Question about Whirlpool Duet GHW9150P Front Load Washer
Rubber seal and wire has come off the inside of my washer, how do you fix or do you need repair service?
Wire and bellows repair.Check to see if the rubber gasket bellows has a tear. If it loooks good the bellows goes over the front lip of the washer ,than place the wire that should have a spring attached over the lip. you will need a extra set oh hands to help hold the wire in place as you use to butterknifes to slde the spring over the lip.
Posted on Dec 31, 2010
Rubber seal inside door came off-how do I replace it and where does the retaining wire/cable go?
Reinstalling that rubber seal is a lesson in patients. There is a metal lip on the machine opening and a cooresponding groove in the rubber seal. These two need to be mated together. That's the easy part. Once together, the retaining wire and spring go around the rubber seal just on top of where the rubber seal goes over the matching lip. It will take several tries, the spring may be small but it's very strong and difficult to stretch. Good luck.
Jan 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Front Loading Duet Washing Machine Plastic at drum front shredding
i think your talking about the rubber door seal????
you can change this yourself,,,under the seal on the case is a wire spring unhook it and the door seal will fold inside the washer,,,on the inner drum you will find the other wire spring undo this as well and pull the old door seal out through the hole in the door,,,the new seal is fitted to the iner drun first so you need to turn the new seal inside out to fit it,,,push the seal into the washer and fit the inner wire first then unfold the seal and fit it over the outer door so you can fit the wire spring,,,
easy after you have fitted a fuw 100?
Aug 21, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Leaking at each wash cycle
this sounds like the door seal has split,,,there not very pricy but a pain to fit,,,so here go's,,,
open the door,,look at the door seal pull it off the back of the door and you should fine a spring wire holding it there,,,undo this wire,,,now fold the seal into the washer over the inner drum,,,,there you will find the inner wire,,undo that wire and pull the seal out the washer door,,,,
to fit the new seal,,,turn the seal inside out and push it through the hole in the door then fit the inner wire on the inner drum first,,,unfold the seal and pull it through the door,,,now fit the outer wire,,,,not put the kettel on,,have a cup of tea take the pain killers for the head ache you just got,,, and think about how much money you just saved ????
now was it realy worth the trouble,,,i wonder? am i good or what?
Jul 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have water leaking from seal around door. clothes got twisted inside around rubber part and pulled wire that is supposed to whole rubber in place. i put it back but can not get a good seal. is there a...
hi, the problem is trying to repair it can be hard and there are no guarantees its going to solve the problem, what some people use is silicon you can buy this from most diy stores and then when you put it on the rubber seal keep building it up untill it covers the whole or where it leaks.
Now doing this dosnt mean its going to solve the problem sometimes you can get it just right and then get at least a few months extra use out of it but on the other hand you might still have water leaking as its difficult to create a seal with to seperate materials ie the rubber seal and the silicon plus over time this would fail causing the seal to leak again.
You could try doing it but you may find it wont solve your problem.
What you could do is buy a new door seal you should be able to get one ordered from a local electrical appliance repair shop, but the problem you have is depending on how old the machine is would depend on wether its financially worth spending the money as its its over say 3 years old then the chances are you could soon be replacing motors and belts etc but this all depends on age.
You could try the silicon first as an emergency fix but their is no guarantee that it will last that long so its up to you.
replacing the whole seal would cost the price of the seal plus someone fitting it for you unless you could do this your self.
let me know how you get on or if you need further assistance
Nov 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The rubber seal came off of the inside during the spin cycle - behind door against the tub -- and a wire ring came out. I put the rubber seal back on but have no idea where the wire ring would go? Is this...
The wire ring is the seal retaining spring, it fits in a groove at the rear of the door seal.
Double the seal back in the drum, and fit the spring around the seal at the rear of same, it fits inside a groove, it is difficult, so persist and be patient.
Please rate my solution.
Thanks.
Nov 03, 2009 | Bosch WFMC 3200 Front Load Washer
A HOLE IN THE RUBBER SEAL
You can certainly diy. Unplug the washer. With the door open, look at the bottom of the seal. You'll see a ring clamp. Loosen the screw and remove the clamp. Peel the seal inward. It is easier to complete the seal swap with the front off. Remove the door and set aside. Locate the screws for the front of the machine and remove them, gaining access to the seal. Youcan either set the door to the side with the door lock wires still attached, or unclip them, which is easier. With the seal folded inward, you will likely find another clamp at the bottom. Loosen this as well. Remove the seal and replace with the new one, making sure to orient it like the old one was, and fold it to the inside like you had the old one for removal. Replace the front panel. Complete the seal installation, being careful to make sure that the clamp removed earlier gets put back in the groove and seats well. Reinstall the door. Best Regards, --WoobieDog--
Jul 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore HE 3t Front Loading washer, rubber seal torn
fix ya..do it your self and save big,,im going to talk you through..and give you the part number...what you need is the bellows part # 8182119...ok vack unplug unit..open the door,,now you see the front lip of the bellow theres a wire with a spring stick a srew driver and pull off,,wire off ..ok now look in the unit right behind the front panel and in front of the tub in the upper right hand corner of tub font or bellows backside there a nut take screwdiver and losen pull bellows off,,easy to put back just reverse but open clamp a bit on back...onthejob
Jan 27, 2009 | Kenmore Elite 45986 Front Load Washer
Leaking door due to the wire ring that holds rubber seal
Bosch Nexxt 500 WFMC3301 Front Load Washer how
to get the metal ring back on.
This video will show you how to change a door seal on this Bosch front loader washing machine and also how to replace the metal rings.
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 06, 2008 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Clothes got tangled with rubber seal inside and ripped it. How do I fix/get a new seal?
This part is a problem on many front-loaders and never really goes away. The rubber seal is a replaceable part and should be supplied under warranty. There is no way to fix it.You should try very hard to get Sears to pick up the labor cost as well.
Mar 14, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
225 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
