Question about Magellan Triton 1500 GPS Receiver
Magellan triton 400 fatal application error gps doesnt work anymore when i open it it give me that error and i cant do any thing with it
  • 321 Answers
What you have to do when your gps device comes up with such a message is for you to reset your device. First check that the battery is properly charged, then you reset it by pressing the reset button that is on it. If that does not do the job. then you have to do the back up restore solution.
To do that, you have to connect your device to the computer that has its software, then you browse out the device using the computer page, then you format your device by right clicking on the device from the computer page, then you select format, do not use the quick start, format it normally, that way the whole software and applications on the device will be wiped out, then you reinstall your software back on it and try to load maps on it. After doing that, your device will work perfectly fine once again.
That should do the job.
Posted on Dec 30, 2010
Magellan triton 400 serial number
The serial number for the Magellan Triton 400 is located under the battery compartment cover
Dec 26, 2012 | Magellan Triton 400 Handheld GPS Receiver
When i turn on mt magellan triton 400 the first screen comes on and that is all and ii cant turn it off
Definitely an internal memory error. The unit has to be reflashed. If under warranty go to Magellan.
Jan 09, 2011 | Magellan Triton 400 Handheld GPS Receiver
Magellan Triton, continues to get fatal application error. What can be done to correct this situation?
Your problem stems from a corrupt software file in the internal memory of the GPS. Unfortunately, the problem is too complicated for you to solve. I really do not know of any people beside Magellan that repair the 200. The Jungle Ghost repairs 300 400 500 1500 and 2000's and maybe he can help you out. Check with www.jungleghost.com
Aug 23, 2010 | Magellan Triton 200 Handheld GPS Receiver
Each time I plug in the USB cable I get a blue screen. I am running Windows 7. I am trying to load maps onto the Triton 400.
Don't bother with the 400 on a Win7 machine even though Magellan claims it will work. I also keep getting a bad pool header blue screen on mine even though I've updated everything I could. The best thing to do is to either setup a dual boot system with WinXP and only plug it in while running XP (Don't bother with XP mode in Win7) or have a second system that's dedicated to XP and run Vantage point from it like what I run now from my laptop.
The whole problem is caused by the Triton driver and for some reason Win7 doesn't like it all that much. Vantage Point does run great inside Win7 but as soon as you plug in the Triton, that's when it all starts to screw up.
All we can do is wait until Magellan gives us a proper working driver.
Aug 21, 2010 | Magellan Triton 400 Handheld GPS Receiver
When turned on the triton 400 gps will read; internal error.... your triton has encountered an unexpected error and must shut down....please wait while your data is saved.
This problem is caused by a corrupted software file on the internal memory. The chip has to be reflashed. If under warranty return the unit to Magellan.
Jun 19, 2010 | Magellan Triton 400 Handheld GPS Receiver
Magellan Triton 300 giving Fatal Application Error!
This is a problem with the internal memory files. They have been corrupted It is too complicated to fix yourself. If the is out of warranty, the Jungle Ghost at http://www.jungleghost.com/repair_service.shtml has a repair service.
Jan 20, 2010 | Magellan Triton 300 Handheld GPS Receiver
Triton 400 will not load maps.
OK .. you could have many possible causes. The most likely is that the magellan drivers are not installed on your computer. If you installed Vantage Point you will find them under the c:\magellan drivers folder.
Now without Vantage Point being on just connect the GPS to the computer and turn it on. Then open up the device manager on your computer and you will see a PORT COM(number). Click on the properties and see if the device driver is enabled and working.
If it is not.. then uninstall the present driver and reinstall from your computer by pointing to the c:\magellan drivers folder.
JG
Sep 21, 2009 | Magellan Triton 400 Handheld GPS Receiver
Locked up with fatal application error on display
It is too complicated to fix yourself. If the unit is out of warranty, the JungleGhost at jungleghost.com has a repair service. Go to http://www.jungleghost.com/repair_service.shtml
May 21, 2009 | Magellan Triton 400 Handheld GPS Receiver
Magellan triton 400....fatal error?
Jenn,
OK .. take out the SD card. Then power up the unit and do a MENU>>VIEW>>SETTINGS>>MEMORY.
First do a CLEAR MEMORY and after that is completed do a RESET FACTORY DEFAULTS.
Now you unit will be ok and you can place your SD card back in the unit. By the way .. never use an SD or SDHC card smaller than 4GB on the unit.
JG
Jul 26, 2008 | Magellan Triton 1500 GPS Receiver
Magellan Triton 1500 GPS Receiver Logo
358 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
