Question about Refrigerators
I have a Kenmore top freezer with ice-maker and there is water leaking into the refrigerator. I shut off the valve to the water supply and every day about 1 cup of water collects below the vegetable crisper. Any idea's, thank-you ,Dave
    Problem Solver:
  • 8 Answers
Sounds like your defrost drainpan is stopped up. It should be located behind the rear panel in the freezer, below the coil. If it is frozen, DO NOT USE A POINTY OBJECT!!! Thaw it with a hair dryer or leave unit off overnight. Clear any debris from pan. Some units have a cup-like device at top rear center of ref. section. If so, you can pull it foreward to remove it, then flush with hot water and re-install. good luck.
Posted on Dec 30, 2010
Ice maker drips water into freezer.Makes ice but doesn't shut off when full.
How to Repair a Refrigerator Ice Maker ' HomeTips
www.hometips.com/repair-fix/freezer-ice-maker.html
Aug 6, 2015 - If the ice maker doesn't make ice but you can see the arm swing intomotion and you hear a ... 4Check the water line that enters the back of the freezer for a blockage. Find the water shut-off valve behind the refrigerator or under the sink, turn it off, ... If your ice maker keeps making ice, even when it is full:.
Refrigerator's Ice Maker Leaking Water ' ThriftyFun
www.thriftyfun.com/tf37813274.tip.html
If your refrigerator ice maker is leaking water, the first step is to locate the source. ... Its not the ice maker - in the floor of the freezer is a small drain that lets the ... I shutthe water supply off but water dispenser still leaks even though no ... My side by side refrigerator leaks water into the ice bin when filling the ice tray with water .
Dec 26, 2015 | Refrigerators
I just hooked up the ice maker to the water line and put the lever down on the icemaker. The water has not filled the ice maker. Is there something I need to do further? The model # is 596.765 73600
  • here are some things to check for, please be very careful and only to this if you disconnect the power supply.
  • 1 Inspect the shut off arm located on the side of the ice maker. This arm should move up and down with a slight resistance when pushing upward. Make sure that this lever is not frozen to the side of the ice maker preventing it from dispensing ice. In addition, if the arm move loosely up and down, then it is broken and must be replaced.
  • 2 Verify that the ice maker is receiving water. Check the water supply valve which is usually located either behind the refrigerator or under the kitchen sink. The knob should be turned all the way clockwise until it will no longer move.
  • 3 Move the freezer or refrigerator out from the wall and locate the water supply line. This line extends from the water supply valve that was previously located. Make sure there are no kinks or twists in the water supply line as this prevents the ice maker from getting water. Also check for leaks along the supply line which will also prevent the ice maker form working.
  • 4 Locate the manual shut off button for the freezer, if it has one. In some models, the shut off button is located inside the freezer door. If this is the case, simply check to make sure the button is switched to the "on" position. Shut off valves are only on some Kenmore refrigerator/freezer combination appliances.
  • 5 Measure the temperature in the freezer by placing a thermometer inside and allowing it to sit for approximately one hour. If the temperature is higher than 17 degrees F, then something is wrong with the main freezer and not the ice maker.
  • 6 Check the water inlet valve to ensure that is allows water to flow through freely. First turn off the water supply at the water supply valve, usually located under the sink or behind the appliance. Locate the water inlet valve by following the water supply line up to where it attaches to the refrigerator or freezer. Turn the plastic nut at the base of the supply line counterclockwise to detach the supply line. Pull the two or four wires of the water inlet valve off of the terminals. Inspect the wires for burn marks or corrosion. If these are present, it means they must be replaced as water is not being fed to the freezer.
  • good luck
    Iain
    May 02, 2011 | Kenmore Refrigerators
    Water is leaking from the Ice maker on top of the
    the water valve on the back of the fridge has malfunctioned.
    Jul 21, 2010 | Kenmore 57029 Side by Side Refrigerator
    Kenmore bottom freezer refrigerator warming up
    Hi
    There is a definetely leak in the cooling gas.
    Firstly... You will need to find from where the gas has leaked. It is usually on the compressor pipes..... but not always.
    Secondly you are right about the Water Valve... it needs to be changed.
    Regards
    Berry
    Feb 02, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
    Icemaker is leaking into ice bin.
    it sounds like the water valve is leaking
    May 07, 2009 | Kenmore Refrigerators
    Water is leaking from freezer into lower compartment of kenmore
    If you think it is the ice maker then shut down the water supply and see if the leak stops. Most likely though it is probably a blocked defrost drain.
    Apr 09, 2009 | Refrigerators
    Kenmore coldspot top freezer auto ice maker, water
    Dear customer,
                   We suggest u to perform the following checks to solve ur problem...
    1. Check the refrigerator for level
    2. Check the ice maker for level
    3. Inspect the fill cup alignment
    4. Inspect the water supply line
    5. Test the water inlet switch
    6. Test the water inlet valve
    7. Check the shutoff arm
    8. Test the shutoff switch
    thank you..
    Apr 08, 2009 | Kenmore Refrigerators
    Kenmore Refrigerator Ice Maker
    it sounds like your inlet water valve is not closing all the way,pull frig out turn water off,remove valve get model number from inside the frig. and replace it,let me know-mike
    Jul 07, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
    Refrigerators Logo
    61 people viewed this question
    Top Refrigerators Experts
    John Tripp
    John Tripp
    Brian Coughlan
