Question about Sony STR-DE805 Receiver
Receiver keeps cutting off. protector lighst comes on
  • 591 Answers
I'm not familiar with this model but is the receiver has an amplifier combined, if so first check for a short circuit on the outputs (speaker wireing), if not combined with an amplifier check the audio cables for shorts too.
If all the cables ar OK than i suspect a power supply problem you need a good tech. for that...
Posted on Dec 30, 2010
  • 4,234 Answers
The question is when does the light come on, immediately upon turning on the unit or after turning up the volume? See the link below for an explanation of protect mode. Update this with more details and I'll be able to provide more detailed repair estimates.
Thanks,
DAn
Link: http://www.fixya.com/support/r5390728-protector_means
I have sony radio model no STK-KM22 it display flashing protector messege and I cant play any thing ,how I can solve thi ploblem?
Unplug for 30 seconds unplug speaker cords.twist all wire ends together tightly for each set of wires.one little wire not twisted tightly with the rest can short out throwing receiver into surgery protection mode.plug receiver back in or reconnect it.test each wire set to see if external speaker wire issue.wire sets are twisted good you will know as each speaker will come back on.twistem tight soldier them or use liquid tape to keep connection working properly.use surge protector to protect unit receiver.
Apr 09, 2017 | Sony Audio Players & Recorders
Sony GX800ES protector
Make sure none of the speaker wires are touching each other. If they are, it will short out the stereo which triggers protection mode and cuts out all of the sound.
Sep 21, 2007 | Sony STR-GX800ES Receiver
It keeps blinking protetor
The protector circuit protects your amplifier from shorted speakers . One of your speakers , or more speakers are shorted out . To figure it out easily follow these instructions . Turn the unit off . Now unplug all of the speaker wire connections from the back of the unit . Turn the unit on . Make sure the volume is turned all the way down . The protector light should not light up . If it does , the problem is inside the unit itself and we'll have to be repaired at the shop . If the protector light is off than continue on as follows . Connect the speakers one at a time to the unit . Each time you connect a speaker , turn the volume control up and back down making sure the protector light does not come on . When you connect the bad speaker , the protection light should come on . Whichever speaker makes the lights come on when connected is the bad speaker and should be replaced .
Oct 21, 2010 | Sony STR-DA2ES 6.1 Channels Receiver
It flashes the word - protector
Hiya,
Disconnect all speakers at the receiver and power it back on. If it stays on, check all speaker wires and speakers for shorts (touching wires). If it cuts out, it needs to be serviced.
Regards
Mike
Mar 24, 2010 | Sony STR-DE625
After a power surge my DVR-625 receiver keeps powering/cycling on and off between TV 1 and 2. It never comes on so that I can get a signal.
You will need to unplug your rec and bypass any surge protectors, if you still have teh same issue tehn call 800-333-3474 to have your recr replaced. it is a very common issue.
Oct 31, 2009 | DISH Network DVR-625 DTV Receiver /...
Message "PROTECTOR"
Disconnect all speakers at the receiver and power it back on. If it stays on, check all speaker wires and speakers for shorts. If it cuts out, it needs service. If you need detailed troubleshooting help on this after testing receiver without speakers connected and it passes, post a comment and I can walk you thru it. Hope this helps.
Oct 24, 2009 | Sony STR-DE625
Every time I try to turn on my onkyo receiver it turns off instantly
the reason why the receiver probably keep turning off is that the systems come with overload protector to keep one from burning or short the systems out so it shut its self off. make sure you have the speaker wires is connected properly, its very important that you do although the receiver has 0% tolerance when it come to speakers hook up. positive from speaker to positive connector behind reciever; same as negative. double check all speakers wires. repost if that not an issue
Oct 03, 2009 | Onkyo TX-SR605 Receiver
Keep getting message protector
if all connections and speakers seem ok the problem is internal witch can go from blown power supply to shorted output devices and everything in between , and as always look for repair shop in your area, do not attempt to do it yourself, firehazard and electric shock are the things we all want to avoid ;)
Sep 01, 2009 | Sony STR-DE835 Receiver
Dish ViP622 keeps crashing - on 6th unit from Dish network
the 622 receivers are very sensitive to static electricity build up, if you have been through more than two receivers i would demand having a technician come to your home to check grounding of your dish system, while he is there he will also check the grounding where you plug the receivers in, i suggest not using any surge protectors/power strips and, as debmaldo did, try different outlets, if you have a very high end surge protector, it should be okay but for troubleshooting purposes try a different wall receptacle
May 05, 2008 | DISH Network ViP622 DVR DTV Receiver /...
Sony STR-DB1070
Check all your speaker connections and make sure there are no shorts where any of the negative wires can come in contact with any of the positive wires.
Dec 10, 2007 | Sony STR-DB1070 Receiver
185 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
