Question about Dishwashers
My bosch classixx dishwasher does not heat up or pump out water, it also keeps running and does not end it's cycle. Can you help please?
It probably is dirt or corrosion on the set of contacts in the main switch (Normal, Pots, etc.)
Posted on Dec 30, 2010
Bosch classixx dishwasher not heating water on cooler wash works on hot wash
Most dishwashers don't heat the water. They run on whatever temperature water you have it set for. They have heating coils on the bottom but that's for drying, not heating up the wash water.
Nov 30, 2014 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
How do I resolve f17 error message on bosch classixx 7
F17 is a time out fault on drain pump. Check all water hoses and drain pump for either blockage or restriction. Failing that, check your waste pipe is clear.
May 29, 2014 | Bosch 24 in. SGS43C12 Classixx...
Bosch Classixx dishwasher fault
it can be a dry joint on the electronic board, or a defective thermostat, or the element, or an interrupted wire in the lower point of the door
Dec 23, 2013 | Bosch Dishwashers
We have a bosch classixx free standing dishwasher and the base is filled with water, we ve removed the filter but there doesn t seem to be anything there causing the blockage.any ideas?
Hello Becky,
The most likely causes are a failed drain pump motor (or capacitor) or a jammed/broken pump impeller. There is a very simply simple test on classixx models which which help you to determine the cause, or where to look next.
1. Turn the wash cycle selector to any wash cycle so the "ON" light is illuminated, but do not press the START/STOP button.
2. Open the door and pull the lower basket out.
3. Locate the 'float', lift it up fully and keep it held up.
(The float is a dome/mushroom shaped protrusion in the base of the washer just to the left of the drain and partially hidden by the spray arm)
When you lift the float, the drain pump should run instantly and the water should drain from the washer. If you can hear a low hum from the pump motor in the base of the washer, but the water doesn't drain, then it's likely that the pump impeller is jammed or it may have broken away from the spindle. If this is the case, try repeatedly lifting and dropping the float fairly rapidly. Repeated stop/start signals to the pump motor can sometimes free a stuck impeller.
If you cannot hear any noise from the base of the washer when you lift the float, then the drain pump motor or the motor capacitor may have failed. A failed capacitor is often accompanied by a buzzing noise. Further testing will be required to determine the exact cause of the fault.
Please try the simple test above and then post back with the results for further assistance.
Hope this helps.
Regards,
BElectric
Mar 05, 2011 | Bosch 24 in. SGS43C12 Classixx...
Water not heating up in my Bosch classixx dishwasher yet it still goes through its cycle ( but a lot slower )
your water temp is noot correct. the heater only really maintains the temp it does not raise the temp from cold to hot. if this is helpful send me a 4thumbs up post.
Feb 22, 2010 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher not draining after a power cut
I would run the heated dry cycle a few times to try and get rid of that residual water, then restart the cycle and see if it work now. If it still is a problem try cleaning out the drain line behind the dishwasher, this is a very common problem with draining. If not that then might need a valve or if you have a new garbage disposal you need to punch out a peice of the plastic or it wont drain. Hope this helped, good luck
Jul 14, 2009 | Bosch 24 in. SGS43C12 Classixx...
Bosch integrated dishwasher water pump wont go off
sounds like the drain pump stays on. take the kickplate off and check for water in the base. if no water then make that little red bar to the left of the watervalve in the base go up and down a few times. you could have a stuck microswitch on the pressure chamber
May 29, 2009 | Bosch 24 in. SGS43C12 Classixx...
Bosch dishwasher sgs43c02gb cycle problem.
I found the problem for pump noise & water in bottom. The dishwasher hose connection under sink had small plastic piece stuck in narrow elbow
Jan 23, 2009 | Bosch 24 in. SGS43C12 Classixx...
Bosch classixx slimline dishwasher not running through cycle
fault is that there is a leak. the tray at base of dishwasher is full of water which operates a float and turns on drain pump. tilt over 45deg and water will run out and then it will work or remove bottom front panel and mop out (better). then find leak
Mar 17, 2007 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Dishwashers Logo
78 people viewed this question
Top Dishwashers Experts
