently lift the right hand side of the LCD assembly a couple of inches and place something of appropriate size to hold it in the raised position. You will see 2 additional screws that hold the hinge to the LCD assemble. Remove those and the old hinge will come right off.
Position the new hinge and replace the two screws that you had just removed. Reverse the removal sequence to reassemble the display.
Before you start snapping the bezel back into place, check to make sure that the two cover catches (those hook things, up at the top of the LCD assembly) are both operational. The link going to the left hand one tends to easily fall off.
This procedure should take in the neighborhood of 45 minutes to an hour.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thanks you, and have a super day!
Ron-
Nov 15, 2007 | IBM ThinkPad T41 Notebook
Dell Inspiron 1150 Notebook Logo
50 people viewed this question
Alun Cox
