Question about Belkin (F5D9230-4) Wireless Router (F5D92304)
Ip address where do i find my ip address for my router, it is not on the item and i no longer have the box it is a belkin f5d8631-4 N1 , i want to change some settings
  • paul cahill Jul 08, 2008
    found it on another web site you were close, 192.168.2.1
If it's changed you can reset it to the factory settings by pushing the reset button (with f.a. a paperclip) for about 20 seconds. After about 1 minute you can access the router via 192.168.2.1
Posted on Jul 21, 2008
    Scholar:
  • 77 Answers
To access the web base settings of your router, in an open internet explorer window type 192.168.1.1 or 192.168.0.1 one of these should open a window asking for username and password. If you haven't changed these settings it should be admin for both.
Good Luck
Posted on Jul 08, 2008
I need to reset my router password.
You will need to log into your router with the IP Address, userid and password, then you can change the router password.
You do realize that the Router Password just lets you get into the router to make changes to it.
The Wireless Password is what allows people to connect their wireless devices or laptops to the internet via the router. If you need to change the wireless password then once you get into the router go to the wireless tab or wireless security and change it.
The manual will give you the router's IP address, default userid and password. Also it might be on a sticker on the side or bottom of the router. The wireless password or network key might be on it also.
If you need the manual go to Belkin's website.
Get online and got to www.google.com In the google search box type: "Belkin Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for Manuals throughout the site.
Below is a direct link to their site where you just plug in your model number.
http://en-us-support.belkin.com/app/product/list/q/routers/
Jun 04, 2012 | Belkin N1 Vision Router
Have a Belkin N1 wireless router. Moved to new apt. and am about to setup the home network. Now I cannot connect to the router using Ethernet and using any of the 3 suggested 192.168.2.1 or 1.1 or 0.1....
If you're connected to the router via an ethernet connection you should have a valid IP address,
the IP address for your router USUALLY is the common 192.168.1.1, etc but you can find out what YOUR router's IP is by doing a simple IPCONFIG command.
If you're running Windows XP:
Press START, then "Run...", and enter "CMD" and press OK
If you're running Windows 7 or Vista:
Press START, then in the search box enter "CMD" and hit ENTER
This will open a command prompt, here you enter IPCONFIG and hit ENTER
You'll see a list of all of your network adapters, If you see Ethernet adapter Local Area Connect #:
you'll need to figure out which one is your connection.
The list item called "Default Gateway" will be the IP Address of your router.
Jun 04, 2011 | Computers & Internet
My belkin N1 router when i plug it in it just flashes the security light and wont connect to the internet
You will need to double-check your security settings. Apparently, the modem is trying to tell you there's a problem regarding this.
The easiest way to be able to access the router settings in this case, will be to provide a direct connection between your PC and the Belkin router (using a network cable) and then type in that address.
If the address still doesn't work, double check the router's IP address by opening the Command Prompt (it's under Programs -> Accessories) and typing in "ipconfig", then hitting Enter. The IP-address you're looking for is listed under "default gateway".
(Also, make sure your computer isn't using a fixed IP, set it up so it's dynamically assigned an address by the Belkin router.)
Jan 20, 2011 | Belkin N1 Wireless-N Wireless Router
Can the belkin n1 visoin, support nat type 2, connected to a playstation 3?
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Nov 05, 2010 | Belkin N1 Vision Wireless Router
N1 Vision Router: i cannot connect to my belkin router...
Check the routers gateway IP address is in the same subnet as the other computers or laptop.
Ie 192.168.1.X . (X is between 1 and 254)
In addition, the sub net mask is 255.255.255.0
If all is ok then it is probably a miss configuration with WPA /WEP options
May 18, 2010 | Belkin N1 Vision Router
How to forward website to belkin n1 vision router
You would have to log into the router to configure port forwarding on port 80. You would have to know the IP address of the computer hosting the website and put that in the routers config under port forwarding.
Oct 27, 2009 | Belkin N1 Vision Router
Belkin N1 Vision - Virtual Servers Add button doesn't run ok
Ascertain what incoming ports you need to open and the IP address of the device / computer that you wish to forward to and set the ports up manually.
· Enter a description for the service
· Enter the inbound port ranges from WAN
· Enter TCP/ UDP type
· Enter IP address that the service is to be forwarded
· Enter the private port range (keep these the same as the incoming ports unless you are running multiple services ie 2 web servers on port 80)
· Click enable check box and save entry
· Repeat as required.
Sep 27, 2009 | Belkin N1 Vision Router
BelkinMIMO wireless router stopped connecting to internet
I just installed a Belkin N1 (model F5D8635-4 v1000) to a Comcast Arris modem in SW Florida by resetting the IP on the router to 192.168.1.1 Comcast assigns 198.168.0.1 (but will accept 192.168.1.1 however not .2.1) and Belkin default is 192.168.2.1. Problem is easy enough to correct by following the instructions for changing the default router IP using a Firefox interface as documented in the user's manual. Note that when applying changes it takes about 30 seconds for changes to be effective.
Sep 16, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Final Fantasy XI drops every two hours
problem in the game box just check it the port number and ip address of the game box and the router also or any firewall is on then off it or any antivirus also off it then try it
Apr 04, 2009 | Belkin N1 Vision Wireless Router
Playstation 3 networking problem with belkin n1 router
To REDUCE NAT ON PS3 /Xbox
Step 6:Scan and connect in the PS3/Xbox
Step 7: Get the IP Address of the PS3/Xbox
Step 10:Enable the IP Address of the PS3/Xbox in it
Step 15:Enable UPnP
Goto : my blog for more information about belkin routers (Page is still under construction )
Open Router setup
Jan 05, 2009 | Belkin (F5D8231-4) Wireless Router...
Belkin (F5D9230-4) Wireless Router (F5D92304) Logo
41 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
