Question about Linksys WRT160N Wireless Router
I have a desktop & a laptop with the Linksys router connecting the two. Everything is hooked up okay, but lost the security key on my laptop . Tried to set up my E Reader wireless & went into my security key on my laptop & lost my security key by mistake. I think I have to set up NEW on my desktop & laptop....HOW do I do that . HELP
    Sergeant:
    Champion:
  • 217 Answers
Can you connect directly to your router using an ethernet cable?
Go into your settings on the router and choose a security key.
Set the same key for your laptops etc..
Posted on Dec 30, 2010
I lost my serial key # to hook my laptop to wireless
Do you have a desktop or other computer that's on the network? Use it to log into the router and retrieve the wireless key.
see this link http://www.columbia.edu/acis/networks/aptnet/linksys/index.html
Aug 16, 2011 | Linksys Wireless-G Broadband Router
I am attempting to install my new Cisco linksys wireless-n-home router. I first loaded everything on my laptop and it works fine wireless. Then I attempted to load the disk on my desktop and it gives me...
You do not need the disk, if you want it on one device that is fine. log into the routers IP address and under wireless security there will be a key. If there is no key make one now. Make the security type WPA or WPA2. On the laptop, click on the wifi signals in the lower right hand corner next to the clock. Select your network and check to always connect to that network. Type the same key that was in the routers wifi security box.
In this case, the key you would type in the laptop would be what475ever. I don't even know why they shipped a CD with the things. All it does is confuse people.
Feb 26, 2011 | Computers & Internet
Lost wireless connection
  1. Follow these steps to configure Linksys WRT160N wireless router.
    Open Internet Explorer, it does not matter if you see error message such as "The page can not be displayed" . now erase everything on the address bar and type in this IP address: 192.168.1.1 or the full address: http://192.168.1.1
    This is the default IP address for the router set by Linksys.
  2. 2 Hit the Enter key on your keyboard to connect to the router's web admin control panel. You will be prompted a login window for the username and password: the default admin username is "admin" and the default admin password is "password". If you can't connect to this admin control panel, you will need to change the IP address on your modem, maybe your modem is using the same IP 192.168.1.1 also, just unplug the router from your modem, and hook up your computer directly to the modem and fire up the web browser and enter the IP 192.168.1.1 and follow the on screen direction to get in.
  3. 3 It will then ask you to change password, then you make up a password that is meaningful for you to remember. You will need to write down the username and password for future reference because I am sure you will forget. You will need to reset the router if you forget the router password, and that will erase everything saved inside the router setting.
  4. 4 After successfully login, you will be in the Basic Setup of your Linksys WRT160 wireless router. You also might need to clone the Mac Address if you are using Cable Broadband (Comcast), to do this go to Mac address clone -> Enable, then clone my computers Mac.
  5. 5 If you are using Verizon, you might need to change the Internet Connection Type to PPPoE and enter your username and password that is created by Verizon.
  6. 6 I think many of you concern more on the Wireless secrutiy. Click the Wireless tab and enable the wireless security, you will need to choose a type of security encryption, WEP is weaker, you will need to type 10 characters for the pass code. The WPA or WPA2 is much stronger that it takes passphrase. For more security on wireless connection, you can also try to use MAC authentication, each of your laptop or wireless card has unique MAC address, you find out the MAC address on your laptop then enter it into your router so only this laptop can have access to the wireless connection.
Jan 25, 2011 | Linksys WRT160N Wireless Router
Can't Connect Laptops Wirelessly to Linksys WRT54G2
1.Log into router (192.168.0.1) user name "admin
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the Desktop/laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
Jun 28, 2010 | Linksys Wireless-G WRT54GS Router...
Laptop says no internet connection
First you need to ensure proper connection and filtering. Make sure the source cable is plugged into the Linksys router first. Direct connections must be made to the router, meaning the cable to your main computer should come from the router, not the main source.
Next make sure that the connection is made. You should see a light on the router indicating proper internet connection. Once this is accomplished, connect your main computer and you should have access to the internet on it.
Now comes the easy but somewhat tricky part (tricky only because icons can vary a little). If you haven't already done so, run the setup disk for Linksys. It's has simple, easy-to-follow instructions to set up your network. Now for the laptop. On the blue bar at the bottom of the laptop screen there should be an icon indicating internet connection. Click on that icon to show available wireless networks. Most likely your Linksys router will show up as a secure network. When you click on that connection it will ask you for a WEP key. That key is usually a 10 digit alpha-numeric key written on the back of the router. Sometimes it's on the box the router came in. Sometimes it requests a 12 digit WEP key, in which case simply add two zeros to the front of that same key. If you set up a password for your wireless network you will need that as well.
NOTE: if you have neighbors close, you should always secure your network with a password.
You may need to shut down and restart the laptop in order for the changes to take place.
It sounds confusing, but once you start you'll find that it's actually fairly straight forward. I hope this helps. Good luck!
Jan 12, 2010 | Linksys Wireless-G WRT54GS Router...
Lost installation cd cant connect to wireless router wrt54g v8 linksys router need to know how to get it connected to my laptop
If you configure the Linksys wireless router with encryption and you configure your wireless card in your computer with the router's encryption settings it will secure the Linksys wireless router and allow your computer to connect to the Linksys. Please click on this link and follow my instructions to secure your wireless router :-
http://www.fixya.com/support/r3559128-wireless_router_security
Jan 06, 2010 | Linksys Wireless-G WRT54G Router
I have a WRT54G2 Wireless router. Works okay with
yes mke sure wep is correct code. make sure you home security level is the same as your laptop. have tried hooking up your laptop to the home with a cat 5 cable. we had to do this with 2 dell vista laptops. then disconnect lan and we hooked up wirless just fine. something in vista firewall settings.
Dec 31, 2009 | Linksys WRT54G2 Wireless Router
I cant connect my laptop to the internet through my linksys router, the router is hooked up to a motem on my desktop computer, my laptop says it is conected to the network but it will not allow me to go...
You have to configure your laptop the router. For that First down load the CD which came with the linksys router to your laptop. It carries all the instructions how to set up the internet connection. After downloading, Connect your laptop to router with Ethernet cable. Normally the linksys link should come up automatically. If it doesn't open the linksys link by clicking on the icon on the desktop.it will give you step by step instructions on how to configure your laptop to the wireless router. You should not have any problems as it is simple
Dec 02, 2009 | Linksys Wireless-G WRT54G Router
Method to add another laptop to wireless Linksys in home. Model no: WRT546 Serial no. CDFF1G506178 password lost...tried ADMIN
just try reset in your linksys and reinstall once again the driver for it in both your laptop and set a password for it .....
Aug 07, 2008 | Computers & Internet
Linksys WRT160N Wireless Router  Logo
108 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
