Question about Sony PlayStation Portable (PSP) Slim (PSP-2000) Console
Left trigger of my psp 2000 is messed up.It looks perfectly fine and the trigger presses down correctly,but when i press it it takes like 30 seconds to a minute for it to stop pressing
sandrew
  • 2961 Answers
SOURCE: Left Trigger
if you undo the screws from the underside of the controller and gently part the body just enough to see the back of the button, then spray a very small amount of WD40 or any lubricating liquid around the button and press button gently in and out to lubricate it.
Posted on Jul 31, 2007
SOURCE: sony psp scrolling
change your analog stik.
Posted on Jan 14, 2008
SOURCE: psp malfunction
have you downgraded , hacked it or put homebrew on it ?
Posted on Feb 28, 2008
SOURCE: psp doesn't want to turn on
i play my psp regualy then i quit using it and when i went to turn it on it would never turn on and it want charge.
Posted on Sep 17, 2008
ndsservice
  • 10 Answers
SOURCE: ds lite left trigger broken..
yes your ds lite is repair able if you can,,,,,open up your ds lite and get a soldering iron and touch the 4 points with it, then put it back together.
I can give you step by step information if you email me at ndsrepairservice@gmail.com
Posted on Jan 28, 2009
Psp 2000 screen rainbow colored
Replace the screen or replace the whole thing
Aug 25, 2013 | Sony PlayStation Portable (PSP) Slim...
Switch to english
Hi newagehippie,
on your PSP go to " settings " ( it looks like a tool box ) --> then " System Settings " ( it looks like a PSP ) --> then select your Language.
i hope this helps.
May 16, 2011 | Sony PlayStation Portable (PSP) Console
My psp will not play the games i put in it
Hi maskewfish,
The games that you have already downloaded on your PSP might not be properly downloaded causing you not to play it. Another thing is, consider to double check if you have correct file extension. The following steps I have for you below will help you ensure that games will be properly downloaded and a reminder about the correct file extension to use.
1. Connect the PSP to your PC.
2. Find "Settings", then look for "USB Connection".
3. Press the "X" button, your PSP should display "USB Connection".
4. Please wait until your computer tells you that a new USB device has been connected, then show you a new generic hard drive, usually E: or F:.
5. Click on the drive letter that corresponds to the PSP unit.
6. Now look for ISO folder then copy your desired game (.ISO file) into the folder.
7. When you're done copying your desired games, press the "O" button on the PSP to get out of USB connect mode.
8. To play the game, Use the left-right arrows to move to the game area, then the up-down arrows to find "Memory Stick". Chose that folder by pressing the "X" button again, and you should be able to play all your favorite games!
Hope it helps,
Thank you for using FixYa,
Jan 18, 2011 | Sony PlayStation Portable (PSP) Slim...
How to restore default settings
Hello :
  1. Remove the battery from the left side of the PSP while it is still on. The unit will power down instantly. Wait ten seconds and then replace the battery.
  2. Press both clear shoulder buttons at the top of the PSP and keep them held while the PSP reboots. A "Recovery" mode will be initiated.
  3. Press down on the control pad to locate a "recovery" folder. This will contain all of your PSP content, including games, music, videos and podcasts that are saved on the device. Highlight this folder and press the "X" button to begin reinstalling your content.
Warnings
  • If you would like to reset your PSP while it is working normally, you can do so by going to the Settings menu and selecting "System Reset." This will get rid of all your content and restore the PSP to factory settings (and subsequently remove all of your content.)
Or try this for hard resetting :
  1. Locate your Power button on your PSP. Push the power button up for 10 seconds.
  2. The PSP will and should shut off. Leave the PSP off for 30 seconds.
  3. Turn your PSP back on by flicking the power button up very quickly. If it doesn't turn on, try pushing the power button forward very quickly again. (sometimes you have to do it 2-3 times)
  4. Your PSP should be working now. If not, then you may have a firmware problem.
Warning:
  • Do not have your PSP plugged into a power supply.
  • If your PSP doesn't turn off after 10 seconds (of power button being help up) then remove your battery and wait 30 seconds, and then replace .
PLEASE RATE !
Jun 08, 2010 | Sony PlayStation Portable (PSP) Console
Trying to reset ps 2 to factory
Hello :
1: Remove the battery from the left side of the PSP while it is still onThe unit will power down instantly. Wait ten seconds and then replace the battery.
2: Press both clear shoulder buttons at the top of the PSP and keep them held while the PSP reboots. A "Recovery" mode will be initiated.
3: Press down on the control pad to locate a "recovery" folder. This will contain all of your PSP content, including games, music, videos and podcasts that are saved on the device. Highlight this folder and press the "X" button to begin reinstalling your content.
Warnings :
1: Locate your Power button on your PSP. Push the power button up for 10 seconds.
2: The PSP will and should shut off. Leave the PSP off for 30 seconds.
3: Turn your PSP back on by flicking the power button up very quickly. If it doesn't turn on, try pushing the power button forward very quickly again. (sometimes you have to do it 2-3 times)
4: Your PSP should be working now. If not, then you may have a firmware problem.
Warning:
good luck .
please don't forget to rate !
Apr 05, 2010 | Sony PlayStation Portable (PSP) Console
My psp was working before but now it suddenly hanged up..i cant use it now..how can i reformat my psp?? do you know some ways???
Hello :
Warnings
Warning:
good luck .
rate please !
Mar 19, 2010 | Sony PlayStation Portable (PSP) Console
My psp hang when i hold it it appears m33 vsh menu and nothing works except the vol
My psp did the same thing. 1. Turn off psp. 2. Hold down R trigger while turning psp back on. This should take you to the M33 Recovery Menu. 3. Go to "Configuration" press X then go down to "Use VshMenu" press X so that it is Disabled. This should fix it. Go up to back then down to exit. If this doesnt work or if it does work please comment back to let me know. I like to know that people actually read my posts. Thanx. Gonzo Dacompo
Aug 19, 2009 | Video Game Consoles & Games
Psp works slow
press the power button on your psp phat then press the r button triggerly and go to the cpu speed then press x button then default thats it
Jan 05, 2009 | Sony PlayStation Portable (PSP) Console
Psp menu problem
Ok, your psp CPU clock speed is set to low speed.. 2 way to change:
1. If your psp has VSH menu enable.. : press "select" button, a small window will appear, otherwise its set to "disable".. See at "CPU CLOCK XMB" must set as "default". use left-right d-pad to change it. if vsh menu is disable you can try 2nd way.
2. Boot PSP under Recovery menu ( Hold R-trigger when turn on your psp ).. under M33 menu select "CPU Speed" then press "X", select "Speed in XMB" and "Speed in UMD" to setting as "Default" by pressing "X" button a few times.
Hopefully this help.! Pls post back should you need additional information, and also Show your Appreciation, to help other USER.
http://e-arena.blogspot.com.
Nov 06, 2008 | Sony PlayStation Portable (PSP) Console
PSP SCREEN FLICKERS AND GOES SLOW IN MAIN MENU
Ok...this sounds crazy but it happened to one of my PSPs. I updated the firmware on my system and the menu started stalling and taking a long time to respond. I shut the PSP all the way down....holding the power button until the light shuts off (about 4 or 5 seconds)...Hold the R button and power the system on again (you should be in recovery mode)...go to CPU speed and make sure it is either set at "Default" or "222"....I belive 222 is the default setting....also make sure the UMD is also set at "Default" or 222....if you're going to use the UMD.
Feb 06, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Slim (PSP-2000) Console Logo
89 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
