Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Paper does not feed through correctly - Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
    Sergeant:
    Champion:
  • 217 Answers
Check the guides and tractor feed isn't blocked with a minute speck of paper. This will cause miscuing of the paper.
Look very closely in good light as the particals of paper can be very small.
Blow all clear and try some test feeds.
Posted on Dec 30, 2010
Unable to print - mangles paper
Hi
Try turning the printer off and on.
Check through the paper paths and remove any stuck papers.
Avoid filling the paper feed tray to capacity.
Make sure the paper you're using is the correct type and size for your printer.
Align the paper correctly on the feed tray.
Feb 27, 2012 | Office Equipment & Supplies
I am trying to print my guest receipts and it is only printing out a quarter of the sheet with no ink.
hello, lets see if we can seperate problem with computer and printer, try running printers self test, i am curios if the machine will print properly, turn printer off, then hold paper feed button and turn machine on, paper will feed and print, once the first test pass, if you want to print the rest, press paper feed button, and machine will print and cut paper, this test is rather a little long, but it will give you info regarding paper feed, and cutting as well as impressions. if paper is dragging, check to see if the paper in machine is in correctly, you might want to check this out first, if the paper is in correctly, then problem is feeding, this is a little hard to clean, but you might want to try some isoproply alcohol and put some on the lead in paper, just enough to get paper wet, and try to allow machine to feed in, or maybe, if paper is already feeding in wet some area before going into machine with alcohol, and press feed button, and allow the paper to feed thru. tear off paper and try the printer test again. if still fails then machine has a problem and will need service.
Oct 08, 2010 | Epson TM-U220 Matrix Printer
Paper doesn't always feed, and when it does, the paper rolls through without printing
Get a Q-Tip and alcohol. Wet Q-tip with alcohol. Stand in front of the printer and look down where the paper feeds through. On the righthand side you will see a big roller that pulls the paper through and a little one right up under that. Clean both of them with the alcohol and Q-tip. Press the paper feed button and as it trys to act like it is feeding the paper, clean the roller with the Q-tip. Do this until the paper feeds through correctly.
May 16, 2009 | Epson Stylus Photo R1800 InkJet Printer
Started feeding business card stock incorrectly - worked previously
You may need to have a technician adjust your copier or replace the rollers.
May 06, 2009 | Office Equipment & Supplies
Paper pulls to the right, jams, won't print, tried different paper still won't print
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Apr 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Paper not feeding correctly
OPEN UR PRINTER N CLEAN IT USE AN ATISTATIC VACCUM OR CANNED COMPRESSED AIR . ITS HAVING THE PROBLEM THERE SHOULD BE DUST OR DEBRIS IN PRINTER . INSPECT FOR ANY BROKEN PARTS IN THE PAPER PATH . IF U FIND ANY TO INVESTIGATE OR REPLACING THE PRINTER.THANKS
Apr 18, 2009 | Office Equipment & Supplies
Zerox WorkCentre XD125f E2 red paper jam light
This machine problem can be very involved.
A paper jam as described can be in any locations of the copier.
First of all when the toner-developer falls on the base of the paper feeder, it can contanimate all paper feed shafts and even sensors, and plug connections.
Worn feed rolls can cause the machine to jam. Clean the rollers and see if it corrects the problem.
A bent paper tray can cause the copy to skew, causing jams.
Sometimes the plasic paper path baffles are warped leaving narrow gaps in the paper feed path not allowing the paper to go through properly.
A bad paper feed sensor can cause inttermittant paper feed jams. This sensor is located just above the feed rolls. A involved process to take out without breaking the plastic components.
The machine has paper feed clutches located at the back of the feed rolls. To get to them it is also involved. Sometimes these clutches slip and will cause paper feed problems. There paper feed solinoids may operate intermittantly not allowing the paper feed clutch to operate correctly.
The main board can also cause these types of problems, not allowing the correct signal to operate the paper feed solinoids.
There is so much in this area to locate and isolate for paper feed problems.
If all else fails, call Xerox for a service repair.
Oct 26, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Paper feed
The most common factor here is moisture in the paper if it has sat too long. Try just line feeds to see if the transport is at fault or the paper is the problem and inspect the paper feed rollers to see if any debris is fouling things up.
Oct 12, 2008 | Lexmark X2500 All-In-One Printer
Paper wont feed
It's just one of four things............
1. The paper is not loaded correctly on the correct path.
2. The paper is loaded correctly on the correct path but the "PAPER PATH" selected in the printer driver box or printer preference or application used is not set correctly to grab the paper from the correct path.
3. The paper path sensor is defective which means that the printer needs to be taken to a servicer or you need to contact epson for warranty options
4. The paper being used is too thick for the printer to feed it
Aug 07, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
379 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
