How do I get my username and password for my DR615 router. I have set it up and tried to reset to factory settings but still no luck. I am trying to connect my laptop and xbox to the wireless network. Thanks Mike
    Sergeant:
    Champion:
  • 217 Answers
If you have reset it, go into your security setting of your router and fill in the boxes.
Once rebooted, it should now use your new settings.
Posted on Dec 30, 2010
For got password would like to reset username
Every router I have ever seen allows you to reset the configuration to factory default - but not allow you to retrieve a forgotten password and maintain your settings at the same time. This is often referred to a "factory" or "hard" reset.
When you initiate a factory / hard reset, typically by pressing & holding a button on the router - or behind an opening in the router case - all the changes you've made to it will be returned to the factory default. Wifi becomes "open" with no password (on most devices), the login username / password also go back to default settings (common ones are: admin / admin, admin / password, <blank> / admin, <blank / password, etc.). Consult your router's set up guide or online documentation to learn what the factory / hard reset procedure and the default settings.
Once you gain access to the setup pages of the router, configure it as best as you can remember, and lock it down with good security settings. At minimum - this should include changing the router's username / password, the WiFi's SSID and do not broadcast it, add WPA or WPA2 encryption and secure it with a security key (use a mix of numbers, letters, symbols etc.).
I suggest recording the settings on paper and then tape it to the bottom of the router. There it will remain out of sight - but ready when you need it.
Oct 17, 2014 | Computers & Internet
I am trying to reset my user name and password. I was doing the security thing with typing in code shown, when i hit wrong button. I would like to redo this please. been trying for over an hour to fin
Once you gain access to the setup pages of the router, configure it as best as you can remember, and lock it down with good security settings. At minimum - this should include changing the router's username / password, the WiFi's SSID and do not broadcast it, add WPA or WPA2 encryption and secure it with a security or network key (use a mix of numbers, letters, symbols etc.).
I suggest recording all these settings on paper and then tape it to the bottom of the router. There it will remain out of sight - but ready when you need it.
Oct 08, 2014 | Computers & Internet
I am trying to install a netgear cg814wg wireless router manually. I am going to http://192.168.1 but its aking for username and password. I have tried admin for the username and 1234 and password for the...
You can try resetting your netgear router to default settings. the reset is button located on the rear panel of your gateway to reset all settings to their factory defaults.
Here's the router default configurations settings:
User login URL: http://192.168.1.1
User name (case sensitive): admin or superuser
Login Password (case sensitive): password
You can also check and download your router manual & user guides here:
http://documentation.netgear.com/cg814wgv3/enu/202-10297-01/pdfs/FullManual.pdf
Good luck,
Ryan
May 26, 2011 | NetGear CG814M Wireless Cable Modem...
Need password to my netgear router n 300
what is the model #?
Most netgear routers default to a username of "admin" and password is either " admin ", "password" or it is just blank. Those are the defaults unless someone changed it.
If you cant get in you can hold down the reset button on the back for 30 seconds (while it is plugged into power) and that will set it back to factory default settings then one of the above should work.
If this was a help please give me 4 thumbs up as I am trying to build up my rep on this site!
Mar 02, 2011 | Computers & Internet
How do i reset my password on netopia 3000 router
If you are talking about the password to change the router settings you will need to do a hard reset or try the already default username and password below, but be aware that it will take you back to factory settings.
Get a pen or a straighted paper clip and with the router still powered on, hold that tiny reset button for a bout 30 seconds, then unplug the router and plug it back in. This will set it back to factory defaults and you will need a cabled connection to reconfigure the router. If it ask for your username and password, use these
Username: admin Password: admin
Feb 26, 2011 | Computers & Internet
Where can I find my DI-524 Username and Password?
If you have not changed it, the default username and password can be:
Username: can be left blank or use "admin"
(without the quotes)
Password: can be left blank or you can use either "password", "1234", "admin"
Jan 03, 2011 | D-Link AirPlus DI-524 Wireless Router
Lost password
•Connect the power cord
•Unplug ALL Ethernet connections
•Hold down the reset button for at least 15 seconds
This will reset your router to factory defaults. •Open Internet Explorer (with the computer connected to the Router)•Enter 192.168.1.1 into the Address Bar, push Enter•If 192.168.1.1 does not appear to work, try 192.168.0.1•Under the Username field enter "admin"•Under the password field enter "password"•Click "OK"
Good luck and thank you for using FixYa! We would sure appreciate a 4 "thumbs-up" rating for this FREE answer. Happy holidays!
Dec 05, 2010 | Belkin F5D8631-4 Router (F5D8631au4A)
Problem in setup wireless router,need default security key/phrase
If there reset the router to the factory settings:
Default Username: admin (lowercase)
Default Password: none (none, leave blank)
If this doesn't work, try pressing the reset button for 10 seconds with it powered ON. Then try it off. I can't remember which one will work.
After this is complete, username: admin and password: (nothing, blank, nada) will work.
Good Luck!
Apr 07, 2009 | Hawking 54M WIRELESS G ROUTER AP 4PORT...
Password for belkin router
If you have the router, the default username and password is usually printed on the bottom if not try these.
Username | Password
Admin (none)
Administrator (none)
Admin password
Administrator password
Admin admin
Administrator admin
try these in any order and switch round passwords to usernames these are the default passwords, if these dont work, then a simple push button reset will sort you out.
Ben.
Feb 07, 2008 | Belkin (F5D7230-4) Router (587009)
Lost password for wireless connection
Reset your router using the reset button. That will put everything back to factory settings.
Dec 25, 2007 | Broadcom BCM5705 Network Adapter
Computers & Internet Logo
David Payne
David Payne
