Question about Fuji FinePix Digital Camera
My camera is showing protected card how do i get that off it wont let me take pictures
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Fuji Master
  • 102,366 Answers
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Posted on Feb 11, 2011
Camera shows write protect when open
When what is open? Always keep the battery / memory card door closed. If it is not closed correct, the camera won't work as expected. To protect the file system, when someone should pul out the memory card, while the camera is accessing the memory, it will or shut down completely, or at least protect the memory card against writing to it.
Before opening the battery / memory card cover, always make sure the camera is completely shut off. That means no light is allowed to burn or flicker. The memory card can also be write protected (SD cards) when the lock switch is down like in the picture on the 32GB card.
Before you can make any picture the switch on the card should be up like on the 64GB card on the picture. 3635bcf4-65df-478c-a04d-92e341d15860.jpg
Jan 29, 2014 | Cameras
Camera won't take pictures it show protected card
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jan 23, 2014 | FUJIFILM A220 Digital Camera
Card locked shows of view finder, cannot take a picture it shows a't picture but won't take a picture
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 06, 2012 | Canon PowerShot S2 IS Digital Camera
My SD card is locked and i cant get it unlocked
Nov 24, 2011 | Vivitar ViviCam 5024 Digital Camera
My picture card is saying no picture when i go to take a picture the card says full it wont let me take a picture??
Hi.
Check AE lock custom button:
Ensure that the memory card has no protective seal or object in front of the protection area. See here.
Ensure that the files are not individually protected (Key sign in settings)
If that does not fix the problem, then the card may be defective. In that case replace the card.
Here a manual.
Sep 14, 2010 | Olympus Camedia C-3020 Zoom Digital Camera
Card protected
Use a separate card reader to download your pics. Then, you can format the card in the camera to get it to work properly.
Mar 25, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Cant take pictures with memory card in
Mar 19, 2010 | Fuji FinePix S700 Digital Camera
CANNOT TAKE PICTURES SHOWING PROTECTED CARD
Nov 12, 2009 | Fuji FinePix J10 Digital Camera
Digital camera
personally i never connect the cam to pc using the usb cable, i take the memory card out and put it in an sd card usb adapter, you say the images are protected, this tells me that you have the lock switch activated on the sd card...hope this helps :)
Jul 11, 2009 | Samsung L100 Digital Camera
Protected feature
There are 2 probable solutions. 1. The images are "protected" by the camera & will show "locked" when you try to erase them. 2. The SD card in the camera is locked. The solution to 1 is to unlock the images in the playback menu. See page 46 of the manual. Note that you need to select "unlock" you can't select protect as they are already protected! Solution 2 is to remove the card from the camera & check the "lock" slider that you can see on the side (although no all cards have this). Set the lock off. You can download the manual from the first link on the following page: http://www.vivitar.com/manuals/english/ViviCam6300/CameraManual.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 11, 2007 | Vivitar ViviCam 6330s Digital Camera
Fuji FinePix Digital Camera Logo
13 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
