Question about Uniden Lands Phones
Message on handset reads - "Check TEL Line"
    Problem Solver:
  • 12 Answers
This generally indicates a phone line tha is dead. It may have timed out because a phone on the line has been left or knocked "off-hook". If so hangup the offending phone. In a short time the problem will self-correct. Beyond that, unplug ALL the phone appliences ( Fax,Computer, phones) Then, after waiting about 5min plug in 1 phone to see if it works. If that worked, re plug in the remaining items 1 at a time checking that the phone still works. If it quits, the last item you plugged in is likely causing the trouble.If the phone did not work, then go to the demarcation test box(ouside where the phone line comes in) open the portion which does NOT have the tamper proof screw. Unplug the short jumper wire and plug in a telephone. If the phone works there, the incoming phone service is ok, if it doesn't work call for service. If callers have complained tha you seem to pick up then immediately hang up, clean accumulated dust from jacks that are on outside walls particularly any near humidfiers tha may have caused the dust to become conductive. (a vacume cleaner should work) PS look for chewed cords (cats, dogs)
Posted on Dec 30, 2010
Getting check tel line message on base unit. Checked all the plugs on handsets, but still get message.
It could be one or more of these:
- the cord that goes from the base unit to the phone company wall jack is faulty
- the cord that goes from the base unit to the phone company wall jack is not connected or is not plugged in to the base unit jack labelled 'line'
- the wall jack is not active (ie; does not have phone company dial tone)
Sep 04, 2017 | Lands Phones
In normal condition phone continuously ringing what do
There could have been a short or ground in the telephone line (Tip and Ring). Please check the connection of the Tel line cord in the junction box. If your Tel line consist of 3 wires, disconnect all three wires, lift the handset, connect only 2 wires going to Exch Line or Trunk line (Local Tel Company) until you hear the dial tone. Leave the other wire disconnected.
This helped me isolate the problem, I hope this applies to you.
Best regards.
Sep 02, 2015 | Lands Phones
"Check Tel Line": Do I need a new phone?
theres some thing wrong with the base unit, try unplugging it and plugging the whole setup at a friends or something, also if youhave a DSL line you my have to install a filter to seperate the data line and voice line. Its ole school but this might work.
Feb 16, 2014 | Uniden DECT 6.0 Cordless Telephone...
Panasonic phone says check tel line
Check cable conections from phone box on wall to base unit, make sure that the conectors are fully inserted. If possible plug a different phone into box to make sure that line is working. Hope this helps
Jun 08, 2017 | Lands Phones
I have a Panosonic pnlc1001yat cordless phone, and I just moved and now have a new phone number. When I plug in the base, I get an error tht reads
make sure that the service provider has connect your line in the exchange
if you have moved areas then you may get a new number as numbers do not move with the phone
Dec 16, 2017 | Lands Phones
Motorola L404 DECT 6.0 Cordless 4 Handset Phone & Answering System . Was working fine, and then one day just stopped. When we pick up any handset the error message reads "no line."...
I had the same message. After a length investigation, I found it was the phone line and not the phone. After having the phone line fixed, the phone worked fined.
Nov 02, 2011 | Motorola Lands Phones
Message displays "check tel line". All
What you need to do first of all , put of the phone then disconnect it from the power supply allow he phone for about five minute ,then put it on again check the phone respond on your command if the problem remain same or solve.
Note if the problem remain then you will need to send me the name and the mode /serial number of the phone to guide you further.
Thanks.
Sep 06, 2011 | Panasonic Lands Phones
My panasonic panafax uf-890 has three ports on it's leftside and they are labeled "line" "telephone" and "handset". For faxing proposes, which port should I have plugged-in?
The "line" port is for the telephone line you intend to use for faxing.
The "Tel" port is for an external telephone to be plugged in.
The "Handset" port is for the hanset which may or may not have come with the fax machine.
Dec 31, 2010 | Office Equipment & Supplies
Message reads: "Check tel line"
You can remove your telephone line from the base unit and fix it to stranded telephone unit and hear the dial tone.If it heard then some inductor or else part may be broken inside the base unit due high current surge.If the dial tone didn't heard from the other phone also check for the corroded line cord or modular box fault with the tel line.There should be 30 Volt-50Volt D.C.Voltage at your wire ends.
Rana.rishanranatunga@gmail.com
May 18, 2009 | Panasonic KX-TG1033S Cordless Phone
Lands Phones Logo
566 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
