Question about DeLonghi EAM3500 Espresso Machine/Coffee Maker
Magnifica coffee machine when turned on makes a noise for 3 seconds then turns itself off, it will not turn back on untill power is switched off and back on from powerpoint then the same thing will happen again for 3 seconds, can anyone help as warrenty is not covered due to loosing reciept
  • gioffret Jan 02, 2011
    it's just the motor sound and then it stops, there is no awful sound at all, just the usual motor sound as it should be.
    still require a solution if anyone can help please
You will need to open it up and lubricate the motor gears
Posted on Jan 02, 2011
  • 2,382 Answers
Hi, when you first turn the machine on at the power point, does it make a motor sound and then stop, or is the awful noise apparent at that time.
If the awful noise starts as soon as you turn it on, then most likely there is a motor problem which will need to be seen by a Service Center for immediate replacement.
Posted on Dec 30, 2010
Defuser unit stuck at bottom of Delonghi magnifica coffee machine. Squeezing red buttons does not help. Cannot remove
Recycling the power resets the position of the defuser. When you turn it off, make sure you do it via the button on the front before swutching it off at the power point.
Aug 21, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Lost the instructions / booklet and cannot recall how to clean / descale my DeLonghi ( Magnifica Model) Coffee Machine. Are you able to assist? Many thanks
fill water right to line ... turn unit on ....when its ready to use push and hold the descale button for approx 5 secs the lights wer cups are should stay on.... now place descaler in water ......put a larg container under steam pipe..... turn vaule open fully... it will run for approx 10 secs then stop for at least 15 min...until water runs out ... when light for water comes on fill tank up again with clean water place back into machine and it will flush through until empty .... when light for water comes on again ..job done ..turn vaulve to shut. ///
Feb 06, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
The power went out while i was cleaning. now both cup lights flash and the descale light fo about 15mins then the cup lights stay on contsant and the fault light stays on at the same time. from what the...
hi check u havent snapped the switch prodder ..its on the bucket rear .bottom..... change the wast bucket if broken. if its there still u may have a problem with the pcb .. we carry out repair service anywere we do a postal service
Feb 05, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
NO WATER COMING THROUGH ALTHOUGH TANK IS FULL, AND A TERRIBLE NOISE AS MACHINE IS TRYING TO MAKE COFFE
turn unit on let it set up as norm ... when it trys to wash or even if it dont ..turn steam knob fully open until noise has gone .. all done ..oh turn steam offf... bsc appliances 07779933829 postal service too
Jan 04, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Infuser is stuck at bottom of machine
hi, try turning the power on at the machine like you would normally do , then turn the power off at the machine again, not at the power point this should make the infusser pull back.
cheers
Jan 03, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Delonghi magnifica coffee machine...infuser jammed in machine. Needs to come out for cleaning. Can depress red buttons but it wont come out..looks a but squint
Remove base plate and turn pulley clockwise (probably for several minutes) until infuser arm returns to vertical position and the infuser itself drops to the low position. You should here a click when it reaches this point. The infuser can then be removed as normal.
Nov 02, 2009 | DeLonghi DCM485 Coffee Maker
Magnifica gives Generic Alarm Message - Infuser stuck
My infuser was stuck in the down position, When I called customer support the told me some easy steps to fix this problem..try calling them
Nov 28, 2008 | DeLonghi Esclusivo Magnifica ESAM3300...
New unit just won't work - keeps saying to insert brewer unit
These machines seem to respond to what their CS dept call "priming the pump." Turn on machine and after it has warmed up, turn the hot water valve or about 30-45 seconds. Shut it off and after a pause 30 seconds, repeat this process 2 additional times. Do the same 3 cycles in the steam mode. ( hit the steam button for frothing) Check openings  where coffee comes out with a small wire, ect., to make sure they are clear. It should work.
Mar 29, 2008 | DeLonghi EAM3500 Espresso Machine/Coffee...
DeLonghi EAM3500 Espresso Machine/Coffee Maker Logo
87 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
