Question about Necchi 3102 Mechanical Sewing Machine
What size bobbins does the necchi machine take?
    Genius:
  • 1,788 Answers
Look at your manual, if you do not have one, take your bobbin with you and ask a sewing machine dealer. They normally stock all sizes and will sell you the right one. I tried to look it up online but could not find the exact size listed. Good luck
Posted on Dec 30, 2010
How do I wind a bobbin?
Actually, $10 for a manual is probably a valuable investment. It will not only help you with threading & winding the bobbin but also with maintenance and care of your machine and as well as how to use your machine. Similar brand machines thread and wind the bobbin in the same manner. So, even finding a similar Necchi and the bobbin winding method should be helpful.
Necchi bobbin wind Google Search
Oct 17, 2016 | Necchi 3101 Mechanical Sewing Machine
Correct bobbin size for a Necchi Omega 6030
You can use either 16 or 16J. If your threads are loopy on the bottom side of fabric, the problem is either your needle thread tension is too loose or you have a snag in your needle plate where you have broken a needle. Check needle plate and clear snag if any. Then tighten up your needle thread tension until both needle and bobbin threads are in middle of fabric.
Jan 30, 2015 | Necchi 6030 Mechanical Sewing Machine
Stuck bobbin
Please put on the bobbin correct size. And check the tension . Then use new threads.
Dec 19, 2013 | Necchi Sewing Machines
What Bobbin Style for Necchi 531FA
check with sewingpartsonline.com for a manual & the bobbins for the machine.
necchi's are a good reliable machines, I have 2 myself
one sewer to another
Jan 17, 2012 | Sewing Machines
My Necchi 4595 has never really worked properly,.,.,the lower thread (bobbin) is very loose and then the thread breaks,,,I've tried to adjust the tension, but maybe I'm doing that wrong.
I also own 2 necchi sewing machines, my mechanical is a 4595,,
lower thread tension
to test the bobbin tension, remove the bobbin case & bobbin & hold it by suspending it byb the thread, **** it once or twice, if the tension is correct, the thread will unwind by about an inch or two.
if the tension is too tight, it does not unwind at all, if the tension is too loose, it will drop too much.
to adjust the tension,, left is loosen & to the right tighten
thread breaks
rethread the machine making sure to get all thread guides
top thread tension usually 3 or 4
replace needle- make sure the needle is inserted correctly
some needles don't work with some thread, here's a tip
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Nov 16, 2010 | Necchi 4595 Mechanical Sewing Machine
Threading the bobbin- Necchi 535FA
Hi - I have a 510 Necchi sewing machine - how do a fill the bobbin?
May 04, 2010 | Necchi Sewing Machines
Which bobbins can I buy for replacements?
Call 1-800-322-6980 for Service and Parts.
Mar 05, 2009 | Necchi Sewing Machines
Bobbin case on my 524fb necchi has come apart
Almost all Necchi use a class 15 bobbin & bobbin case, a new case should cost around 7 to 10 dollars!
Dwayne
Dec 02, 2008 | Necchi 3537 Mechanical Sewing Machine
Necchi 3102 Mechanical Sewing Machine Logo
135 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
