Question about Black & Decker Drills
I need wiring diagram for a Black&Decker DR550 corded drill.Replacing power cord,so I need to find out which holes it goes into.
  • 22 Answers
An electric meter can be used to find where wires go to switch
Posted on Jan 23, 2011
Cord connection to switch of black and decker hammer drill Dr250
Look beside the wire in the switch their should be a small hole.put a paper clip in this hole and push down and then pull on the wire.
Jan 11, 2015 | Drills
I purchased a Black & Decker DR260B drill to drill masonry but there's no info in manual about brick. Can I use this drill to drill holes in brick mortar?
This corded drill has enough power to drill normal brick masonry without issue as long as you're using a masonry bit.
http://www.homedepot.com/b/Tools-Hardware-Power-Tool-Accessories-Drill-Bits-Masonry-Percussion/N-5yc1vZc23f
Nov 07, 2014 | Drills
Where can I find a service manual? I need to change the 3 wire power cord to a 4 wire cord.
first install the RED & BLACK conductors on the cord to the L1 & L2 terminals or the 2 outer terminals on the 3 position terminal strip on the dryer,next take the WHITE ( NEUTRAL) wire on the cord connect it to the "N" terminal on the dryer terminal strip usually located between the 2 phase wires RED & BLACK so the terminal strip will be(RED-WHITE-BLACK) red & black can go on either outer terminal as they are not polarity sensitive due to the A.C. current, then the GREEN on the power cord goes to any metallic portion on the dryer case
Aug 23, 2012 | Maytag ADE7005AYW Dryer
I HAVE A BLACK AND DECKER IRON-DIGITAL ADVANTAGE, POWER IN THE IRON GOES ON AND OFF NEED TO KEEP ON HOLDING THE POWER WIRE INTO THE IRON, SO I TRIED TO OPEN THE WIRE SECTION,BUT IT NEED A SPECIAL TOOL TO...
Bring the iron to a Hardware store, ask for a set of tools right for the type of screws (maybe Torx, Security Torx, tri-wing, bristol and others).
Once you can open the iron and access to the cord you may change the power cord. it is easy.
Power goes on & off because the power cord is broken. This failure is very common on irons.
Good luck
Apr 19, 2011 | Black & Decker Steam Xpress AS250 Iron...
My porter cable 19.2v model 8605 battery charger
Porter Cable has not offered a replacement for their poorly designed 19.2V chargers. I had the same problem and happen to like my drill and circular saw. I found a universal charger called a model number CHUN-2420. Google it--I got mine for $27 plus shipping. All you need to do to make this work is splice 3 wires.
My charger is a PC model 8624, so the instructions might vary slightly between the chargers. Remove the six screws on the bottom of your PC charger. Remove the bottom section. Remove the screw(s) that attach the circuit card to the plastic housing. Disconnect the 3 pin white charging connector from the circuit card, and cutoff the connector. Discard the circuit card and power cord. Cut the 3 conductor (red/yellow/black) cable coming out of the Chun-2420 approximately 2' from the charger. Splice these three wires to the three wires in the charger housing that connect to your battery. In my situation, Red/Red, Yellow/Yellow, White/Black. To verify, red=positive, black/white=negative, yellow=temperature sensor. Wrap the red/yellow/black cable with electrical tape where it exits the PC charger through the power cord hole. Re-attach the bottom.
Jul 24, 2010 | Porter Cable 19.2V Drill Kit
When replacing cord on black & decker 7190 type 1 electric drill i dropped the drill one of the wires pulled free and im unable to visibly tell how it is to be rewired correctly need diagram displaying...
If you look at the trigger/switch mechanism, you'll note little lettered ovals on either side at the bottom/base where the wires go. The black (hot) wire from the plug goes to the side stamped "LINE", and the white (neutral) wire goes to the side stamped "LOAD"
Jul 02, 2010 | Drills
I Own a U21 Black & Decker Drill Type AH070865 I need to get the stator completely fixed infact a wiring diagram would be great, or a repair manual
Go to www.2helpu.com which is the Black & Decker after sales service site. Most, if not all diagrams are located there, including manuals
Jun 03, 2009 | Black & Decker Drills
Zivan NG3 battery charger diagrams
your NG3 should have been preprogrammed for the type of batteries you are charging. The NG3 has the 3 wires from the power cord. Here is what I have done:
Brown from charger goes to black wire
Blue goes to white wire
yellow green goes to green ground.
Mar 11, 2009 | Ryobi Multi-Volt Battery Charger
Drills Logo
315 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
